HI, I have a Sunbather solar heating system for my swimming pool (Model SCM). My temperature sensor for the solar tubing got pulled out by a someone and I am not sure where it was originally located. Where is the best location for me to place it.
  • 659 Answers
SOURCE: goodman a/c heating unit will not cut on.
The unit won't kick on if you have a float switch installed on the unit. The drip pan you are talking about, I think, is the emergency drain pain and you will find it sitting directly below the unit. It will be a big silver pan with pvc piping connected to it. If you turn the switch for the fan to on instead of auto, does the fan kick on? Do you have power to the unit? Have you manually reset the breaker to the unit? Are you getting an error code (flashing light) from the control board? Are there any lights on in the unit? If you can answer some of these questions, I can help you diagnose your unit correctly.
Posted on Apr 11, 2009
emissionwiz
  • 80417 Answers
SOURCE: coolant temperature sensor location for 1999 Dodge Durango
The sensor is right next to the heater hose outlet on the front passenger side of intake manifold. It is very small with an oval shaped connector going to it. I have the same engine.
Posted on Oct 21, 2008
MNfisherman
  • 11896 Answers
SOURCE: 97 Pontiac Sunfire - where is the temperature sensor located?
the coolant temp sensor is located: Under hood, driver side, upper engine area, below valve cover, mounted in cylinder head
Posted on May 05, 2009
SOURCE: swimming pool solar heater panels freeze problem
Depending on the manufacturer, your solar panels may be replaced under warranty. Our installer says that once the panels begin leaking, they tend to deteriorate fairly rapidly. For example, three leaks the first year, 7 leaks the second year, 30 leaks the third year.
Many solar panels are warrantied against freezing, but that is not likely to be the future of the warranties, because they inevitably DO freeze and leak.
If there are just a few leaks, it is easier to fix them - a Fafco Solar panel repair kit can usually be bought from your installer for about $25.00.
If you turned the pump on to manual to circulate the water through the panels, that should prevent a freeze - but will cost you the electrical cost to run the pump.
Our experience has been that it is better NOT to drain the panels - we had many fewer leaks the years we have not drained the panels, despite occasional hard freezes in our part of California.
In addition, your rooftop installation should help radiate some heat up to the panels to keep them from freezing.
Check your warranty and get the panels replaced if there are more than a few leaks.
Posted on May 07, 2009
SOURCE: where is the pressure switch located so i can replace it. lost my manual
open the lower front door, then up on underside of panel are two screws/hex head. Unscrew these two screws and the upper panel will slide down, may need a gentle nudge. Near the middle left your will recognize your pressure switch.....
Posted on May 20, 2009
Will a sfs1000/7 work with model 59025 solar heater?
The size of the pool and the size of the filter will play a role in the compatibility of your new swimming pool heat pump. We want to make sure that you have a swimming pool system that would be able to deliver the minimum gallons per minute of water that the new unit would need. We can check compatibility but we would need to know the size of the pool first. Please feel free to email us at splash@backyardocean.com so we can provide further assistance.
Jun 10, 2014 | Backyard Ocean SFS1000/7 Skimmer Pump
Air coming out of return holes in pool
You have a leak in one of your suction lines allowing air into the returns. Swim Time
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_156682b88afabb53
Feb 24, 2014 | Solar Heating System For Swimming Pools
Have a brand new AquaPro heat pump for our brand new swimming pool, It worked 3 days and quit. Is saying pool temp is 136 degrees
Thank youfor posting your question here on Fixya.com. It sounds like the water temperature sensor is faulty. I recommendyou call AquaPro Systems at 1-877-278-2797 and they should be able to help youfigure this issue out. I hope this helps.
Ifthis answer does not resolve your issue, please comment with additional informationbefore rating the answer. Positive feedback is especially appreciated once yourproblem is solved! Thank you.
Aug 24, 2011 | Aqua Pro Swimming Pool Heat Pump 125000...
I've a pentair solar control panel for my solar system for my pool. On one sunny and very warm day in California, the water in the pool remained cold after a few hours of circulation. Therefore, I was...
There are many variables to this......
How big is your pool how big is your solar system.
Solar temps don't rise quickly ever, and definitely not when the temp is only 75 outside.
You need 80-90 degrees or more on the roof to see quicker results, if the water temp is currently at 70 and it's 75 degrees outside and 80 on the roof you will barely get any change.
You will also lose the heat at night due to lower temperatures.
Once it's hotter outside and warmer at night you get the gains and keep them.
Hope this helps
Mar 24, 2017 | Fafco Deluxe Solar Panel Heating System 1...
Hello I have a Heatseeker SSv2 deluxe model which was installed 18months ago but has worked twice. It is now falshin erro 99 and I cannot find the instructions that can with it hope you can assist
99 error is the roof sensor. Instructions and troubleshooting can be found here: http://www.dontekelectronics.com.au/instructions/Trouble ShootingV2.pdf
Sep 11, 2010 | Solar Heating System For Swimming Pools
Ssv2 automatic controller panel is flashing 99 unable to change temp
A broken or disconnected roof sensor cable or open circuit sensor
Nov 09, 2009 | Solar Heating System For Swimming Pools
Have a supreme Solar - Solar conroller for swimming pool. Roof indicator light is flashing and system wont turn on, (not even in manual mode) Pump working OK though. What does this mean
it sounds like you have a problem with the air temperature sensor on the roof. either you have some damage to the wiring going to the sensor, or the sensor itself has gone bad. Also, check the wiring inside the control box, make sure the connections are tight. If possible, follow the wire from the control box all the way to the sensor. If the wire looks good and there is no damage at all, the sensor probably needs to be replaced.
Nov 08, 2009 | Solar Heating System For Swimming Pools
Heating & Cooling Logo
391 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
