Question about Philips 60PP9352 60" Rear Projection Television
Hello, My 55'' Mitsubishi Rear Projection TV's colors have been screwing up lately and has been getting worse. On the screen there are blue and now green streaks through the TV. It reflects the image and is very annoying. So I went into the settings and tried the Convergence Setttings and tried to move the blue lines back to nuetral, unable to though. So what could I do to fix this problem?
  • 57 Answers
Hello, you have a convergence problem. you need to replace the two stk, in the convergence board and check for bad fuses or resistors and replace them too, and your problem should be fix. if you need more help with your tv feel free to call me at anytime. 602-810-7149
Posted on Dec 31, 2010
The Color On My Mitsubishi Rear Projection Tv model- WS-55908 looks to be off, picture looks blue and Yellow.
its sounds like the convergence on your TV needs to be adjusted. (this adjusts all of the color guns in the back of the tv to line them up again, when they get off, you start to get yellow blue or red halos around objects in the picture. In the setup menu on your TV under picture or Display there will be an item that says "convergence" follow the instructions in there so all the crosses on the screen no longer have colored halos anymore.
Mar 10, 2011 | Mitsubishi WS-55908 55" Rear Projection...
I have a 55 inch rear projection mitsubishi tv. it recently has started showing what looks to be white spots when viewed at a distance on a dark screen. when you look at it closely it actually is red green...
It is called Convergence. You have three CRTs. Red, blue, Green. When they are not aligned, you will see the individual colors. See if you can do some alignment in the users menu. Look for Converge or Convergence in the menu. Either under video or setup.
Mar 09, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Color loss on mitsubishi 73" medallion hd1080
TRake the fron grill off and the front board 6- screws on my 65inch there are three adjustment knobs one of them wil adjust the huge
one the whole screen,if not that,I have heard mold growing on and the inside of the blue bulb because it runs the coolest out of the three.
Jan 31, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Cobwebs behind the screen of a 55" projection screen. How do I remove screen to clean the TV? I have a Mitisubishi WS-55809.
Hello morsec,
You will need to remove the screws on the back of the top half of the TV set. This will allow you to remove the top rear half of the TV and give you access to the screen. Make sure you do not break the mirror that is attached to the rear of the TV set. Clean the screen with a damp non-abrasive cloth dry with a dry non-abrasive cloth. When finish replace the back of the TV and tighten the screws to hand tightness.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jan 15, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Color out of convergence.
Good Day;
Sounds like the CONVERGENCE IC has failed >STK-110 > 267P155010. TV only Uses one.
Good Luck, big IRISH.
Aug 31, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Screen is blue
the problem will either fix itself out or the screen will go. chances are one color goes then the next and then its toast but can go after blue as well.
Aug 06, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Sound no picture
Try resoldering the vertical output IC this is acommon problem with this model
Mar 20, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi WS-55311
check the error codes to see what's wrong, do this by search threads here or at ctechnicians.com
Dec 31, 2007 | Mitsubishi WS-55311 55" Rear Projection...
Onscreen menu appears greenish
call tech and suggest to balance your screens ..they will know the procedure.
Nov 02, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Color sag on mitsubishi ws-55909 projection tv
Adjust convergents for blue.This is done with your remote control. go into menu, setup, instructions will come up on screen, also in manual.
Feb 04, 2007 | Mitsubishi WS-55909 55" Rear Projection...
Philips 60PP9352 60" Rear Projection Television Logo
49 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
