Question about Kyocera Mita FS-1920 Laser Printer
I have a Kyocera fs 1920 printer how do I replace the drum with a new one
  • 200 Answers
1. Remove the paper cassette and the paper transfer unit. (Draw the paper transfer unit while pressing the buttons in)
2. Remove the developer unit.
CAUTIONS When if installing or removing the developer, do not let the magnet roller touch any part in the printer.
A. Open the top cover.
C. Remove the toner container.
D. Disconnect the developer connector.
E. Remove the developer from the printer while sliding the developer lock lever frontwards.
F. Gently flip down the magnet roller protective cover.
NOTE After removing the developer, seal it in the protective bag and place it on a flat surface. Do not place the developer in a dusty area.
3. Remove the waste toner bottle.
4. Remove the drum unit while pressing the drum lock.
I hope this is helpful,
Shawn
Posted on Jan 29, 2011
How to add fs-1920 printer to HP300 pc
depending on u're OS you can use a wizard from printer and faxes for win xp and win7 or using installation cd. connect the usb cable or parralel cable switch on the printer the found new hardware appears continue with installation select u're model kyocera->fs1920 or nearest model-> then follow instructions
Jun 22, 2012 | Kyocera Mita FS-1920 Laser Printer
Kyocera FS-1920, error F030:0077538
i've been working on kyocera's for about 4 years. now..this error is not good..it's a general system failure..only solution is replacing main board.
contact me if you need a part #.. I can look it up for you
Feb 01, 2010 | Kyocera Mita FS-1920 Laser Printer
My kyocera fs mita 1920 some dose not print or the message of add tonner come out while tonner was their why it do that?
remove the toner ... shake it well and re fix it and check ..... remove the drum unit and clean it ........ for more details please post your comment
Dec 29, 2009 | Kyocera Mita FS-1920 Laser Printer
I need to purchase a power supply for a Kyocera FS-1920 network printer
call a kyocera dealer or do a google search... google search will always be cheaper...
Nov 17, 2009 | Kyocera Mita FS-1920 Laser Printer
Kyocera FS 1920 paper jam
Please install printer cartridge with drum unite properly.
Aug 24, 2009 | Kyocera Mita FS-1920 Laser Printer
Kyocera fs-1920 (call service 6400:0040085) help!
the printer will require a need new fuser unit or a new power supply.
let me know if you need more help
Oct 24, 2008 | Kyocera Mita FS-1920 Laser Printer
Kyocera FS-1920 error message: "call service 6400:0295998"
Your drum unit is not seated correctly. Look inside for a bent drum ground clip.
Oct 19, 2008 | Kyocera Mita FS-1920 Laser Printer
Problems with Kyocera Mita FS-1920
Make sure that your paper sizes match in the control panel of the printer in Windows. It will not only cause the duplex not to work but could cause jamming problems as well. When printing in duplex mode, make sure it is turned on.
Jul 23, 2008 | Kyocera Mita FS-1920 Laser Printer
Kyocera FS-1920 won't pick up paper from tray
replace pick up rollers and paper tray roller. Take out paper tray and toner, lift printer so you can see underneath you should see a set of rollers its nopt to hard to get out. also in the paper tray there is a roller swop that out to
Dec 14, 2006 | Kyocera Mita FS-1920 Laser Printer
Kyocera Mita FS-1920 Laser Printer Logo
713 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
