Question about Mitsubishi WS-65869 65" Rear Projection Television
I also have the timer light blinking and have attempted to power off and resetting with negative results. Any suggestions?
  • 57 Answers
It looks like your dm went bad, to get problem fix, you need remove the dm from the back of tv and open it , and replace the 7 caps in it. that should solve your problem, if need more help with your tv please feel free to call me at 602-810-7149 anytime.
Posted on Dec 31, 2010
  • evastv Jul 10, 2011
    Can you tell me where the DM is located in the Mitsubishi WS-65511? I've read that replacing the capacitors is fairly straightforward, but I don't know which of the shielded boards is the DM and I don't want to just start ranomly disconnecting things. Any help would be appreciated.
    Many thanks,
    Steve
I replaced the lamp in my Mitsubishi WD 52628 and the tv will still not come on and the lamp light still blinks
"Initialize" a "factory reset". Power on the tv, on the original remote, enter "MENU 1,2,3 ENTER". This will get you to the factory reset window. Initialize the default reset and you are fixed. Try this before ditching the set or tearing it apart. Good luck and post your results for everyone here with the blinking green timer light issue. Thanks.
Apr 25, 2012 | Mitsubishi WD-52628 52" Projection HDTV
When I attempt to turn on the TV the green power light will stay on for about 2 seconds. Did system reset with paperclip, timer light flashed for 1 minute. Tried again with same result.
STANDARD ANSWER FOR THIS PROBLEM:
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
BEFORE YOU RATE THIS INFORMATION LET ME KNOW WHAT YOU FIND, i AM HERE TOP HELP.
SD TECH
Jul 15, 2011 | Mitsubishi WS-55511 55" Rear Projection...
The TV worked fine last night, but today will not power on from either the remote or the front panel. When I remove and reapply AC power by unplugging the cord, the Power/Timer indicator light blinks...
hello am rico, it looks like you have bad lamp, or bad thermal sensor, go get and hold the buttons menu and input or device, it will blink and then pause and then will blink again check the blinking. like 2 pause 3 or 2 pause 2 for codes. if you need more help, feel free to call at anytime. 602-810-7149.
Jan 07, 2011 | Mitsubishi WD-52627 52" Television
Flashing green light
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
Blinking green timer light. Won't reset, I know there is a master reset of the DM board, it happened after I replaced the bulb and I found a blog that suggested a reset using the front keys in a sequence.
actually your TV resets everytime you unplugg it and the green light should blink for 70 seconds, if it does not stop blinking there is a problem with either the power supply or any part of the signal circuit. on the 62525 model I have had great success replacing the capacitors on the power supply, they will look swollen on top, usually the (4) 1000mf at 35volts , the power supply is on the left side when facing the back , Mitts uses a lot of screws and plugs, but if you are good at taking things apart you can attempt is and save the $300-400 a servicer will charge.
gd lk
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Aug 20, 2009 | Mitsubishi WD-62725 62" Rear Projection...
JVC tv i'art blinking timer
It is protecting you and itself with high probability.
Power supplies in modern electronic devices are designed to cycle if there is a fault in circuitry they are servicing and because of the design, also will not turn on completely if they are failing.
The older style of power supply was 'dumb' and unable to do this so could cause fires if the failure wasn't teh 'right' kind to blow the main fuse.
I agree with the manual; this is a job for a tech.
Aug 23, 2008 | JVC AV-32260 32" TV
Red power button & "lamp" indicator blinks
Having similar issue with my PT-44LCX65. Lamp blew and replaced it (last month), never figured out how to reset timer. Now red indicator light blinks once every 5 seconds and after about 4 minutes TV goes black.... Any ideas?
Dec 26, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Sep 22, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Open Questions:
See all Mitsubishi WS-65869 65" Rear Projection Television Questions
Mitsubishi WS-65869 65" Rear Projection Television Logo
55 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
