Question about Sewing Machines
Elna Supermatic Needle wont move up
I have recently tried to use the Elna Supermatic. It is a fairly old sewing machine. I was sewing a normal straight stitch and decided to turn the foot pedal to fast rather than slow. I stopped and did this. When i started to sew again the needle went down but would not come back up. I wound the knob the wrong way to get the needle up. The needle will not move when the knob on the side is turned the right way. Any ideas?
Thanks!
  • shellie_bell Jul 09, 2008
    The needle will go up when you turn the handwheel the other way.
    Does this sewing machine need oil?
kimbo322
  • 10 Answers
SOURCE: Pfaff 7570 Sewing Slow
Unfortunately, this is most likely a computer board issue and there's just no way to predict if/when a board will go bad.
Your only option at this point is to take it to an authorized Pfaff dealer. If the person who serviced it was an authorized Pfaff tech, take it back to them. If not, do take it to a Pfaff dealer - non-Pfaff authorized techs are not trained on the machines.
Sorry I can't give you a simpler answer, but until this is corrected, your machine won't work properly.
Best,
Kim
Posted on May 04, 2008
SOURCE: Janome Memory Craft 9500 Troubleshooting
The solution that I found last night was the thread tension. I have never touched the dial, only had it set on 'auto." When I started playing with it, I realized the top thread should be really easy to pull through the machine and it wasn't. I started turning the dial (to 3 or 4) and the thread slid through the machine perfectly. No more birds nest! I really thought it was bobbin initially because of the horrible sound it was making.
Posted on Jun 05, 2008
SOURCE: Singer 626 Not sewing
First, give Mom all your Reese's Peanut Butter Cups.
Then, be sure the bobbin-winding function is not still engaged. Check it again, since on some machines, the mechanism has to be backed off until you hear a click, or until a light turns off. If that's done, check the tension on your top thread, since that's easier, then on your bobbin thread.
If the bobbin didn't get wound evenly (Like if you're hurrying) that will mess up its ability to let the thread flow out, so see if the thread on the bobbin looks as smooth as a new spool of thread.
I hope you got your costume together & had fun aside for that frustration. :^)
Posted on Nov 06, 2008
SOURCE: Elna 6003Q Sewing Machine won't snap out of bobbin winding mode
I had the same problem and fixed it myself. Remove the portion of the housing that coincides with the bobbin winder. You will need to remove two screws to do this--one is just to the upper left of the bobbin winder itself, and one is hidden under the handle on the left side of the machine (lift the handle, and look on the machine on the left side.) It takes some coaxing to remove the housing, but it can be done--be gentle. If you need to, remove the housing on the left side of the machine that covers the needle assembly. This will make it a bit easier, but still, be gentle.)
After removing the housing, you will see a black metal piece with a elongated slot and a screw adjacent to the bobbin winder mechanism. Unscrew the screw a turn or two, and slide the piece to the other side. Tighten gently. Turn your machine on, and move your bobbin winder back and forth and watch the screen change from bobbin winding to the main straight stitch screen. Now, do a brief Dance of Joy. I hope this helps.
Posted on Jan 23, 2009
  • 9 Answers
SOURCE: Kenmore sewing machine 385.1960180, problem with needle centering
That sounds like it's definitely an internal adjustment. The machine will need to be opened up and the left/right adjustment taken care of. Is this machine one that you can open the top easily, or is it the type that has the front and rear shell?
Posted on Feb 21, 2009
My Elna Supermatic only sews on slow speed now. Why?
It appears to be an older mechanical machine. Has a thorough cleaning and oiling been performed on it? These old machines need frequent oiling with fresh good quality sewing machine oil to keep them running smoothly. The fact that it is slowing down, indicates to me that the old oil has solidified and is sticking things. Continued use in its present state could burn up the motor.
Wheel on right side that controls the needle up and down is very tight...
It was working now it seems to be frozen the needle part wont move
Oct 23, 2016 | Elna Sewing Machines
Elna sewing machine is jammed or frozen needle does not go up or down
Sharon, I am not a sewing machine expert, but will post some links that may help you get your machine up and running. You can also google search your problem for a lot for info. on this issue. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My Needle is Stuck My Hand Wheel Won Move HELP It Just Sewing
HOW TO FIX YOUR SEWING MACHINE IN 5 EASY STEPS
Help me diagnose and fix problem with my sewing machine
Jul 29, 2016 | Elna Sewing Machines
The stitch length lever is stuck on my Elna Supermatic
the best solution for the sewing machine is to take the machine
to a sewing machine shop & have it serviced, to find out why it's
stuck in position A. that way you will know wether it's needs cleaning
& new oil & grease or if some part is damaged or not.
Jun 02, 2012 | Elna Sewing Machines
I HAVE A ELNA SEWING MACHINE MANUAL AND CAMS AND FOOTS TO FIT OF ELNA SEWING MACHINE BOUGHT 52 YEARS AGO UNFORTUNATLEY I DO NOT HAVE THE SEWING MACHINE I LEFT THAT WITH A REPAIRER HERE IN ADELAIDE AS IT...
I would love to take these off your hands as my Mum has an Elna Supermatic that was her mum's. Could you email me on cwrogers@tpg.com.au, I'd be happy to pay postage to ship, I'm up on the Gold Coast.
thanks
Carolyn
Mar 17, 2011 | Elna Sewing Machines
Where do you oil a machine the bobbin winder runs fine but the needle mechanism will hardly run
I have a Elna Supermatic 1954 sewing machine. What is the proper way to upperthread?
Aug 25, 2009 | Elna Sewing Machines
Extra discs for an vintage Elna Supermatic plus pressor feet.
Try the usual eBay route, but also approach any Sewing Repair shop as they often acquire odd bits from old machines....We had 9 disks for a lady with an Elna SU only last week, all from a machine traded 2 years ago and really beyond resale.
Aug 02, 2009 | Sewing Machines
Have a 1970's elna su supermatic but cams don't work
There are two types of discs - single and double.
For the thinner single discs do as follows:
1.Turn stitch width knob to "0"
2. Turn stitch length knob to "0"
3. Insert the single disc
4. Turn the top selector to "A"
5. Make sure the needle selector is in the centered position.
6. You may now choose any stitch length or width you wish. I usually try "3" for the width and 1/2 for the length to start.
For the thicker double discs do as follows:
3. Insert the double disc
6. You may now choose any stitch width.
7. The stitch length must be put on "A" - this is the difference between the single and double discs!
I hope this helps!
Mar 11, 2009 | Elna 1010
Wheel on old Elna Supermatic sew machine does not move the needle
you can buy "horseshoe" clips. Push your wheel back into position and put your own clip on. Should be an easy fix.
Aug 02, 2017 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
