Question about Asrock P4I45GV R5 Motherboard
I read from a website that Inlet 845GV chipset based motherboard shall not support Double-sided x16 DDR SDRAM DIMM, is it true?
    Sergeant:
  • 223 Answers
Yes Mr.oktan Double-sided x16 DDR SDRAM DIMM is not supported.
It has Two 184-pin DDR SDRAM DIMM sockets so it support
- 2.5V unbuffered PC1600 (DDR200), PC2100 (DDR266) or PC2700 (DDR333) DDR SDRAM DIMM
- Supports maximum of 2GB system memory using 64Mbit,128Mbit, 256Mbit or 512Mbit technology.
Good luck ! if you think your problem solved don't forget to rate
Posted on Dec 31, 2010
Ram support for intel 845 motherboard
Hello. this website will show you the supported RAM for your Motherboard.
RAM Support
Hope this helps!
Apr 11, 2011 | Intel D845EPI (INTELKD845EPILPAK10)...
My System Model is : AWRDACPI Type : X86 base PC Processor type : Inter (R) Celeron (R) Speed : 2.00GHz Installed memory is 128 MB I do want to increase the physical mem, kindly tell me upto how much...
From the Intel spec sheet 4GB is supported:
The boards have four DIMM sockets and support the following memory features: • 2.5 V (only) DDR SDRAM DIMMs with gold-plated contacts • Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMS with x16 organization are not supported. • 4 GB maximum total system memory. Refer to Section 2.2.1 on page 55 for information on the total amount of addressable memory. • Minimum total system memory: 128 MB • Non-ECC DIMMs • Serial Presence Detect • DDR 400 MHz and DDR 333 MHz SDRAM DIMMs
If this answers your question, I'd appreciate 4 thumbs. I do this for fun and do not get paid.
Jim
Oct 05, 2010 | Intel D915GAG Socket 775 Motherboard -...
What ram compatible with intel845gv mother
Please find the details below:
  • 184-pin DIMM Banking: 2 (2 banks of 1)
  • Chipset: Intel 845GV
  • Error Detection Support: Non-ECC only
  • Max Component Density: 512Mb
  • Max Unbuffered DDR SDRAM: 2048MB
  • Module Types Supported: Unbuffered only
  • Supported DRAM Types: DDR SDRAM only
  • USB Support: 2.x Compliant
  • Thanks and regards,
    Anil.B.R
    Aug 17, 2010 | Intel Motherboard
    Will 1gb ddr2 800mhz ram support intel102ggc2
    The board has two 240-pin DIMM sockets and supports the following memory features:
    • 1.8 V (only) DDR2 SDRAM DIMMs with gold-plated contacts
    • Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMs with x16 organization are not supported.
    • 2 GB maximum total system memory
    • Non-ECC DIMMs
    • DDR2 533 or DDR2 400 SDRAM DIMMs
    Note
    To be fully compliant with all applicable DDR SDRAM memory specifications, the board should be populated with DIMMs that support the Serial Presence Detect (SPD) data structure. This allows the BIOS to read the SPD data and program the chipset to accurately configure memory settings for optimum performance. If non-SPD memory is installed, the BIOS will attempt to correctly configure the memory settings, but performance and reliability may be impacted or the DIMMs may not function under the determined frequency.
    May 27, 2010 | Intel D102GGC2 Motherboard
    What is the max ram Ican run with a 865pe neo2-p motherboard and
    Main Memory
    �� Supports bandwidth up to 3.2 GB/s (DDR 400) for single-channel mode and 6.
    4GB/s (DDR 400) for dual-channel mode (for 865PE only).
    �� Supports two (for 848P) / three (for 865PE) unbuffered DIMM of 2.5 Volt DDR
    SDRAM
    �� Supports up to 2GB (for 848P) / 3GB (for 865PE) memory size without ECC.
    �� Supports only x8, x16 DDR devices.
    �� Supports Dual-channel (for 865PE only) DDR 266/333/400 (based on DIMM 1.3).
