Question about SYMA Toys industrial New Syma S107 Mini Indoor Gyro
I have had my S107 for a week and it will not go back and forth everything else works okay
    Problem Solver:
  • 4 Answers
Back and forth movement is controlled by the prop on tail. Hold the helicopter in your hand move the right stick up and down to see if the little prop moves. If it works, then maybe the plastic prop itself... i.e. has a chip in it, or is bent/broken
Posted on Dec 31, 2010
Wipers not working right
This is about a "AFI 31000 Hand Operated Marine Windshield Wiper?"
Is this a trick question?
They are Hand Operated. The Motor is You!
http://www.marineengineparts.com/marinco-31000-hand-operated-windshield-wiper.html
Mar 31, 2017 | AFI 31000 Hand Operated Marine Windshield...
S107 RC Helicopter making a high pitched whine when used
If the gears are meshing properly and the rotors are not spinning very fast then the motor shaft is slipping in the hub of the first gear.
Jun 11, 2012 | SYMA Toys industrial New Syma S107 Mini...
How do I change a keyboard on a satellite A85-S107 laptop?
1. Take out the battery and AC adapter, unplugged from the wall, enusre the laptop is fully powered off.
2. Remove those screws with a T-8 or Phillips screwdriver.
3. Turn the laptop back over and open it up. Check and see if the Toshiba Satellite A85-S107 keyboard is tucked under any plastic pieces. If so, find them if those plastic pieces are screwed into anything, and unfasten them as well. If not, it probably uses clamps that can easily be removed.
4. Remove the plastic pieces carefully.
5. Unscrew any screws at the top (if necessary) and remove the keyboard itself from top to bottom. You'll notice that the keyboard is connected with a thin, but wide, data cable to the system board at the bottom.
6. Disconnect the data cable attachment of the keyboard which will sever all the remaining attachments of the laptop keyboard with the laptop computer motherboard. To remove this cable, you have to just carefully pull it out from the socket to which it is attached. Then you can lift out the entire keyboard out of the laptop.
7. Take the new Toshiba Satellite A85-S107 keyboard out of the plastic and place it inside with the right orientation, attach the data cable.
8. Refasten the keyboard in place at the top.
9. If you had to remove any plastic pieces, carefully snap them back in and replace any screws you had to remove.
10. Turn the laptop over and replace all of the keyboard screws.
11. Put the laptop battery back in place and switch it on to check Toshiba Satellite A85-S107 keyboard functionality. If everything has gone according to plan, you should be ready to type away!
Mar 12, 2012 | Toshiba Satellite A85-S107 Notebook
My sons S107 lower rotors would not turn. I disassembled and solved a gearing problem. At this time a wire came loose that supplies power to the tiny little prop at the tail. I fixed this problem too. ...
Check if s107 is fully charged.
Both rotors (lower and upper blade) should be working at full capacity. If either one of them is going slower, S107 won't lift up from the ground.
Check that gears are not too tight on each other. They should be able to rotate (leave cca 1mm space up/down between them)
Mar 23, 2011 | SYMA Toys industrial New Syma S107 Radio...
I have a s 107 and it will not go forward or backwards. everything else seems to work fine.
This has happened to two of mine, fairly common problem if you keep hitting things with your back rotor.
Solution 1: Replace the tail assembly
Solution 2: Remove the canopy and put a small weight in the nose which will serve to drag your heli forward. No backward flight but it works better than a heli that just hovers.
Mar 05, 2011 | SYMA Toys industrial New Syma S107 Radio...
My S107 does not hover very well. It moves in a large circle on its own. It isn't the trim as it doesn't spin around the axis of the rotor. It points in the same direction but slowly moves left, back,...
The upper shaft 'T' head has a broken pin in it (the part that holds the blades. You can flip the heli upside down and slightly rotate the blade housing back and forth and IT SHOULDN'T do that. Another way to instantly identify it is dislocate the rotor head links and the upper blade housing should instantly separate) It's made of plastic.
Anyway, It's also called the "T.B.E." Toilet Bowl Effect. It's not 'really' what's taking place, it's move of a cyclic issue but the effect looks like it's swirling in a toilet bowl... You need to replace the inner shaft basically on the upper rotor. They cost anywhere from $4-7.00 bucks. It took me about 2 days of researching and purchasing another one to finally figure it out. There was another website that says the balance bar is it or the gyro has gone bad; this simply isn't true.
Cheers!
Jan 05, 2011 | SYMA Toys industrial New Syma S107 Radio...
Can't figure out how to change frequency on the S107 copter itself (not the controller). Can someone advise. Thx
Found this for you.
it appears that the helicopter dynamically configures the control channel upon first detection of a signal from a controller. So, If you 1) turn off the helicopter, then 2) turn on the controller, then 3) select the desired channel on the controller, then 4) turn the helicopter back on, then 5) hold the throttle down on the controller, the helicopter will start up (after a slight delay) and be controlled via the new channel.
Jan 04, 2011 | SYMA Toys industrial New Syma S107 Radio...
Toshiba Laptop Keyboard Malfunction
If you boot a XP cd and select repair will it let you type?
Sep 21, 2007 | Toshiba Satellite A85-S107 Notebook
SYMA Toys industrial New Syma S107 Mini Indoor Gyro Logo
232 people viewed this question
Top SYMA Toys industrial Toys Experts
MeAndMyBrain
Level 1 Expert
Terry Hair
GI Consulting
Are you a SYMA Toys industrial Toy Expert? Answer questions, earn points and help others
