Question about Anycom DELOS-14 Bluetooth Headset
I have a unit from last 3 years which I never used. Now I am trying to start it but it isn't starting. i want to connect it with my iphone.
  • 149 Answers
Make sure the headset is completely charged (sitting for a few years unused with discharge the battery).
On your phone, make sure bluetooth is turned on (settings, general).
While your phone is in discovery mode, turn your bluetooth device on and put it in discovery mode (usually you have to hold the power button for 7-10 seconds).
Your phone will find the device, and you will be prompted to enter the devises PIN number (often 0-0-0-0). Your phone should pair with the device then.
Posted on Jan 04, 2011
I have a new iphone and am trying to set it up. I started doing this last night but went to sleep before I finished.
Try connecting it to iTunes and resetting the device. Make sure your not sleepy this time while you set it up again
Dec 07, 2013 | Apple iPhone 4S
Why wont iphone communicate with the ipod station
Have you made sure that there is no protective case on your iPhone that would be interrupting the connection between the two devices? Have you verified that your device is compatible with the dock? On most of the new ones they require a digital input from the iPod/iPhone which only iPods made in the past few years (2007 or later) can supply. Also try docking your device when the docking station is in standby mode.
Dec 25, 2011 | Philips DCM250 Table Stereo Clock Radio...
Iphone not recognized when attached with usb connnection
Try using different usb ports on your computer. If it doesn't work then try hooking up your iphone to another computer. If it still isn't being recognized then try a different IPHONE USB cable.
If your Iphone still can't be recognized after all of this then read the article at the link below.
http://support.apple.com/kb/TS1538
Also try restoring your iphone to factory defaults if necessary. This is a last resort. If your iphone still won't get recognized by the computer then it could be the connection on the Iphone is defective and in that case replacing the phone is the only option.
Nov 03, 2011 | Sony VAIO VGN-N325E Notebook
I cant start my iPhone,and I did not sfiched off last night,for some reson did by it self.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a 10 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Dec 10, 2010 | Apple iPhone Smartphone
Iphone not starting
Hello!I have a problem with my iPhone 3g battery life, it lasts for no more than 5 hours or so and it doesnt matter what I do with the phone, if I listen to music, talking to someone or even if the iPhone on standby, at night I have to put it to charge because the iPhone just wont last the entire night (on standby) and will turn off.does someone have the same problem or know what to do to fix it?I have the iPhone for like a year and a half and the version is 3.0
Mar 05, 2010 | Apple iPhone 3G Black Smartphone
My iphone will not ring and i checked the orange dot
Some users who have recently updated/restored to the new iPhone firmware 3.0 have reported to have got into a problem where their phone randomly doesn’t ring when there is a call nor does the keyboard or slide to unlock button sound anymore. I got into this problem as well after unlocking and jailbreaking my iPhone 3G with firmware 3.0, my iPhone suddenly stopped ringing on calls randomly, resulting in missing a lot of important calls.
So if your iPhone isn’t ringing sound on calls, or if you are unable to hear the keyboard or slide to unlock click sounds, then try the following fixes before you panic and call Apple support:
Fix #1: Push feature is currently not working properly on jailbroken iPhone’s. If you have installed an application which supports Push Notification System then try disabling the Push feature as it may solve the problem.
Fix #2: Try Resetting the iPhone: Settings > General > Reset > Reset All Settings. This will reset your phone’s setting to factory defaults. Your contacts, calendars photos and any other data will stay intact.
Fix #3: There is a slight possibility that your iPhone’s headphone jack may have got some dust or rust which is causing the phone to think that the headphones are still plugged in when they actually aren’t. Try blowing out air in the headphone jack or try plugging the headphones in and out repeatedly. This trick may solve the no sound problem.
Fix #4: Restore/Update you iPhone back and start afresh: If the above solutions doesn’t help in solving your problem then you will have to start from scratch by first restoring your iPhone to the the original firmware
3.0 from iTunes, jailbreak it using redsn0w and then finally unlock(3G users only) it using ultrasn0w. This has fixed my problem.
Fix #5: Install Insomnia from Cydia: Install Insomnia as your last resort. When you press the power button on the top, iPhone goes into sleep mode after 30 seconds, in the process turning off your WiFi, sound and other stuff. When Insomnia app (available for free from Cydia) is enabled, applications will keep running and sound & WiFi will stay connected when the screen is off. This should fix your problem if all of the above solutions have failed to fix it.
Dec 30, 2009 | Apple iPhone Smartphone
I havent used my ipod touch in a month and i forgot the passcode
  1. Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
  2. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
  3. Press and hold the Home button while reconnecting the USB cable to iPhone. When you reconnect the USB to iPhone, the device should then power on.
    Note: If you see the message "Charging... Please Wait" , let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.
  4. Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
  5. When you see "Connect to iTunes" on the screen, you can release the Home button andiTuneswill display the recovery mode message:
    If you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6.
You will lose all your data though...
Sep 10, 2009 | Apple iPod touch Second Gen (8 GB,...
My itouch is only 3 weeks old. I just charged it last night. Now when I try to turn it on nothing happens. No power or anything.
you may have to restore it....but you'll lose all your data. here's how...
  1. Verify you have iTunes 7.5 or later. Apple recommends using the latest version of iTunes.
  2. Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
  3. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
  4. Press and hold the Home button while reconnecting the USB cable to iPhone. When you reconnect the USB to iPhone, the device should then power on.
    Note: If you see the message "Charging... Please Wait" or you see the screen pictured below, let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.
  5. Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
  6. When you see "Connect to iTunes" on the screen, you can release the Home button and iTunes will display the recovery mode message:
Aug 19, 2009 | Apple iPod touch
Plz help me
1. Re-start Itunes
2. Turn off the iphone
3. Connect your iphone to your computer while holding the Home button (at the bottom of the iphone face) for 15 seconds
4. Itunes will show a screen allowing you to restore your iphone.
A video guide: http://www.youtube.com/watch?v=M2foiTBSn3k
Oct 26, 2008 | Apple iPhone Smartphone
Sync
While the iPhone certainly isn’t the first mobile handset to suffer from freezes, its functional breadth and the fact that many of its users install unsupported third-party applications make the device, generally, more freeze-prone.
settings can result in a reduction in or complete elimination of freezes:
  • Tap Settings on the home screen. Tap General. Tap Auto-Lock. Set to “Never.”
  • Tap Settings on the home screen. Tap Brightness. Turn Auto-Brightness off.
Oct 13, 2008 | Apple iPhone 3G
Anycom DELOS-14 Bluetooth Headset Logo
111 people viewed this question
Top Anycom Radio Communications Experts
Michael Vincent Cruz
ray gallant
Are you an Anycom Radio Communication Expert? Answer questions, earn points and help others
