What kg capacity is the Hitachi 1220p - Washing Machines
What is the towing capacity of a 1992 automatic Nissan patrol station wagon Y60 4.2 petrol?
Rated Towing Capacity†
Trailer with brakes (kg) manual/automatic 3200/2500
Trailer without brakes (kg) 750
Towball download (kg) See table
Gross front axle capacity (kg) 1500
Gross rear axle capacity (kg) 1800
http://m.nissan.com.au/~/media/Files/Brochures/Specifications/Y61_Patrol_Specification.ashx
Nov 30, 2016 | Nissan Cars & Trucks
What is the GCWR rating for a 2015 Jeep Grand Cherokee? That is the combined weight of car & trailer that it can handle.
in the operators guide, and on drivers door jamb.
can vary by uSA car or export, so, your looking , wins, first.
Mar 28, 2015 | 2015 Jeep Grand Cherokee
Hitachi paf 1220p washing machine
Uneven Load or try check it out for something stuck inside washer drum or tub or inside pump or loose or broken parts
May 21, 2014 | Washing Machines
What is the air pressure for shocks on a 97 flhtc
I do not know but you could call a Harley Service department or better go there in person and ask.
Recommended Suspension Air Pressure: FLHX, FLTRX, FLHR/C
Solo rider up to 150 LB up to 68KG10-20 0 psi0kPa
Solo rider up to 150-200 LBup to 68-91 KG0-10 psi0-69kPa
Solo rider up to 200-250LBup to 91-113KG10-20 psi69-138kPa
Solo rider up to 250-300LBup to 113-136 KG20-30 psi138-206kPa
Solo rider up to over 300LBup toover 136KG30-50 psi206-345kPa
Solo rider with capacity luggage of 40 lbs (18 kg) up to 150LB up to 68KG 10-20 psi 69-138kPa
Solo rider with capacity luggage of 40 lbs (18 kg) up to 150-200 LB up to 68-91 KG 20-30 psi 138-206kPa
Solo rider with capacity luggage of 40 lbs (18 kg) up to 200-250 LB up to 91-113KG 30-40 psi 206-276kPa
Solo rider with capacity luggage of 40 lbs (18 kg) up to 250-300LB up to 113-136 40-50 psi 276-345 kPa
Solo rider with capacity luggage of 40 lbs (18 kg) up to over 300LB up to over 136KG 50 psi 345 kPa
Rider plus passenger ALLWeights 40-50psi 276-345 kPa
Maximum GVWR ALL Weights 50psi 345 kPa
If Tour-Pak is installed, add 5-10 psi (34-69 kPa) to shock pressure.
Do not exceed 50 psi (345 kPa) suspension pressure.
Apr 17, 2014 | 2001 Harley Davidson FLHT Electra Glide...
I need a manual for a Hitachi PAF-1220P i dont understand the s when going throught the wash cycle there does not appear to have a rinse mode. thank you
Reply to rutledge5135 on Apr 11, 2011
(i need a manual for a Hitachi PAF-1220P i dont understand the s when going throught the wash cycle there does not appear to have a rinse mode. thank you)...
The 'S' is for 'Spray' which happens at the beginning of the Spin Cycle...it then goes on to rinse etc.
regards, avery.phill@gmail.com
Apr 11, 2011 | Hoover Washing Machines
To whom it may concern hello I have bosch washing machine was32794 , 1-can I use bleach?may be it damage the machine? 2-how can I distinguish the weight of cloths is more than the capacity of machine?...
Yes, you can use bleach -- about 1/2 cup oer load -- or more if specified in owner's manual.
The machine could handle easily one full laundry basket -- see below.
  • Capacity of typical Laundry Basket = 6 kg (dry weight)
Calculation: [(36 cm x 51 cm x 26 cm) / 28317 cubic cm] x 3.5 kg = 5.9 kg
Charlie
Feb 23, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Online repair manual for hitachi washing machine moel PAF-1220P
machine does not want to turn during wash cycle and smells like it's burning out motor... drain and spin still work fine.. any idea what is going on? thanks..
Sep 14, 2010 | Washing Machines
White-Westinghouse model la450mxw1 top load capacity in Kg.
I called Frigidaire technical support, they informed me that the capacity is 2.7 c/feet.
Nov 26, 2008 | Westinghouse WWS833ES Super Capacity Top...
INSTALL AN UMAX ASTRA 1220P TO AN USB PORT ON A LAPTOP USING XP
The 1220P (P = Parallel) does not have a USB port and Windows XP does not support it.
Jun 16, 2008 | Umax Astra 1220P Flatbed Scanner
Umax astra 1220p for xp
I need the driver for Umax astra 122OP Scanner!
Nov 12, 2007 | Umax Astra 1220P Flatbed Scanner
Washing Machines Logo
221 people viewed this question
Top Washing Machines Experts
