Question about Danby DDW497W 22 in. Countertop Dishwasher
On the front of the door .bottom right hand corner there is a small amount of water coming out.when in use.
  • 784 Answers
Sounds like the seal is not sealing properly. check to see if there is any debris along the seal -- or any cracks in the rubber seal.
c...
Posted on Dec 31, 2010
Mt front load duet whirlpool is locked full of water
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a kenmore upright freezer model #253.9266411 there is a gap in the upper left side does anyone know how to adjust the door? The seal is fine
I'm assuming you don't want to replace the door seal. Open the freezer door. Stand "inside" the open door and place your foot at the right bottom corner (looking from the inside). Place your hand in the top right corner and pull it very slightly toward you. Do this in small amounts until the gap closes making sure you don't open one at the bottom.
An alternate method is to warm the gapped section of the door seal with a hair dryer to soften the rubber enough to allow the magnet within the rubber to pull the seal gap closed. This has worked for me numerous times by making small adjustments at a time. Good Luck
Sep 02, 2009 | Kenmore Freezers
Sub zero 550 (14 years old) has a small but steady leak onto floor from freezer compartment. Small amount of frost buildup on inside of door. Food is frozen and the door "appears" to seal we
Right hand side wall in the freezer - take a look- any frozen water or moisture? Need check a drain line, usually defrost heater inside the freezer wall getting bad and draining water just freezing inside of it.
May 10, 2009 | Sub-Zero Bottom Freezer Refrigerator
Will not seal. new from sears.
The description below is for a gap at the top of the door. Adjust the procedure for gap at bottom by "twisting" the door in the opposite direction.
May 06, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Water dripping from the front bottom front panel
It is possible that you may be using to much liquid soap...if that is what you are using ...this tends to foam up...and will leak out around the door....also drying agents will do the same ...if some is spilled into the inside wipe it up before stating the cycle...another issue could be the round float at the front right (usually) of the DW...this can stick sometimes allowing to much water in.....see if it is gunked up and if so clean it out it should move up and down freely...and make a clicking noise also. You could also a piece of food or debris blocking the door from properly sealing.
I hope this helps...good luck and good day...please rate my effort ...The Fang
Mar 08, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Door staying locked
what happen s if you advance the washer too a drain cycle will it drain out the water???perahps its locked from too much water in unit and for safety/flood reasons it will not open. there is a manual release, if hte water level is down to a respectable amount,andto access it youll need to remove the front panel (3s\ screws across the very bottom of the front of the machine) after teh front access panel is removed, you can stick youre hand up the right hand side (where the lock/latch mechanism is) and youll feel a quarter sized plastic tab protruding form hte bottom of the latch assy, simply pull down on it and it will unlock your door for you. reomve the power cord first!!!!
Dec 08, 2008 | Kenmore Washing Machines
Danby DDW497W 22 in. Countertop Dishwasher Logo
126 people viewed this question
Top Danby Dishwashers Experts
Kevin Getz
Kevin Getz
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
