Question about Toshiba Camileo H30 Hard Drive Camcorder
I have a Toshiba camileo H30 and it wont turn on with without the ac adapter pluged in.. its been charging for hours and still no effect.. any help on hiw to work out this problem
3 Suggested Answers
miket756
  • 2702 Answers
SOURCE: Charging continues to flash even
have you checked that the charger is charging the camera battery up?????
it could also be a dud camera battery,,if one cell is duff the hole battery wont charge up to its full volts so the charger works its **** off trying to charge up a dud battery till one day the charger just burns out as well?
Posted on Nov 27, 2010
ginko
  • 19396 Answers
SOURCE: I own a Toshiba Camileo
Hi.
The light stays yellow because you are using the USB charger. The USB charger is suitable for occasional use. You need to purchase a replacement charger. Here one of the forums from users with your same problem.
The Amperage of the USB charger is less than the DC charger. If the battery does not hold charge anymore, then the battery may also need replacing.
Here the charger and battery:
US:
CAMILEO Charger.
TOSHIBA CAMILEO H30 Battery
UK
Camileo H30 Charger
PX1657E-1BRS Battery
Regards.
Ginko
Posted on Mar 29, 2011
My Toshiba Camileo H30 won't focus or zoom by any means. Please help!
Does it have an auto focus switch?? Maybe u have it on manual so it always out of focus, well almost always.
Jul 21, 2015 | Toshiba Camileo H30 Digital Camcorder
Free download handy cam driver
Drivers
click the link, go to option 3 and type in camileo h30 camcorder
Jul 24, 2013 | Toshiba Camileo H30 Hard Drive Camcorder
Camileo p10 wont turn on or charge
I had a similar problem with the P10 not charging via USB, I purchased mine second hand so it came with no charger just a USB cable. I assumed it would charge by the USB cable but it did not, the red light flashes but doesn't charge. Luckily I have an external battery charger for a different camera i got some years ago that takes a similar battery , the P10 battery didn't fit properly so I had to place it at a 45 degree angle into the charger making sure the outer contacts were lined up properly and taped it into place. After an hour it was fully charged and the camera is working fine. The charger is a 4.2 volt charger. New external chargers can be picked up on ebay cheaply
Dec 18, 2012 | Toshiba Camileo P10 Flash Media Camcorder
My Toshiba Camileo x100 won't charge?
Try with normal USB cable &take out laptop USB port .actually I misplaced my ac adapter try for many solutions at I found this
Jul 02, 2012 | Toshiba Camileo X100 High Definition...
Toshiba Camileo H30 only records onto built in memory. When I put in an SD card, gives an error message (a yellow exclamation point inside a folder). Please help. The camera is brand new. Regards, AL
The first suggestion would be to check if the SD card is the correct one, and if it is correctly installed. On my Hi-Def Hard Drive Camcorder, when properly installed, the SD card looks like it's "up-side-down" - with the little metal sensors upward. It is easy to accidentally put it in - what seems to me is "right-side-up". Then I see an error message and need to flip it over.
You might also check to see if the metal sensors on the SD card are all intact. Sometimes one of the little metal sensors are slightly out of line or maybe bent.
May 15, 2011 | Toshiba Camileo H30 Hard Drive Camcorder
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
Charging continues to flash even after 3 hours of charging Toshiba camileo h30? Booklet said it should stop flashing when charged, but hasn't. Thanks in advance Paul
Nov 27, 2010 | Toshiba Camileo H30 Hard Drive Camcorder
Toshiba Laptop Wont Boot.
yes,if the battery doesn't charge with the ac adapter or turn on with it pluged in.it is common on comuters for the power adapter on the motherboard to go bad after a while.downfall of the laptop is that it is very hard to replace it(desktop easy because it is not built into the motherboard)you can either buy a new motherboard or a new laptop.if you got any more questions feel free to email me at gamecrazy944@yahoo.com
Aug 03, 2009 | Computers & Internet
My tablet is not pluging in
Toshiba computers have a label on the bottom that displays the exact voltage and minimum amperage required to power the computer ("DC15V 3.0A", for example, which means 15 volts DC (direct current), at 3.0 amps. Each Toshiba AC adapter has a label indicating its output voltage and amperage capacity (for example, "DC15V 3.0A"). Important considerations for using AC adapters with portable computers:
The connectors must be compatible -- they must mate together correctly.
The voltage level must match exactly (a computer designed to run from 15 volts can be powered only by an adapter rated to produce 15 volts). If the AC adapter's voltage is higher than the computer's requirement, the computer and the battery may be damaged, If the AC adapter's voltage is lower, the computer may not operate correctly, or not operate at all.
The AC adapter must supply at least enough amperage (current) to meet the computer's amperage requirement. Otherwise, the computer may not run properly, the battery may not charge correctly, or may charge very slowly.
The quality of the power (ripple, noise and other factors) provided by the AC adapter must be very high. AC adapters from other manufacturers may supply sufficient amperage at the correct voltage level but the quality of the power may be poor, which can cause the computer to operate erratically, and could even cause damage to the computer. Whenever possible, use the correct Toshiba AC adapter for your computer.
The computer's power light may blink to indicate that there's a problem with the power from the AC adapter.
Mar 25, 2008 | Computers & Internet
Toshiba Camileo H30 Hard Drive Camcorder Logo
688 people viewed this question
Top Toshiba Video Cameras Experts
Voros101
Are you a Toshiba Video Camera Expert? Answer questions, earn points and help others
