Have no sound how do i get my sound back - Computers & Internet
  • 374 Answers
First we have to determine whether or not you have the required drivers installed in order for the operating system to communicate with your sound playback device. Following is the keyin sequence for Windows XP - The key-ins will differ somewhat for other Windows operating systems:
Click on START
Right Click on MY COMPUTER
Tnen click on PROPERTIES followed by HARDWARE and then DEVICE MANAGER.
Double click on SOUND, VIDEO and GAME CONTROLLERS
Your sound playback device (such as Avance AC 97 Audio) should be listed. And there should NOT be a yellow exclamation mark in the left margin (If there is, this is an indication that the device is not working properly - see CORRECTIVE ACTIONS below.
Double click on your sound playback device.
In the device status box you should see the statement "This device is working properly"
If you get any other messages indicating that drivers are required or need to be updated, see CORRECTIVE ACTIONS below.
If everything look OK, click on the "X" in the upper right corner to close device manager.
If everything was OK in device manager we will now see if the operating systen is sending sound to your playback device.
Click on START
Click on CONTROL PANEL
Select the Classic View (If not already displayed)
Click on SOUNDS AND AUDIO DEVICES
Double Click on AUDIO DEVICES
Click on the AUDIO tab.
In the Sound Playback dialog box your sound device (something like "AC 97 Audio") should be listed. If it is not, click on the pull-down menu and select it if you can..
If it is NOT listed, see CORRECTIVE ACTIONS below.
If it is listed, perform the following tests:
Click on the SOUNDS tab
Set the Sound Scheme to WINDOWS DEFAULT
Click on APPLY and OK
In the Program Events dialog box, click on any event that has a speaker Icon to the left of it
Underneath the Program Events dialog box you will see a small box with a triangle inside
If the triangle is black that means that the operating system has recognized your sound playback device (sound card).
Click on the triangle.
You should hear the sound through your speakers (the triangle will change to a rectangle while the sound is playing)
After the sound plays the black triangle will re-appear.
If the triangle is black and changes to a rectangle when you click on it and you DO NOT hear sound through your speakers either your speakers are plugged into the wrong jack or you have a problem with your speakers. Test or replace the speakers.
If the triange is gray that means that the operating system does not recognize your sound playback device (sound card). See CORRECTIVE ACTIONS below.
CORRECTIVE ACTIONS
If the playback device is built into the motherboard, the device may not be enabled in the BIOS. Check your BIOS settings. If your sound device is disabled, enable it and repeat this procedure.
To enter BIOS setup turn on your PC and immeadiately hold down the DEL key. (On some machines it's the F!, F2 or F10 key).
Once in BIOS setup, press the Enter key to select the first display screen, ususally titled "Standard CMOS Features". Navigate through the menus until you locate the setting for your on-board sound playback device. If it is set to "Enable" or "Auto" leave it as-is. If it is set to "Disabled." change the setting to "Enabled" or "Auto".
Follow the on-screen instructins to save yur settings and exit BIOS Setup.
If you do not have built-in sound on your motherboard you will need a sound card installed in an expansion slot on the motherboard. This card may not be present. If there is no sound card, install one and then repeat this procedure.
If you do have a playback device installed and enabled and either you have an error indication, drivers are not installed, or device manager reccommends a driver update, you will have to download drivers from either the motherboard or sound card manufacturer's web site. Also, if the drivers are installed and you no have no error messages, but you do not hear sound when you click the black triangle, you may have a hardware problem on your motherboard or sound card.. At this point, you will require some help from a qualified PC technician.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please return to the FixYa website and rate my response to your question.
Best regards,
Yavacotech
Posted on Dec 31, 2010
My Vivo ptv42hda tv makes a clicking sound when switched on but screen won't turn on how can I please fix the problem myself thanks as I'm good with electronics
do you have back light or not? and do you have sound or not?
if back light comes on and sound on but still no picture.. problem is in T-Con PCB.
if no back light.. but sound ok.. problem in back light.
Jun 02, 2013 | Televison & Video
No Picture now No Sound
main board faulty check tuner poss dry joints
Nov 22, 2012 | LG 37LC7D 37 in. LCD HDTV
Sound becomes distorted after changing channel requiring pushing mute button and back to sound again to restore proper sound
Tries tv unplug,replug it back like about an hour.By letting the tv by resetting itself back to the factory setting.Now goto the tv menu goto Audio Setting,go down to do resetting,so resetting the tv Tuner board for resetting sound,setting back to factory setting.This should solved ur sound problems.
Jan 30, 2011 | Vizio M370VT 37 in. LCD TV
Pop sound tv went black, went off then back on had sound but no picture, I turned it off and it turned its self back on at this time no picture and no sound. I unplugged tv and when I plugged it back in it...
An electrolytic capacitor has gone bad in you high voltage section of your TV or the high voltage oscilater has gone failed please have tech check and replace
Aug 13, 2010 | Samsung DLP HL-P5663W 56" TV
ACER SOUND DRIVER(ACER LAPTOP 4310 MODEL
i want aspire 4310 series sound driver so can u help me?
Aug 01, 2008 | Acer Aspire 3004WLCi Notebook
No sound on my 8year old panasonic tv.
It worked fine yesterday. Sound on all channels. Sometimes the picture goes black on channel 6. We can get it back by going up one channel, then back to 6. it is due to cable signal ie weak. now there is no sound this is due to sound section 1 loose connect in sound section 2 speaker 3 problem in sound section some part must have failed.
Sep 17, 2007 | Panasonic CT-32SX12 32" TV
No sound at all no DVD,no FM, no sound at all
I just had exactly the same problem. Tried your trick of unplugging and plugging the power back. The sound did come back. Hopefully it will last. Thanks!
Apr 01, 2007 | JVC TH-M505 System
Playback movie pictures or sound
Movie pictures can be played back with the camera, but not sound. However, when the camera is connected to a TV, both movie pictures and sound can be played back. For playing back movie pictures or sound on a PC, the QuickTime™ 4 is required.
Sep 01, 2005 | Olympus Camedia C-3030 Zoom Digital Camera
Sep 01, 2005 | Olympus C-3000 Zoom Digital Camera
Computers & Internet Logo
623 people viewed this question
David Payne
David Payne
