Question about Mitsubishi WD-57732 Projection Television
I have a Mitsubishi WD-57732 Tv and it went out tonight. The screen is black but we can still hear the sound and it has a steady red light on. What can be wrong?
  • 57 Answers
Check lamp it looks like your lamp went out, and replace it, tv should be working again to normal.
Posted on Dec 31, 2010
Black screen
Sounds like you need to replace the lamp. An original Mitsubishi lamp will last 7 to 10000 hours. It's a no brainer to replace. Buy the lamp from Mitsubishi or a dealer. Do not buy one over the internet. Those are awful...
Dec 31, 2013 | Mitsubishi Televison & Video
How can you diagnose a failed lamp in a Mitsubishi DLP WD 52631
Remove the lamp and do a visual inspection.
If this is a DLP you may have a bad color wheel! whistling sound is a sign of color wheel.
Good luck to you
www.aaatvservice.com
May 08, 2012 | Mitsubishi TV Lamp 915P049010 for WD-52631...
Mitsubishi WD-62525 TV will not turn on
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it for a samsung ,it works like your mitusibishi:http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php The ballast has a sensor that detects when it's not able to power the lamp or if lamp is not responding,it will flash red when that sensor detects that.When you say: "it began to roll like the vertical and horizontal hold did not work then the sound went out" Do you mean you where getting horizontal lines? If you did that could be the Dmd.his is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Usually when there's a green light it could indicate a problem with the power supply,sometimes some capacitors do go bad. Check all of this and comment on this answer to see how it went.
Apr 08, 2010 | Mitsubishi WD-62525 62" Rear Projection...
I have a Mitsubishi WD-57732. The problem started
Lamp did not turn on at P-ON sequence
(No Lamp inserted)
(Disconnected cable between ballast and lamp)
(Lamp-Enable goes to DM but not to Ballast) It's related to the lamp.
Mar 26, 2010 | Mitsubishi WD-57732 Projection Television
Wd 57732 won't turn on, power/timer light blinks
probably something related to the FMT board. will need shop service.
Aug 30, 2009 | Mitsubishi WD-57732 Projection Television
Has Sound but no Picture and shuts down
I have the same tv and the same problem happened to me (Actualy twice). It turned out to be the color wheel motor. thats what the clicking noise is.
May 15, 2009 | Mitsubishi WD-57732 Projection Television
SCREEN IS BLACK
Called a service tech, (for free)
he said it was probably the lamp, and it was an easy fix.
Just have to order the lamp and put it in our selves.
I will let you know if it works or not.
We were told the lamp goes out anywhere between 1000 - 2000 hours.
So we will be needing the lamp regardless.
Sep 26, 2008 | Mitsubishi WD-57732 Projection Television
Mitsubishi WD-57732 Projection Television Logo
302 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
