Question about Intel KD915GAGLBULK 915G LGA775 DDR VGA PCIe LAN mATX 10pack Motherboard
Problem in installing svga
After installing SVGA from my (drivers and utilities) CD, system gets hanged up,then i went in through safe mode and uninstalled my intel(r) game accelarator driver, after that my system working normally but i could not install this SVGA from my drivers cd... pls.give me a solution...
    President:
  • 2,351 Answers
Hi sackraj85, go to Intel's web site & download the drivers from Intel. Click this link to choose you're operating system.
(Intel D915GAGL MB).
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=1672&lang=eng
For Window Home & Pro click this link.
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=1672&OSFullName=Windows*+XP+Home+Edition&lang=eng&strOSs=45&submit=Go%21
If you find this is not the correct MB drivers please list the correct Intel MB model.
I did notice the model number KD915GAGLBULK above which is the Intel D915GAGL MB.
Luck!
Mike
Posted on Jul 09, 2008
I have a Hitachi CP-L500 LCD projector. It is connected to my laptop from the svga projector port to the svga port on the the laptop. It is making no signal connection. I have made sure the input button...
I am not familiar with your Hitachi LCD projector . However , I do have a little knowledge regarding video signals and inputs / outputs as well as connections . If your connecting cable is one piece (has no adapters added to either end of it ) I would believe your problem is simply a settings misconfiguration in your projector / computer , or both . First , access your startup BIOS / CMOS settings during the initial booting sequence in your computer by pressing F1 or whichever keys you press when you turn the computer on to access it . Then , in the advanced list , check your primary video input selection to be sure it is default. Then, once the computer is completely booted and you can click on your start selection , go to your video settings and check how to switch between internal and external display options . I say this because it is important that you are able to reroute your video signal to your SVGA Out from the laptop (for sure) and it is in fact in that video output mode. Once you're sure you have a signal going out of laptop through that port , go to your projector video input selections menu and select each and every input option available until the signal comes through . This will only work if you're absolutely 100% sure that your video signal is in fact leaving the laptop via the SVGA port connection .
Sep 05, 2010 | Computers & Internet
Manual de sony svga vpl-c57
I have the CD projector but i can
Jun 14, 2010 | Sony VPL CS6 Multimedia Projector
I can't change my screen resolution in the control panel and I can't find any drivers for a Compaq SVGA Color Monitor. All of my options are greyed out.
That sounds as though you only have the "Generic" drivers installed? Go to the Motherboard or Video Card manufacturers web site, and download the video drivers and install them, Then you will be able to adjust you setting. BTW, have you tried right click, desktop, choose properties, and adjust the slider, Or if vista display settings, or can't you do that?
Feb 26, 2010 | Compaq Refurbished PE1140 21 SVGA COLOR...
My Averatec 3225 HS starts with the Windows logo and then goes black
Most of the time there is a problem with your Video Card Drivers. They are either corrupt or the incorrect drivers for your card. Try the following steps to resolve the problem:
1. Boot your PC in Safe Mode(press F8 during bootup)
2. Once your system is up and running, change your Video Card Drivers to a default of VGA or sVGA and reboot again
3. If the System its booting up correctly this time, Locate the Video Card manufacturer on the Web and then try to find and install the correct drivers for your Video Card
B52computers
Dec 07, 2009 | Averatec 3200 Notebook
Can I change the Presario 1200-XL103 Laptop video mode from VGA
U just went to ur brand site.. and there u enquire about ur problem.
Sep 29, 2009 | Computers & Internet
I have just brought dell latitude e5500 laptop. i wanted to connected the hp officejet 5610 scanner to my laptop but am not able to do. please help
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab19
Jul 11, 2009 | HP Officejet 5610 All-In-One InkJet...
Windows 98 computer (drivers?)
1- Yes, you could install your CD. 2- www.download.com
Feb 26, 2008 | Dell Dimension 3000 PC Desktop
Out of range
maybe you have to boot your pc to enable vga mode and adjust the resolution to a smaller screen resolution...........
Feb 15, 2008 | GNR F153A (Black/Silver) 15" LCD Monitor
Intel KD915GAGLBULK 915G LGA775 DDR VGA PCIe LAN mATX 10pack Motherboard Logo
52 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
