Question about KitchenAid K45SS Classic Stand Mixer
What causes my K45SS KitchenAid mixer to only have about 3 speeds, mostly fast?
  • nodiled Dec 31, 2010
    I could not seem to find the solution, did you send one?
4 Suggested Answers
SOURCE: Kitchenaid K5A mixer 10 speed only runs on fast, no slow speed
Pull the back off and there will be two screws at the top of the Speed Control Plate and a 3rd screw at the bottom. Tighten the top two screws down. bakerboy49203@yahoo.com. Let me know if it works.
Posted on Mar 21, 2009
  • 130 Answers
SOURCE: we have a kitchenAid mixer [ K45SS-WH-O ] when we
It's not oil, it's grease. Here is a very detailed article on how to add grease to the mixer. After you have added some new grease and tightened the screws it will stop leaking. The temporary fix is to simply remove the chrome ring as is done in the picture on the attached link, clean out the oil and stick it back on till it fills up again. It is called a drip ring for the reason that it catches the oil component of the grease which drips from the gasket when the screws loosen:
http://www.artisanbreadbaking.com/discussions/kitchen-aid.htm
Posted on Apr 15, 2010
justinbur167
  • 257 Answers
SOURCE: I have a Hobart KitchenAid Mixer Model K45SS and
Hello Mayfix,
The problem with your mixer is the speed control switch, this switch is located at the back of the unit. It is usually black and has all of the wires coming into it, the Item # 1394070 and cost $27.95 it can be located at RepairClinic.com he is a link
http://www.repairclinic.com/Kitchenaid-Switch-Parts?z=100&gclid=CKSD5NriuKcCFUVqKgodIE2b_g
You will have to adjust after you install you will adjust the two screws at the top of the switch while the machine is running inorder to make sure that you are getting all the speeds. Be careful as there is a possibility of electrical shock if you touch the wronge thing.
Thank you for using FixYa.
Posted on Mar 06, 2011
KitchenAid mixer runs at full speed only
It is most likely the phase board which is the little PCB under the back cover at the top, it has 4 wires coming out of it that plug into the black speed control board.
Mar 05, 2014 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid mixer K45SS only has one speed, slow. Have taken apart and regreased the machine. I plugged it in while the planetary head was off and it went through the speeds as normal, but as soon as
Did you clean the are around the variable-speed control lever?
Please be sure to unplug the mixer BEFORE disassembling the mixer.
http://www.ereplacementparts.com/kitchenaid-k45sswh0-classic-stand-mixer-parts-c-114958_114959_115060.html?page=4
http://www.ereplacementparts.com/article/11983/How_to_Replace_the_Speed_Sensor_and_Control_Board_on_a_KitchenAid_Pro_6_Mixer.html
Jan 07, 2014 | KitchenAid K45SS Classic Stand Mixer
KitchenAid mixer speed surges high and low uncontrolably
You can get the high speed back if you want to play with those three screws. there is a timing scheme for your mixer and it is set and adjusted by manipulating those 3 screws. The bottom center screw is for speeds 6 8 and 10. The best choice is to replace this switch, about $10 bucks on ebay.
Nov 13, 2012 | KitchenAid K45SS Classic Stand Mixer
My kg25h7x varies the mixing speed on its own
The Kitchenaid uses a centrifugal switch to maintain a constant speed. This must be sticking to cause this. You mixer will need to be disassembled and inspected.
Jul 03, 2012 | KitchenAid K45SS Classic Stand Mixer
The mixer goes real fast on all the settings. Whats wrong?
The K45SS is very similar to the 5-qt. tilt-head Artisan Stand Mixer.
You need to adjust the mixer speeds. Obtain a copy of the K45SS Repair Part List from Kitchenaid.com. Remove the screw holding the End Cover and locate the three screws from the Control Plate. All three (2 top left and right, and 1 bottom) must
be adjusted. 1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 14, 2011 | KitchenAid K45SS Classic Stand Mixer
I have a Hobart KitchenAid Mixer Model K45SS and it runs fast on low (Surges speeds up and down)what is causing this problem
Hello Mayfix,
Jul 04, 2010 | KitchenAid K45SS Classic Stand Mixer
Speed is off, only have fast and faster
Likely, you have an open resistor pack which may or may not be repairable located near the rear of the motor housing. Hope this helps!
May 23, 2010 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid mixer running too fast.
Change the speed control board. Repair alot of these
Dec 24, 2009 | KitchenAid K45SS Classic Stand Mixer
K45ss kitenaid mixer surges at low speeds
Hi. Go to mendingshed.com and download their free Kitchenaid Service Manual. This valuable document will help you to tune up your mixer, and covers the K45SS model. They also sell kitchenaid parts.
Go to kitchenaid.com and search for a parts manual for your mixer. Enter your model# thusly k45sswh.
If this solution has assisted you, please rate it. Good luck! ricardok45.
Apr 12, 2009 | KitchenAid K45SS Classic Stand Mixer
Kitchen Aid stand mixer just started going really fast at the lowest speed. I tried checking the sensor as some have suggested but is still goes really fast. It's only been used a few times. Is there...
Hi. Goto www.mendingshed.com , locate and download the free Kitchenaid Service Manual. This is a comprehensive manual and will help you with your task. You can also go to the Kitchenaid website and download the Parts Catalog for your mixer model.
If this solution has assisted you, please rate it. ricardok45.
Mar 10, 2009 | KitchenAid K45SS Classic Stand Mixer
KitchenAid K45SS Classic Stand Mixer Logo
44 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
