Question about Panasonic Heating & Cooling
Panasonic inverter air conditioner remote control wont work, it will not turn on and there does not seem to be an override switch on the actual unit?
To replace your battery have 2 AAA batterys and slide down the front cover and pull the cover of the remote you will find the battery compartment underneath the slide.
Posted on Jul 08, 2011
  • bargearse65 Aug 12, 2011
    you are a bloody champion you have sorted our question out thankyou!!!!
  • 2,133 Answers
Replace battery in remote. If still problem replace remote.
Posted on Dec 31, 2010
  • 1 more comment
  • jujuhan63 May 23, 2011
    how do you change the battery?
  • sandraz38 Jul 08, 2011
    slide the front cover down and take it off and the battery compartment is underneath type AAA Baterys.
  • Martin Finlay Aug 30, 2013
    Tried replacing batteris but does not work, the air conditioner is still stuck on auto and still must turn on or off on AC, remote seems to be dead....
My panasonic inverter 410a has remote control problem. we already change indoor unit pcb . but doesn't work.so what to do?
SERVICE MANUAL Inverter Split system Air - Thermospace ...
www.thermospace.com/shinco/Inverter_Service_Manual.PDF Panasonic(rotary type. DC INVERTER). Refrigerant. R410A(pre-charged). R410A(pre-charged). R410A(pre-charged). R410A(pre-charged). Cooling. Capacity.
Jul 12, 2015 | Panasonic Heating & Cooling
Fujitsu inverter ASTA30LCC wont start after remote reset
Check that the circuit breaker in the switch board has not tripped, then check the isolator near the outdoor unit has not been turned off. After that, check your remote control is transmitting by focusing a digital camera at the transmit LED on the end. If you see a purple flash through your camera each time you press a button, the remote is probably OK. If these check out, you are going to need a tech to diagnose the controlling circuitry inside the air conditioner.
Jan 02, 2015 | Heating & Cooling
Panasonic air conditioner with seral nr. A75C2616
Have you checked your remote
control if you have accidentally set the
timer off to turn off one hour after
turning it on? Seems like the problem because the
timer LED is lighting up means that the
unit has shut off via the timer. Verify the remote if there is a timer
setting on it. If you would not
recognize it, try to remove the battery
for about 5 minutes, return the
battery, then just press the on and off
switch and put it in cooling mode and observe if it did correct the problem.
Jul 15, 2013 | Heating & Cooling
My samsung inverter condition does not switch off error C1
Try:
Switch the unit off with the remote (power button) - "C1" appears on unit
Push "Auto Clean" button on remote
Unit should switch off
Nov 16, 2012 | Heating & Cooling
I have a Panasonic air conditioner model CU-E12EKU (inverter). The unit stop working and the timer indicator is blinking. I checked for this error and followed the instructions in the Operating Manual,...
Not sure if yours has a letter 'H' before the 16 but if it does, it's the:
- Outdoor Current Transformer open circuit.
which means that your outdoor controller board is faulty.
Sep 08, 2011 | Panasonic Heating & Cooling
My Ac wont turn on becauser the timer light is blinking Panasonic inverter R410A
use the remote to retrieve error code,on the bottom of the remote you will see a CHECK bottom,use a pointed pin to press it for 5 seconds the display of the remote will change to two underscore, then scroll the arrow beside the time,r press until you hear beep sound, then jot down the error code..there's a error code you will see inside the panel of the indoor unit,for quitting press again for 5 seconds the Check bottom
Aug 22, 2010 | Panasonic CW-1006FU Air Conditioner
Panasonic Inverter CS-E12EKU timer indicator blink. The unit not work at all, I follow the manual instructions using the remote control but the instructions are not clear. Using other similar Panasonic...
Today I install a new unit Panasonic CS-S13KKP also have a same problem timer blink and the outdoor unit wont start. Error code is 11. after checking the problem, can not using a 3 cable cord, solve the problem using 4 Cable cord and its run !
Victor
Aug 21, 2009 | Panasonic Heating & Cooling
My remote wont turn on A.C. and when I push manual override cool or heat nothing happens the unit is a coleman mach with the RVP remote I am also getting the led flash on 2 seconds off one,my remote test...
If the system does not turn on and there is not beep, it is either a low or overvoltage situation or a problem in the wiring. Check the 12VDC at thermostat and make sure that it is OK. Also, check the incoming 120VAC at the control box (unit with small phone cord)
Jul 06, 2009 | Coleman Mach III Air Conditioner
Remote is working- but unit won't turn on
check your remote control using your camera or cellphone camera as your eyes. Point the remote control transmitter to your camera and "on", light should emit in your remote control transmitter (means good remote). Check for reset or rst button in your remote control and push it to reset and test it in your unit. If wont work means either the receiver board or mean board is defective.You need a qualified tech. for this problem. For the mean time you can use manual button to operate the unit.
Jan 30, 2009 | LG LSC121PMA Split System Air Conditioner
Heating & Cooling Logo
4,626 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
