Question about Frigidaire FGQ332ES Gas Dryer
Knocking sound when dryer runs. It sounds like it is coming from the top left corner of the dryer.
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
Check the paddles on the inside of the drum to see if one has come loose.
Posted on Dec 31, 2010
Dryer is clicking as the tub is spinning, sounds like is is coming from left front any hints on how to take off the top
Most dryer tops come off by releasing the clips at both front corners
Slip a 2" putty knife between the top and the front about 2" in from the end and push
The clip should release then do the other side and you should be able to rock the top upwards
Jan 18, 2011 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Dryer is knocking,on left rear side you can feel the knocking and when you press it knocks louder
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch.
Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt.
Remove the drum and belt and this will expose the drum rollers, idler arm
pulley and motor.
Now is a good time to check the belt to see the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go
to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots
or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably
only need lubrication. Lubricate the shaft of the rollers with a good grade
of machine oil such as 3 in One oil.
Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Dec 09, 2010 | Maytag Neptune MDE5500AY Electric Dryer
The dryer sounds like an unbalanced washer. Sound is coming from the front top left side. Machine diesn't move. does it even when empty. Began after was on for about 10 minutes.
Possible bad bearing for the drum front or maybe a drive belt with a missing segment that thumps with every revolution. You will need to open the top to inspect--either screws in the back edge of the top or insert a thin putty knife into the front corners to release a spring catch on each side. Hope this helps!
Oct 09, 2010 | Frigidaire GLEQ332A Electric Dryer
Knocking sound in upper left of refrigerator.
Yes, there is a ventilator (fan) for recirculating air. Looks like needs some maintenance (bearings regreased/oiled) or, if the worn is too high and blades are disbalanced, a new one.
Sep 11, 2017 | GE GSS25JEMCC Side by Side
THE DRYER IS MAKING A NOISE ON THE LEFT SIDE WHEN IT IS ON
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
uio4
Jun 03, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My dyer is making a rattling sound what is cause it to happen
Hi, It sounds like the blower wheel is bad. This is a common problem.
While the dryer is running, listen to the front lower left corner and see if you can pinpoinnt the noise area.
If this is the case, please let me know if I can assist you further.
Thanks
Vic
May 16, 2009 | Maytag PYE2300AY Electric Dryer
Ge dryer started making a loud rubbing sound
Sounds Like the drum is scraping. You can remove the drum and inspect the felt bearing/gasket for damage or a coin or screw that got lodged in it. You will need to remove Top and front in order to remove drum Carefully note the routing of the belt near the moter.
Jan 23, 2009 | GE DCSR483EA Electric Dryer
Knocking from driver's side rear of vehicle.
Does it sound like it's coming from the fuel tank?
Oct 07, 2008 | 2002 Jeep Grand Cherokee
Knocking sounds
Ususally knocking is a sign that the rubber belt which spins the dryer tub is old and has hardened. If the knocking sound gets quieter after you have run the dryer for 30 minutes or so, then the belt is the problem. As the dryer turns, it heats up the rubber belt and makes the belt more pliable. This quiets the knock. I have seen dryers work fine for years, knocking the whole time. Have the belt replaced if the sound bothers you.
Sep 07, 2007 | Maytag Atlantis MDG6400AW Gas Dryer
Frigidaire FGQ332ES Gas Dryer Logo
52 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
