Question about Kenmore 24032\24036 Top Load Washer
My washer is an older one i think 1981 or 1980 its a Kenmore it leaves my clothes wet and soapy and win it goes on the spin cycle it will make a loud buzzing sound or it will make a loud banging sound and move everywhere. it also will have a burning rubber...
  • 784 Answers
Wow -- that is old. might be time to just go out and buy a new one. a new machine only costs about $350 to $425,,, the cost of a repair man to come out and fix this problem could be anywhere from $200 to $300 and up,, plus on a old machine such as this -- there is a chance that as soon as you fix one thing that something else breaks. sometimes new saves time and money.
oh' ,, and the problem sounds like the motor might be having trouble engaging the transition box.
c...
Posted on Dec 31, 2010
I own a Kenmore washer Model 110.22722100. The last couple of weeks, it leaves the clothes wet. It drains like it is supposed to and spins. What is causing this to happen?
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Here is the part you will need.
Nov 28, 2010 | Kenmore Washing Machines
Spinning cycle
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Mar 23, 2008 | LG WM-2277HW Front Load Washer
My Hotpoint Aqualtis washing machine leaves
the drain **** in the machine is partially clogged. my best guess is at the water pump. your washer needs to be serviced. call a serviceman..
Nov 15, 2009 | Washing Machines
Wet clothes
the reason the clothes are wet is the washer is not shifting to high spin,does the washer have a speed switch(normal wash spin,high wash spin)if its not the speed switch than the clutch is bad,how old is the washer?mike
Apr 19, 2009 | Kenmore 24032\24036 Top Load Washer
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer series 80, Clothes still soapy
If you are getting no water spray during the rinse cycle that would cause the soapy clothes issue.
Are you getting cold water during the wash/rinse cycles? If you have the machine set to warm/warm you may only be getting hot water while the final spin is calling for cold.
If you have cold water available then the timer is not calling for the water spray. The problem is either in the mixing valve or the timer.
Jan 10, 2009 | Kenmore 23822 Top Load Washer
Kenmore washer spin cycle doesn't leave clothes dry
SOUNDS LIKE THE TRANSMISSION IS NOT ALWAYS SHIFTING INTO HIGH SPEED MODE,TRY A MED. SIZE LOAD AND SEE WHAT THAT DOES,TRANSMISSION MIGHT JUST BE GETTING OLD WHIH IS NORMAL-MIKE
Dec 06, 2008 | Roper RAB2121KW Top Load Washer
Series 70 kenmore elite washing machine
If it goes through the complete cycle o.k. except for the slow spin then the motor itself needs to be checked.
Mar 20, 2008 | Kenmore 24622 Top Load Washer
Spinning cycle
usey only takes about 2 tbs soap ather than that bad main board make sure you have cold water going in washer
Feb 24, 2008 | LG WM-2277HW Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
55 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