    (For the updated supporting memory modules, please visit http://www.msi.com.tw/
    program/products/mainboard/mbd/pro_mbd_trp_list.php.)
    Regards.
    Apr 04, 2010 | MSI 865PE Neo2-V Motherboard
    Max RAM for Intel 102 GGC motherboard
    Thanks to Intel website The board has two 240-pin DIMM sockets and supports the following memory features: * 1.8 V (only) DDR2 SDRAM DIMMs with gold-plated contacts * Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMs with x16 organization are not supported. * 2 GB maximum total system memory * Minimum total system memory: 128 MB * Non-ECC DIMMs * Serial Presence Detect * DDR2 533 or DDR2 400 SDRAM DIMMs Note To be fully compliant with all applicable DDR SDRAM memory specifications, the board should be populated with DIMMs that support the Serial Presence Detect (SPD) data structure. This allows the BIOS to read the SPD data and program the chipset to accurately configure memory settings for optimum performance. If non-SPD memory is installed, the BIOS will attempt to correctly configure the memory settings, but performance and reliability may be impacted or the DIMMs may not function under the determined frequency.
    Jun 16, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
    My intel motherboard model no.is D845GVAD2 AND I WANT TO KNOW THAT HOW MUCH RAM IT SUPPORT
    That motherboard has 2 DIMM sockets. Each socket is capable of handling up to 1 Gb of 2.5V 184-pin DDR SDRAM DIMMs for a total of 2 Gb on the board. Please note that this board does not support double sided x16 DIMMs. Do NOT use ECC DIMMs on this board as it will cause damage.
    Jan 02, 2009 | Computers & Internet
    I have a 838gm gateway,Ive tried to install 4gb of ram ,when I install more than 2gb,it will not boot
    Gateway's website says this motherboard will support 4GB of DDR333 or DDR400 memory. I would suggest testing each memory modules by plugging it into the board by itself, then rebooting. This way you can catch a bad DIMM that might be causing problems. If each one checks out then start adding one module at a time, rebooting after each one. If it still stops booting after you add a module, you probably have a bad system board, and only now that you are adding the extra memory are you finding that out. If that is the case, try contacting Gateway support. Maybe they would be kind enough to cover repair under warranty.
    Nov 27, 2008 | Computers & Internet
    RAM cuantity
    The motherboard you mentioned supports DDR1 RAM.
    For windows xp and general application 512 MB is enough.
    But if you use memory intensive applications like image/video editing then you can opt for 1-2 GB RAM.
    Nov 24, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
    Upgrading RAM
    Yes that should not be a problem as DDR is backward compatible with the slower speeds so the faster RAM, will just slow down to match. These are the only conditions listed so as long as the stick you have doesn't fall under this criteria you should be good.
    he D845GLVA board provide the following memory features:
    • 2.5 V (only) 184-pin DDR SDRAM DIMMs with gold-plated contacts
    • Unbuffered single-sided or double-sided DIMMs
    • Maximum total system memory: 2 GB; minimum total system memory: 64 MB
    • DDR266/200 MHz SDRAM DIMMs only
    • Serial Presence Detect (SPD)
    CAUTION:
    Do not use ECC DIMMs with this board. Using ECC DIMMs could damage the board.
    Integrator's Notes:
    • Registered DIMMs are not supported.
    • Double-sided x16 DIMMs are not supported.
    • If a full-length PCI add-in card is installed in PCI bus connector 1 (the PCI bus connector closest to the processor), remove the add-in card before installing or upgrading memory to avoid interference with the memory retention mechanism.
    • This board has been designed to support DIMMs based on 512 Mbit technology for a maximum onboard capacity of up to 2 GB, but this technology has not been validated (currently validated up to 1.0 GB) on this board.
    Note:
    Enjoy the increase in RAM,
    Lee
    Jun 14, 2008 | Intel Desktop Board D845GLVA...
    Asrock P4I45GV R5 Motherboard Logo
    101 people viewed this question
    Top Asrock Computers & Internet Experts
    David
    David
    Computer Links
    Iqbal Husain
    Iqbal Husain
    Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
