Question about Electrolux Kitchen Ranges
I have a Electrolux EXC643 Oven. When you turn on the oven, set to 200 deg C for example, the oven fan and light works, but the oven stay's cold. The circuit breaker has not been tripped, at any point. Could this be the heating element has lost continuity? I would expect the circuit breaker to have tripped, if this was the problem. Any thoughts?
  • Anonymous Mar 25, 2014
    GLEFS77c power on get error e95 turn on oven and trips breaker
    E95 when powered on , trips breaker when oven is turned on.
    President:
  • 1,462 Answers
Circular element is almost certainly open circuit. often the breaker will trip when element goes faulty but not always. take rear cover off and check for continuity
Posted on Jul 08, 2008
My new oven electrolux EUEE63CS WILL NOT TURN OFF. display lights turn off but oven still going
My oven seems to turn off but the fan keeps working! Takes about 1hr for the fan to turn off after l have turned oven off. Is this normal? Im quite concerned. Will be calling help line monday morning......
Jul 28, 2011 | Electrolux 30" Built-In Double Electric...
My electrolux EOD 3360 bottom oven is getting too hot. The oven temperature light stays on even at the lowest setting or defrost setting. The inside of the oven is literally roasting hot, and anything I...
1 . If your ELECTROLUXfan oven is getting warm but takes a very long time to cook or is burning thefood more on one side than the other, then you need to check if your oven fan motor isworking you will see the blade turning fast if it is ok. if the element isheating but the fan motor is notblowing the heat into the oven then you need To replace the oven fan motor is alittle more expensive and a bit more involved.
2 . If you have the opposite problem i.e. your ovenis over heating and burning everything then you will need to replace your ELECTROLUXoven thermostat
3. A quite common and easily overlooked answer isif your ELECTROLUX oven is not working at all i.e. noheat and no fan then the chances are that someone has put the oven timer into AUTOmode, simply put oven back to MANUAL mode and all should be working again.
Mar 22, 2011 | Electrolux Ovens
Electrolux EOB5630X. Oven works fine for about 20-30mins then cuts out (light in oven turns off and grill will not work at this time either). Will work fine again after temp in oven cools but cuts out...
the electronics are heating up and cutting out.that cold be a bad clock assy. or there's a fan in there that could be bad or i've seen on some models there's a screen in where the fan is,it gets clogged with dust and the air can't blow to cool down the electronics.if it is the fan and you keep using it like that it will take out the computer board or clock assy. same part.
Nov 13, 2017 | Electrolux EOB5630 Ultrafan Electric...
New oven thermostat acting nuts
can't find our model with this model # .. i would try cking the wiring / making shure it's correct . normal orp when heating the light is on . not heating light is off . although the thermo is new it may be bad / or possible that it not the correct replacement . hope this helped **** ..
Dec 09, 2009 | General Electric JBS07M Range
Fan and light work, oven stays cold
one of three things are possible:either you are missing part of your 240volts at input power,or a bad neutral power wire to heating element,an oven temp control,or the thermocouple that controls oven temp
Aug 22, 2009 | Ovens
Electrolux double oven does not get hot
If it is a fan assisisted oven and the fan is still working, then you need a new oven element fitting.
Plz rate my solution.
Thanks.
Jan 11, 2009 | Electrolux EOU6330 Electric Double Oven
Oven not working
is this a gas oven or electric?
Oct 24, 2006 | Electrolux EOD5310 Electric Double Oven
Kitchen Ranges Logo
276 people viewed this question
Top Electrolux Kitchen Ranges Experts
Craig Butler
Craig Butler
Robert Plante
Andrew Taylor
Andrew Taylor
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
