Question about Kodak Cameras
Instaler driver kodak af 3x - Kodak Cameras
Posted on Aug 10, 2012
  • 11967 Answers
SOURCE: kodak 8.2 af 3x optical lens is stuck and will not
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Mar 20, 2010
Neerak21
  • 101 Answers
SOURCE: My Kodak af 3x optical aspheric lens camera won't turn on
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
If issue persists, call 1.800.235.6325 for repair.
Posted on Sep 24, 2009
  • 11967 Answers
SOURCE: My camera wont turn on.
Posted on Oct 23, 2009
  • 10865 Answers
SOURCE: all of a sudden my
Hello. This problem is generally due to a low or dead battery. Replace the battery or if rechargeable charge it. IF the problem is still there, take the battery and the camera to any radio shack where they will test the battery and charging system for you. J.
Posted on Jul 31, 2010
LongPockets
  • 1177 Answers
SOURCE: I got sand in my
Try this page, but only if the camera is out of warranty.
Posted on Oct 27, 2010
Sony sd card wont work on my kodak af 3x
My guess: your sony card is a SDHC card. Or when it can store more than 32 Gbyte, it is a SDXC card. Both won't work in your Kodak camera, because it only can handle MMC and SD cards.
You still can buy SD cards, but most of the time they can't handle more than 2 Gbyte. Take care, because most memory cards with 2 Gb capacity are already SDHC.
Apr 23, 2014 | Kodak Easyshare V1233 12.1MP Digital...
My kodak af 3x is frozen the lens wont close and it wont turn on. The light is constantly flashing green. It was working fine and then went black and is frozen.
First you should take out the battery. Then give it a few seconds and reinsert the battery. Make sure there is enough power in the battery.
The camera should start from scratch. (Cold boot) and it should detect the lens is out. Then it should retract.
If there is a visible defect on the outside of the lens perhaps it won't work.
On the other hand, if the lens stays out, it could be there is a defect on the inside of the camera. Something mechanical in the lens barrel, something electrical like a bad connection off a (flat)cable, or just the electronics.
If the error comes back, you should visit a service centre.
Feb 12, 2014 | Kodak EasyShare Cameras
What kind of charger does kodak af 3x take
Surely this information is included in the technical specifications at the rear (probably) of the camera manual ?
Apr 23, 2012 | Kodak EasyShare Cameras
All of a sudden my kodak af 3x optical asperic camera would not turn on. how do I fix this problem?
Jul 31, 2010 | Kodak Easyshare V1233 12.1MP Digital...
Kodak AF power cycles, works in favorites mode
meybe the battery is to weak .
meybe the contet is broken
Jul 22, 2009 | Kodak Easyshare V1233 12.1MP Digital...
Cameras Logo
1,111 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
