Question about Dmm 1.5 HP Spa Pump: 2" in/out, Side Discharge, 48 Frame-120V
Pump hums but wont work, and over heats - Dmm 1.5 HP Spa Pump: 2" in/out, Side Discharge, 48 Frame-120V
    President:
  • Dmm Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
It could be the pump is bound up but it is more likely the motor is failing. It may be a small part such as the capacitor or the starting switch, but could also be more severe such as the winding itself. You will also want to examine the shaft where it passes thru the pump and motor and look for signs of rust from a pump seal leak.
If you are not familiar with testing these parts your best bet would be a local electric motor repair shop to see if the motor can be repaired or if it would need to be replaced. They should also be able to ensure there is no pump damage. If you wish to continue to try to repair it yourself please comment with any questions you have as you work thru the pump and motor.
If this answer does not fix your problem, please comment with additional details or contact me thru our site at www.arrowpools.net prior to rating the answer; I'll do what I can to help. Positive feedback is appreciated once your problem is solved!
Posted on Jan 01, 2011
When it is 20 degrees or less my heetpump outside unit hums high & low pulses is this normal, temp. is fine.
Heat pumps don't work when the temperature is at 20F. They run the best at about 40-50F. At 20F, the compressor doesn't come on and it switches to electric resistance heating. So you pay full price for your heat when it is that cold. The hum you hear is caused by the temperature sensor deciding whether to run the compressor or run the resistance heat. Twenty F is pretty much the cut off point where the heat pump loses it's fabled 300% efficiency (which actually happens at around 50F) At 20F the heat pump is very close to 100% efficient , so it makes no sense to get the wear and tear on the mechanics of the unit, so it switches to resistance heat which is also at 100% efficiency with no moving parts.
Feb 26, 2015 | Heating & Cooling
Heat pump compressor wont come on in heat mode, works fine in cool mode, we get heat occaisionally for about 2 min, then the compressor shuts off. it is a fridgedaire window unit.
Try setting the thermostat at a normal heat setting. By raising the temperature too high the unit thinks that the heat pump won't be effective and go into strip heat mode.
Nov 17, 2013 | Frigidaire Energy Star Room Air...
Motor wont crank and new fuel pump not humming. lights work.
HAVE THE BATTERY TESTED FIRST, NEVER IGNORE THE OBVIOUS.
Aug 31, 2012 | Cars & Trucks
Makes a humming noise wont heat
If its making a humming noise, that means the diode is bad and should be replaced. Once replaced the microwave will begin to heat again.
Feb 11, 2011 | Kenmore 62622 Microwave Oven
WONT RUN OR KICK ON HUMMING
Without more information, If you have a split system heat pump and hear humming from the indoor air handler, it generally means that the blower motor has failed.
Jan 30, 2011 | Heating & Cooling
Water will not drain humming noise
Humming sound could be jammed pump.Remove th filter and check pump Blades are free, nothing is stuck in it....
Nov 25, 2009 | Washing Machines
Pump just hums but wont start
Sounds like its frozen and causing a very heavy load on your circuit. If the motor gets hot within seconds, its shot and needs replacing. Have you attempted to turn the motor over by hand ?
Jun 22, 2009 | AO Smith SQ1202 Pool Pump Motor
Pump humming noise, wont turn
Yes you are correct...impeller is seized.
May 14, 2009 | Plumbing
My new Amana compressor Central Air-Heat Pump hums very loudly
When it hums, is it running? Or does it not run when it hums? I'm assuming it runs when you say you have to turn the therm off to get the noise off.. If it's humming and not running, you have big problemo friend..
Dec 02, 2008 | Amana PTH123B25AJ Heat Pump Air...
Dmm 1.5 HP Spa Pump: 2" in/out, Side Discharge, 48 Frame-120V Logo
48 people viewed this question
Top Dmm Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Dmm Pool and Spa Expert? Answer questions, earn points and help others
