Question about OKI Electric Industry B4545 Laser Printer
Error message: Service Call 980 - Fatal Error
    Champion:
  • 331 Answers
It means a call to OKI will be necessary. Typically, fatal errors are related to internal ROM, or board components that effect the boot process of the printer. When it can't boot - you get this type of message.
Posted on Dec 31, 2010
OKI C330dn Call Service fatal Error:980
That particular error indicates a fuser failure. Try turning off the printer and re-seating the fuser. If this does not clear the message then the fuser needs to be replaced. With such a low number of prints warranty should cover it.
Aug 29, 2014 | Oki Electric Industry C330dn Led Card...
OKI C5500
Error 980 means media clinging to the fuser,remove the fuser and see if there is something wrong in it
Jul 07, 2008 | OKI C5500n Printer
My printer model is OKI C5600n. On the displey stay message: Call services. 980:Fatal error. Where is a problem ? Whats is possible doing now?
Error 980 means that there is something stuck to the fuser. Check to see if there is something is stuck in the fuser. If you can't clean it out, then you will need to replace it.
Mar 22, 2011 | OKI C5500n Laser Printer
I had a piece of paper wrap around the fuser of my Oki C5650 printer. I have removed the paper (all of it.), but now it is displaying a 980 Fatal Error code. What do I do now?
I just had a service call with a 980 error. i removed the paper wrapped around the fuser roller but the error persisted. The only thing that cleared the error was to replace the fuser. I am not sure why but the fuser was shot after it had the paper wrap inside it.
There is no reset to clear the error. The only fix was to replace the fuser.
Aug 18, 2010 | Office Equipment & Supplies
Oki c 5600 980 fatal error
The error means that the media is wrapped around the heat roller of the fuser. The only way to reset this error is to replace the fuser unit.
Jul 20, 2009 | OKI C5500n Laser Printer
Fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
980-fatal-error
Service call 980:Error
Cause: Error by media clinging to the fuser
Error description: Media has clung to the fuser.
Solution: Power OFF. Replace the fuser unit.
Nov 19, 2008 | OKI C5800Ldn Led Printer
SERVICE CALL ? 980 ? Fatal Error
I was able to reset my Fatal Error 980 code on my C5800. There is only two wires coming from that connector and not four at the bottom of the fuser. That is pin 2 and 3. 4 and 5 is still the fuse but there are no wires there, just the 2 pins. What you have to do is make a fuse by connecting pin 4 and 5 together with a piece of wire and break the wire after a few seconds after powering up. This will reset the Fuser counter back to 100%. DO NOT DO THE NVRAM RESET, THAT WILL ERASE YOUR NETWORK FEATURE. Here is the step by step of what I did.
1)Take out the Fuser and lay the two blue levers flat and remove them.
2)remove the two silver screws and separate the casing.
3) Remove the two black screws from the connector at the bottom of the fuser closest to the edge.
4)Unravel and loosen the wires so you can pull that connector out a few inches so you can get a couple of wires in there. You will see what you need to loosen to get the connector out far enough, really easy.
5)Insert a wire into each of the two holes on the back of that connector. Its pretty simple to see where they go, 2 and 3 have wires going in, 4 and 5 dont which is the fuse. After you get the wires in the 2 holes, check for continuity from the end of the wires and the terminals if you can. Make sure the wires are long enough to hang out the case. Use the thinnest wires you can find.
6)Run the wires out of the case and put the case back together and put the fuser in. Twist the two wires together and power up the machine. As soon as you here the first motor,which is about 5 seconds, pull the wires apart and BAM, you just reset the fuser back to 100% and cleared the "980" Fatal Error. You could always put a miniature fastblow fuse in instead of using the wires but that would be tedious to me.Good luck
Jun 13, 2008 | OKI C5800Ldn Led Printer
980: Fatal Error
From the Service Manual:
*Service call
980:Error
*Error by media
*Media has clung to the fuser.
*Power OFF
Suggestion -
Before you replace the fuser, take it out and check for a piece of stuck label, paper, etc. You can spin the fuser roller by turning the gear on the side.
Apr 07, 2008 | OKI C5800Ldn Led Printer
OKI Electric Industry B4545 Laser Printer Logo
1,020 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
