Question about KitchenAid K45SS Classic Stand Mixer
My K45SS starts about medium speed on 1, goes up 2 speeds higher on next 2 settings, then no more change on other settings. If I barely turn on switch it will run slower but pulsate or surge. Took back off and cleaned well, brushes also look good.
5 Suggested Answers
SOURCE: KitchenAid K5SS mixer speeds up beyond set speed.
I have the same mixer and I believe your problem is the governor that is on the back of the motor. You can figure it out by downloading the repair manual here:http://store.mendingshed.com/kitaidparts.html The manual has all the info you need; including a troubleshooting section. The governor is availible from the the same site here:http://store.mendingshed.com/kagovernor.html What tipped me off on my K5SS was looking at the governor as it ran and I could see it moving back and forth; not steady like it should. Good luck!
Posted on Aug 19, 2007
ricardok45
  • 135 Answers
SOURCE: k45ss kitenaid mixer surges at low speeds
Hi. Go to mendingshed.com and download their free Kitchenaid Service Manual. This valuable document will help you to tune up your mixer, and covers the K45SS model. They also sell kitchenaid parts.
Go to kitchenaid.com and search for a parts manual for your mixer. Enter your model# thusly k45sswh.
If this solution has assisted you, please rate it. Good luck! ricardok45.
Posted on Apr 14, 2009
  • 153 Answers
SOURCE: My wife's Kitchen Aid Artisan 325W mixer has
You need to adjust the mixer speeds. Obtain a copy of the KSM150 Repair Part List from Kitchenaid.com. Remove the screw holding the End Cover and locate the three screws from the Control Plate. All three (2 top left and right, and 1 bottom) must all be adjusted. 1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Posted on Jul 03, 2011
  • 11 Answers
SOURCE: We have a K45SS mixer problem. When it is on the lowest setting it hums and the beaters barely turn. The next setting up has a noise but the higher speed settings work just fine. What is the problem?
the lower setting is for stirring. this is a high quality machine that is made to take a beating. you are just hearing the motor wind up. think of it like a jet engine starting, its made to run its smoothest at high rpm's, so it sounds funny at low rpm's but nothing is wrong with it.
Posted on Dec 20, 2011
250 watts k45ss classic stand mixer doesn't run
My first guess would be the speed control plate. It has three screws in an upside down triangular shape. The two screws on top control and adjust speeds 1 thru 6, and often times just one screw being out a 16th of a turn will shut the mixer off completely. I would venture that when you were removing the two stud bolts you moved the adjustment screws on the speed control plate. Remember that even a slight movement can shut down your mixer, take a phillips screwdriver and turn the top left screw one quarter turn while the machine is on, it can start on you so don't be shocked and jump with a loaded screwdriver in your hand at the back of an electrical device, stay calm, if no start then try the left screw a quarter turn, if it does not start go to a half turn on each screw, if still no start turn thr screws back to the start place and try the bottom screw a quarter turn left and right, if you do not start by now, then something is wrong in another place, go back to the brushes and take them out and check how you put them in, these are the two most common problems with a no start mixer. If this does not fix your problem or get the mixer to start please come back here with more info. If you motor raced in the first place then I would suspect the phase control board, but when it came back to normal speed it leades me away from the phase board. When the phse control board goes out the mixer only works at high speed. So please let us know so that we can help further.
Mar 28, 2013 | KitchenAid K45SS Classic Stand Mixer
Mixer doesn't work on all speeds
First the K45SS does not have a hall effect sensor. the pro series the epicurean seines and the pro series 5 use them, The K45ss system uses a phase control board a speed control plate and a governor for speed control. the governor rarely goes out the phase control board is a likely culprit but the system would work only in high gear if it was bad. I agree with the guest above in that it sounds like the retaining nuts on the adjusting screws of the speed control board have worked themselves loose and the adjustment screws themselves have vibrated out of proper position.
Sep 20, 2012 | KitchenAid K45SS Classic Stand Mixer
Dec 20, 2011 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid mixer motor quit , I dont really see any thing wrong with the brushes.
Obtain a copy of the Repair Part List for your model from Kitchenaid.com.
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
First, you may want to adjust the mixer's speeds:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Second, if the mixer won't run:
Remove the Control Plate Assembly (36), the Phase Control Board (39)
and the motor Governor Assembly (35). Inspect for loose connections,
burnt or damaged components. If they seem to look OK, re-assemble
them and test the mixer. If the motor still won't run, then I might suspect
a defective Phase Control Board (39).
Aug 01, 2011 | KitchenAid K45SS Classic Stand Mixer
I have a KA k45ss and it is stuck on high speed only
You need to adjust the mixer speeds:
All three (2 top left and right, and 1 bottom) must be adjusted.
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 28, 2011 | KitchenAid K45SS Classic Stand Mixer
I have a Kitchen Aid k45ss that was dropped a few years ago. I works fine but the speed switch doesn't want to stay in the off position so we have to unplug it. I opened the unit and the switch...
When you said "the speed switch doesn't want to stay in the off position", you meant to
say "the speed switch in the OFF position does not turn OFF the mixer", or "the speed
switch physically cannot be moved to the OFF position"?
In any case, try to adjust the mixer speeds.
Obtain a copy of the K45SS Repair Part List from Kitchenaid.com.
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 21, 2011 | KitchenAid Food Mixers
The mixer goes real fast on all the settings. Whats wrong?
The K45SS is very similar to the 5-qt. tilt-head Artisan Stand Mixer.
You need to adjust the mixer speeds. Obtain a copy of the K45SS Repair Part List from Kitchenaid.com. Remove the screw holding the End Cover and locate the three screws from the Control Plate. All three (2 top left and right, and 1 bottom) must
be adjusted. 1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned anymore. Leave the bottom screw alone for now.
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 14, 2011 | KitchenAid K45SS Classic Stand Mixer
My classic KA mixer will not start on speed position one or two. It will start if I move the the speed knob to 3 or 4. I then can use any speed. This isn't normally a problem unless I forget and start...
You need to adjust the mixer speeds. Obtain a copy of the K45SS Repair Part List from Kitchenaid.com. Remove the screw holding the End Cover and locate the three screws from the Control Plate. All three (2 top left and right, and 1 bottom) must all be adjusted. 1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 08, 2011 | KitchenAid K45SS Classic Stand Mixer
Speeds don't increase after 6
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 03, 2011 | KitchenAid K45SS Classic Stand Mixer
At its lowest setting, our mixer spins at ever increasing speeds until it stops and then, will not work at any setting.
Your motor needs to be replaced. The speed setting should be able to be set from the start, and if it will not slow down or change speeds, the motor has been over-heated and will need to be replaced. The only quick fix for this is to bypass the speed setting, and change the brushes on the motor. If you do not know how to do this, ask a serviceman to change the brushes only. Brushes usually run about $30 to repair. Although, you will only have one speed.
Nov 16, 2010 | KitchenAid K45SS Classic Stand Mixer
KitchenAid K45SS Classic Stand Mixer Logo
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
