Blown channel in fisher ca-870A stereo amp - Audio Players & Recorders
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: when i got the fisher home stereo ca-9025 very little sound
Thin wire will not cause audible change to the sound. Can you describe the problem better?
Posted on Jan 01, 2010
Front left channel on FISHER tad-9925 broken
Chances are that all you have to do is replace STK 411-230E.
Jul 10, 2017 | Fisher Audio Players & Recorders
Do you have a owners manual for a fisher CA-276 stereo amp?
The owners manual can be found here :
http://www.hifiengine.com/manual_library/fisher/ca-276.shtml
Aug 30, 2014 | Audio Players & Recorders
2010 VW CC factory stereo amp popping sound
If the amplifier itself is making the popping sound I suggest you disconnect it immediately, as it could be an electrical short within the amp. If the popping sound is actually coming from the speakers, it could be due to a crossed wire, blown amp channel, or blown speaker. If you posses the technical know-how, you can test the amp channel and speaker by connecting a different speaker to the channel responsible for the popping sound. If the new speaker makes the same popping noise then it is most likely a blown channel. I hope this helps =)
Sep 24, 2013 | JVC AM FM CD DET FACE CAR STEREO
HI I have fisher integrated stereo amplifier model CA-885, it was totallydamaged.I would like to by new one will you please help me. gasim
Hi, I came across this model amplifier in a Goodwill today - was checking online about specs (which is how i found your post) to see if it was worth purchasing and reselling. If you're still interested please drop me a note directly at jtimleck &&**##_at_%%$#@mac *&^ dawt calm
Oct 15, 2010 | Audio Players & Recorders
When i got the fisher home stereo ca-9025 very little sound
Lets try the simple stuff first. Check to be sure that the tape monitor switch is not engaged. Since youare getting some sound, it appears that the signal path is being interrupted. It is possible that the output transistors have failed (open), but that is extremely rare. Check the tape monitor switch and update this with your results.
Thanks,
Dan
Dec 31, 2009 | Audio Players & Recorders
I have a Fisher RS-717 stereo receiver, amplifier. The speaker connections are channel A left & right and channel B left & right. The question is, can you connect speakers to just one channel...
Yes you can use either A or B without a problem. The restriction is when you have both A & B connected. In that case, the speakers MUST be a minimum of 8 Ohm impedence. Using either A or B, you can use speakers of 4 Ohms impedence.
Dan
Nov 24, 2009 | Fisher Audio Players & Recorders
Fisher Stereo Intergrated Amplifier CA 9025 is stuck on standby
just bought a ca-275 that i cant seen to get any sound to come out of. but im also testing it with car speakers. is this my culprit
Oct 14, 2009 | Fisher Audio Players & Recorders
RE: Fisher Model CA-270 - 480 watts.
These units use amp-pacs for the output stage, if I remember correctly. All in all, the unit will require some diagnosis to determine the problem with the power supply and the final output stage. The total cost of repair easily could exceed $125. You can probably replace the unit with a better one for not much more.
If you would still like this unit repaired, please indicate where you are in the country and I'll try to find a shop for you.
Dan
Aug 12, 2009 | Audio Players & Recorders
101 people viewed this question
 Grubhead
Grubhead
