Question about Empire DV-35 Heater
I have just installed a good used empire DV 35 direct vent heater. after about 10 minutes of heating up, the 4" wall vent get very hot to touch and the 4" insulated pipe that comes out of the wall behind the heater on the outside get very hot to touch, so hot that it can burn your finger. I dont think thats safe and shut it down. I'm afraid it will set the wall on fire. My next move is to atach a thermometer to it to see how hot it actualy is. What is temp range is considered safe?
SOURCE: Empire Wall Heater(propane) won't stay lit
John Mac here...the solution was that we had shut the pilot off for the summer, and birds had made a nest inside the heat exchanger...coming in through the direct vent. Cleaned out the nest, and it works perfectly. My technician recommends that I leave the pilot buring through the summer to prevent this in the future.
Posted on Aug 30, 2007
Therinnaiguy
  • 1420 Answers
SOURCE: B vent configuration of direct vent propane heaters
Yes, the design of the combustion chamber is limited at how much fresh air and combustion air can enter it. If you lengthen the venting, you will be causing more restriction and there will not be enough natural air movement to make it work. It will start, run for a minute or two and poof out. Not to mention you will be circumventing it's UL rating and if you sell your home with it installed, you are liable for any fatality or damage. Do you want to risk that? Don't even think of doing it! There are "Box" heaters out there sized from about 5,000 Btu's on up to 100,000 Btu's. Check the web.
Posted on Sep 19, 2008
Therinnaiguy
  • 1420 Answers
SOURCE: Empire DV-35 low heat low flame
Check your gas pressure, You could have a gas valve problem or you could have a restriction in the air intake.
Posted on Sep 09, 2009
  • 79 Answers
SOURCE: empire wall heater with wall vent pilot light
It sounds like the gas valve is dropping out. Make sure the system is venting the exhaust(no restrictions). Then make sure all your wiring connections in the unit are tight. In a millivolt system if all wiring connections aren't tight and clean your circuit will drop in millivolts and the gas valve will drop out. The gas valve requires a certain millivolt to stay open. I hope I was of some assistance!! Good luck!!
Posted on Nov 29, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: DV-35 safety
The Empire DV units have been in production for over 25 years with very few problems and no class action suites. Although the heaters do get hot, so don't wood stoves, kitchen ranges, etc... I suppose they could put a sticker on the cover stating not to put anything on the heater, but I suppose it would burn off eventually. I would not worry about a statement of a faulty furnace because he/she would be fighting with a very large company with plenty of lawyers on the payroll. It should be expected that a heater will produce heat. If the tenant is concerned, remove the heater, install electric heat and let them pay the electric bill. I am sorry but your tenant needs to start using some common sense! There are no safeties built into this unit to detect when someone puts something flammable on it and I know of no heater that does. Remember, you did not make the heater, you did not spend thousands of dollars getting it tested and approval from UL, you may have purchased the heater and had it installed to provide a low cost alternative to other heating equipment but it is not you that is responsible for what has happened. If I were you I would hand deliver a note to each tenant who has this type of heater alerting them of the risk of damage if they left gloves, hats, buckets, etc.. on the heater and have them sign that they read it. The furnace is designed to be safe, burn clean and heat. Good luck.
Posted on Jan 19, 2010
So much air blowing in the pilot on DV-35-2SG heater won't stay lit
Unfortunately if its wall vented the wind can hit it just right and pop off the pilot this happens on older models a lot check your vent if its too much of an aggravation you may have to relocate it
Jan 17, 2013 | Empire DV-35 Heater
Empire heater is lite but wont come on
have you check the switch if it is break ?or maybe it has used for a long time .it was out of work .and couldn't discover .you should change a new one.
wall light
May 03, 2012 | Empire DV-35 Heater
EMPIRE MANUAL DV2353SG
I believe all the Empire manuals are there to download or read at their website: EmpireComfort.com.
Nov 08, 2011 | Empire Direct Vent Wall Furnace;...
I have a DV-55 direct vent... Blower kicks on for about 30 sec after it lights then goes of and continues to cycle this way then finally stays on
That is normal...especially if the air is pretty cool when it starts... the air cools the heat exchanger too much and it cycles till everything gets warm... nothing to worry about.. :-)
heatman101
Jan 15, 2011 | Empire Direct Vent Wall Furnace;...
Have an empire wall furnace. Natural gas. Vent through the wall. My problem is that sometimes when it ignites, it makes a loud boom and I can see a flame flash at the top of the heat exchanger. I was...
Not sure what the problem is, but mine does the same thing.It also blows the pilot light out when it does it..Had several service calls, no luck...POS, don't buy another Empire heater....
Nov 09, 2010 | Empire Hight Efficient Direct Vent Wall...
DV-35 safety
Jan 18, 2010 | Empire DV-35 Heater
Empire wall heater with wall vent pilot light
Nov 29, 2009 | Empire Direct Vent Wall Furnace Millivolt...
Sep 04, 2009 | Empire DV-35 Heater
Sep 17, 2008 | Empire DV-215 Direct Vent Natural Gas...
Empire DV-215 Low Flame Issue
Either a restriction in the gas train, low gas pressure or a bad gas valve. Check the pressure on the gas line when on pilot and again when the burners are running. Depending upon what type of gas it runs on, you should have at least 4" W.C. if Natural Gas and 10" W.C. if Propane. If gas pressures test good and all valves are open, you are looking at replacing the gas valve.
Dec 08, 2007 | Empire DV-215 Direct Vent Natural Gas...
Empire DV-35 Heater Logo
143 people viewed this question
Top Empire Heating & Cooling Experts
paulcarew
rudyjoe
Level 1 Expert
Dan Webster
Dan Webster
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
