Question about Asko 24 in. D3530FI Built-in Dishwasher
I received a second-hand as-is Akso D3530 (model #107353001) dishwasher. It washes perfectly fine, but at the end of the cycle, it keeps running. It does not seem to be the drain that is running, but rather the circulating pump. I have fully emptied the pan of water using a turkey baster and it keeps running. I also checked the float sensor in the bottom. The float sensor is not tripped, and when I manually trip it, the drain pump kicks on. If I enter the diagnostic menu and switch to "circ" it says 3.26V. Do you have any pointers on what to check next? Thanks.
2 Suggested Answers
ginko
  • 19396 Answers
SOURCE: I received a second-hand as-is
Hi.
The float switch is not a water level switch, but an overfill switch. The control board uses the input from the pressure sensor to decide when to stop the pump.
When you open the float switch circuit the machine 'thinks' that there is overfill and starts the pump. Door must be closed and othe conditions met.
The pressure sensor is sometimes difficult to test and gets replaced straight away. The part is not expensive.
You mentioned that you left a little bit of water inside the tub. Perform again testing with no water. A little bit of water may be detected wrongly by a malfunctioning pressure sensor. Ensure power is not connected if not necessary and ensure that you did a power reset by disconnecting appliance for a couple of minutes. Clean thoroughly the drain well and remove water from inside the tub completely.
At the end of the cycle this machines also check dryness and temperature. Check also dryness (humidity)sensor and thermostat.
Regards.
Ginko.
Posted on Jan 03, 2011
My top dishwasher drawer won't finish through the cycle. It runs fine on rinse only but not any of the wash cycles. It stops mid cycles, beeps like it has been paused, then tries to start again
Try to feel the temperature of water inside the dishwasher. If it is normal room temperature for the hot wash cycles then it is likely the heater is faulty.
It is not easy to replace unless you have good experience with repairing dishwashers.
Jan 17, 2013 | Fisher and Paykel 23 in. DD-603 Built-in...
Bosch dishwasher model shy56a05uc/14 door wont latch
I tried the various solutions on this site with no success. Finally I wedged it shut with a nice clear plastic door stop. Worked perfect (who cares if people think it looks funny, I am not hand washing and still am not out any extra dollars)
Jan 01, 2013 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
I have a Asko D3530 and the top basket isn't washing properly but in my menu section it doesn't come up upper basket wash anymore?? If someone could tell me how to get that option back that wo
Keep the Program button pressed until you see wash programs like Auto or Normal displayed. This should get rid of the Lower basket program.
Manual is available from here
Jun 27, 2012 | Asko 24 in. D3530 Stainless Steel...
Kenmore Dishwasher 587.15163401 knob stuck mid-cycle
See if it is stuck on a water heat cycle. if the heater circuit or the thermostat is not working properly it will continue to run looking for a rise in temperature. If these are in working order the timer it self could be sticking and not advancing.
Eric
Oct 23, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Asko dishwasher d3530. The water in the dishwasher is not hot.
Generally speaking, dishwashers don't heat cold water on their own. Be sure the dishwasher is connected to a hot water supply and that hot water is available to the dishwasher at the START of the cycle.
Often it takes hot water several seconds for house plumbing to deliver hot water to an outlet. If the dishwasher is connected to the kitchen hot water supply, run the water in the sink until the water runs hot before you start the dishwasher.
Dishwashers often have heaters to heat the water even hotter than most home water heaters, but they are not intended to heat cool or cold water. You MUST furnish hot water to the dishwasher from the time the cycle is started.
I've seen houses that take so long for hot water to reach a faucet, the dishwasher is already full (of cold water) before the first drop of hot water reaches it.
Good luck. Hope this helps.
Sep 11, 2009 | Asko 24 in. D3530FI Built-in Dishwasher
Not cleaning at all - most dishes end up being washed by hand afterwards
Hi there!
You've done the basics, so we'll treat it as a fault due to wear.
When running, do you hear the spray arms rotating - about twice a second?
If the water is actually reaching the dishes, bur the arms are not rotating, you may need replacement spray arms.
If the water is not even reaching the dishes with any force, The circulation pump may be faulty and needs replacement.
Hope this helps you.
Jun 17, 2008 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Dishwasher soap dispenser won't open during cycle
both have a wax motor on them that needs to be replaced you just remove the panel and replace the wax motor is what its called
Feb 16, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Not full cycle
Check the board for burned spots.
Dec 11, 2007 | Maytag 24 in. MDB5600A Jetclean II...
Asko 24 in. D3530FI Built-in Dishwasher Logo
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
