Question about Moen 1 Handle LavatoryWith Drain Assembly - 64624 - N/A
Hello, i replaced the cartridge because we were haing trouble turning the water on. after i replaced the cartridge i had a drip. i took the cartridge back out and the larger oval shape washer broke off. i replaced it again but it still drips. any ideas what it could be. the faucet did not drip with the old cartridge. Nina
    Problem Solver:
  • 13 Answers
Try food safe silicone lubricant on tho o-rings.
NOT MUCH, just a small amount on your fingertip then apply on the o-rings.
you should feel the cartridge very snuggly go into place one lubbed.
if continues to leak, replace with a diff cart.
PS. You get what you pay for when it comes to replacement parts. Did you buy the after market type?
Hope this helps,
Mike.
Posted on Dec 31, 2010
Water dripping even when shower turned off
More than likely, the cartridge needs replaced. Most cartridges are fairly simple to replace; just remember to shut off water to the shower valve, prior to replacing the cartridge.
Oct 20, 2014 | Home
Replaced cartridge now only have hot water
You likely took out the anti-scald ring out when you took it apart and then put it in in a different spot preventing the handle from turning far enough. You may also have the cartridge or handle upsidedown.
Nov 25, 2013 | Price Pfister R897EBK Brushed Nickel...
Moen single handle faucet, when turning off the water it drips on the cold side
Sephie,
You have a very common problem. The short answer is you need to replace the Cartridge, which is Moen part # 1225.
I have seen that so many times with that particular faucet... I'm not a big fan of Moen in general-- but that aside.... That Faucet is one of their "economy" lines and has a long history of giving trouble. I would suggest to you that the best solution would be to replace the faucet with a nice quality Delta, or equivelant-- Delta style and those that use the same parts such as many Peerless and others ARE VERY SIMPLE TO SERVICE, and the PARTS ARE PRETTY CHEAP AND ALWAYS AVAILABLE at Lowe's or Home Depot. Moen cartridges are expensive and can be hard to find the exact match as there are many models that look almost identical. You can get the part free from Moen, but that takes time and can be a hassel.
Hope this helps, Let me know if you have further questions! Good Luck!
May 17, 2012 | Plumbing
Tap won't turn off
you have a bad cartridge...or bad seats and springs...shut off water pull cartridge and go to lowes or plumbing supply and get parts and replace...make sure hot is on left side before putting back...turn water back on...good luck
Jan 15, 2012 | Danze & Single Handle Tub And Shower...
My fridge is leaking because the drip pan is overflowing
I had this problem and it turns out that the filter cartridge had a leak and a constant drip into the drip pan. The drip pan is designed to capture the runoff from the self defrost but not a constant drip. The first thing you should do is remove your water filter cartridge - this will stop the drip until you can get a new cartridge. If that doesn't work just turn the water supply to the fridge off. You won't have ice but you won't have a leaky fridge either.
Aug 27, 2009 | Whirlpool ED2FHEXN Side by Side...
WATER DRIPPING FROM DISPENSER IN DOOR. GE Model TFX20JRBG WH
You are correct. this is actually a faulty inlet valve(dual) assembly. replacing this faulty valve will fix this issue.
Jun 19, 2009 | GE GSH25JFR Side by Side Refrigerator
Black text d not print
If the printer has been left for some weeks with an empty black cartridge then I suspect the print head is clogged.
To clean the print head, firstly remove it.
Remove each cartridge quickly and turn it upside down so ink does not drip out.
Flush warm water with a drop of detergent through the metal meshes at the bottom front inside of the print head unit. Continue untill the water coming out of the bottom of the print head is clear.
Then flush through with clean warm water for about 30secs.
Shake as much water as possible out of the unit.
Replace the cartridges quickly to avoid ink dripping out.
Undertake a nossle (head) clean on the printer until printing correctly.
Hope this helps.
Jul 20, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Brother DCP 130C not printing magenta and yellow
after replacing the ink cartridges it took several cleans to come good. I have no idea how to "manually" clean the heads. So I told the printer to do it many (about 7) times. It eventually worked
Aug 11, 2007 | Brother DCP 130C All-In-One InkJet Printer
Moen 1 Handle LavatoryWith Drain Assembly - 64624 - N/A Logo
96 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
