Question about Brother MFC-260C All-In-One InkJet Printer
Unable to clean 46 - Brother MFC-260C All-In-One InkJet Printer
  • 1,218 Answers
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the "up arrow" key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Posted on Dec 31, 2010
whitebirch
  • 433 Answers
SOURCE: clean unable 46
You need a new ink absorber box which can be purchased from a brother service partner near your home.
www.brother.com
If you have got the spare part (ink absorber box) you have to open the printer:
Do NOT clean the old one! It cant be cleaned: The felt wont take up ink anymore and will stain the machine from inside and the furniture beneath the printer.
After replacing the eeprom of the printer needs reset:
(dcp: use arrow-up and set key to choose the digits. e.g. arrow-up til 8 then set arrow up til 0 then set
mfc: use the fax-number keys.
Stop-button will always go back to maintenance, if you have done wrong)
press menu then start bk-copy then fourtimes arrow up quickly after another.
machine will switch to maintenance mode and light(s) will flash.
press 8 0
press start bk-copy until PURGE 64xx
press 2 7 8 3
Purgecount will be 0000
Press stop
press 9 9 to leave the maintenance mode.
After the mfc/dcp comes up again in normal state the error has disappeared
Posted on May 14, 2009
Mix-it-up
  • 832 Answers
SOURCE: clean unable 46 : what does it mean ?
...because you have run the cleaning cycles too much, the waist inktank is fed up! needs replacing. contact brother hotline or try to get one from a service partner which can be found on the brother homepage of your country.
Posted on Feb 10, 2008
same
Posted on Apr 14, 2008
  • 13 Answers
SOURCE: unable to clean 46
Unable to Clean or Machine Error 46 means your purge counter is already full. Please refer below for the instructions on troubleshooting your machine.
1. To enter MAINTENANCE Mode: Press MENU, MONO START, 4X on ARROW UP. (within 2 seconds).
2. Using arrow up button look for the following:
a. 8 then press SET or OK
b. 0 then press SET or OK
3. Using MONO START, just press it until the word "PURGE XXXXX" comes out.
4. Using arrow up button look for the following:
a. 2 then press SET or OK
b. 7 then press SET or OK
b. 3 then press SET or OK
This is to reset the purge counter. Then press stop
5. Using arrow up button look for the following:
a. 0 then press SET or OK
b. 1 then press SET or OK (To reset unit)
a. 9 then press SET or OK
b. 9 then press SET or OK (To exit Maintenance mode)
Posted on Jan 21, 2010
Brother 165 Printer is flashing "Clean Unable 46- Refer to Troubleshooting & routine maintenance in user's guide". I went to user's guide and cleaned all the parts inside the printer. Still flashing message. How can i clear ????
Posted on May 14, 2010
Printer is flashing "Clean Unable 46- Refer to Troubleshooting & routine maintenance in user's guide" BROTHER DCP-135C
printer is flashing "CLEAN UNABLE REFER TO 46- TROUBLESHOOTING AND ROUTINE MAINTENANCE IN USER'S GUIDE..BROTHER 2480C
Feb 23, 2013 | Brother Multi-Function Center MFC-3360c...
DCP-165C Compact Colour Inkjet Multifunction Printer: in brother dcp 165 printer the error message clean...
brother dcp-165c printer unable to clean , see troubleshooting and routine maintenance chapter in User's guide
May 16, 2010 | Brother DCP 165C Compact Color Inkjet...
Unable to clean error 46
i have brother dcp 6690cw and it said unable clean 46 i want solution for this
thank you so much
Apr 14, 2010 | Brother MFC 6490CW InkJet Printer
Clean unable 46, See Trouble shooting and routine maintenance chapter in User's Guide.
Hi there. . . okay . . . Follow this step
1.) Unplug your printer.
2.) Plug your printer again while holding the menu button 15 sec.
3.) select 8 by using the arrow buttons ,push OK and select 0 and push OK
4.) then numbers appear looks like this ###:### ###:###.
5.) now push the MONO button until the purge:#### appears on the LCD
6.) Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
7.) - switch off the printer ,switch it on
- ready to print
- CHEERS!
 email me if I help you. . ryuuzaki182@gmail.com
Mar 20, 2010 | Brother DCP 165C Compact Color Inkjet...
Clean Unable 46
Clean unable 46 means that the ink tank is full. You need a replacement tank installed and the count reset. This is a holder inside for the used ink,best to be a shop repair.
Jun 23, 2009 | Brother MFC 240C All-In-One InkJet Printer
Brother DCP 330C 'unable to clean 46' printer will not print
responded to this on a error 46 post by joachim.
hth,
razors
Mar 24, 2009 | Brother DCP-330C All-In-One InkJet Printer
Unable to clean
plz search this forum for unable to clean or error 46
it has been explained so many times
Apr 27, 2008 | Brother MFC 240C All-In-One InkJet Printer
Clean unable 46 : what does it mean ?
Feb 09, 2008 | Brother DCP-340CW All-In-One InkJet...
DCP-130C Clean Unable
- pull out the AC plug
- put back the AC plug while holding down the "menu" button and keep holding it (15 sec)
- now you are entering the MAINTENANCE mode and "error 46" pops up in the display
- select 8 by using the arrow buttons ,push OK and select 0 and push OK
- 00:00 00:01 OK (the display is showing this message)
- now push the MONO button 25 times until you see PURGE: xxxxx
- Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
- the purge counter indicates now: purge: 00000
- ready to print
Jan 27, 2008 | Brother DCP 130C All-In-One InkJet Printer
Brother MFC-260C All-In-One InkJet Printer Logo
685 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
