Can't boot MY computer was working fine, until one time the screen just turned grey then black. I turned off the computer to turn it on again, but it didnt boot from there. Im using mandrake linux. How can i fix my computer.
    Sergeant:
  • 233 Answers
Try to replace RAM
Posted on Jul 08, 2008
My monitor boots up with computer, but turns black when it gets to the desktop. if i turn the monitor off, then on again, it stays on for 2 seconds then turns black. can someone help me?
Make sure your computer's screen resolution is fine for that when you power up the computer press F8 key 5 to 6 time untill you can see safe mode and other menu if you are able to see safe mode then enter in enable vga mode then enter as admnistrator go to control panel->display property ->settings change screen resolution to 1024*768 then apply and restart it.Let me know if you need further assistance.Thanks for using FixYa.
Nov 17, 2011 | ViewSonic VX2235wm LCD Monitor
Hp Pavilion, tx2000, Black Screen, running, lights are flashing, Nothing on monitor
as soon as you turn on the computer keep tapping the F8 key until you see a screen called advanced boot options ..using the arrow keys in the keyboard select the option last known good configuration and press enter hope this works if this doesn't work.
again go to that advance boot options screen by following the same above said procedure and this time select the option safe mode then if your computer boots up in the safe mode then try to do system restore from start button->all programs->accessories->system tools->system restore select a date at which your computer was working fine and let it do its stuff if this works your computer will boot to the home screen..
good luck
Oct 02, 2010 | Computers & Internet
The rec nav radio screen has grey black and white lines and nothing else
If you ever found an answer to your problem I would really appreciate the help. Mine just started doing the same thing today. The screen has lines on it but the sound works fine. 2005 Jeep Grand Cherokee Limited. Thanks
Jul 19, 2010 | 2005 Jeep Grand Cherokee
Computer boots up and then goes to a black screen
Hi ,
Please follow these trobleshooting steps......
Turn the computer off and then disconnect any external devices connected and then when you turn the computer on or as son as you press the power button to turn the computer on start tapping the F8 key repeatedly until you get a black screen that says advance boot menu option .Then used the arrow keys on the keyboard and then hit enter,select the operating system and then when you get the log on screen select administrator .If it takes you to the desktop then you can try doing a restore by going to start ?all programs ?accessories?system tools and then system restore ? select the date when you think that you r computer was working fine and then click on next next to exit from the wizard.Should fix the issue .
If the computer does not boot up to the desktop then without wasting time on any trobleshooting steps recovery needs to be done that takes the computer back to its original factory settings.To do this instead of the f8 key tap the f11 key till you get the screen that says system recovery ,click next until you get the screen that has advance option ,click on it ?select destructive recovery ?click next the recovery will start and the computer will be formated (whatever you have added after you bought the computer would be lost ).If the recovery does not work this was then it needs to be done from the recovery disks and fot that you call call HP...
ALL THE BEST
May 15, 2010 | Computers & Internet
My asus laptop will turn on but not boot up, the screen just stays black but the green lights come on what do i do?
Have you tried connecting the laptop to an external monitor and starting the computer up?
Nov 25, 2009 | ASUS F3T-AP042C Notebook
Grey screen, iPod nano 4g 8gb
Quit trying to charge from the computer, cause a lot of them don't put out enough juice to totally charge the nano.  Turn the thing off and plug this thing into an AC wall charger for about 8 hours.  Then turn the thing on  and press the center button and menu button at the same time to reset the thing.  Then make sure you got the latest itunes edition and plug your cord into the nano and into the computer.  You will be prompted to sync this thing.
Oct 28, 2009 | Audio Players & Recorders
Gateway W340UA Black screen - does not boot
Yep it's probably the graphic card that's failed
Oct 16, 2009 | Gateway Computers & Internet
Acer Aspire One Zg5 will not boot up no indicator light come one
Hi there.
Try taking the battery out and booting it on AC power only, if it boots up turn it back off and reinsert the battery, turn the computer on, if it boots up all good, if not please post back.
Good luck
May 21, 2009 | Acer Aspire 5100 Notebook
Monitor goes blank less than a second after turning on.
I start my computer and turn it on, and everything looks fine for about 1/4 of a second and then it goes black while leaving the power light green. I can only see the screen again after turning it off and on, but that's only for another 1/4 second. What's up?
I got my rosewill flatscreen as a hand me down from my father. I've had it for several years now. Was working fine until a month ago. When I turn the computer on the screen goes black after 1/4 of a saecond. I have to turn it off and on anywhere from 10 to 20 times before it stays on. I have checked all plugs to the computer and outlets. I have absolutely no idea whats causing this.
Dec 28, 2007 | Rosewill R700J 17" Flat Panel LCD Monitor
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
