Question about General Electric Microwave Oven
My GE Microwave Oven, installed 2 years stopped working, and Displayed "F3". Model #: JNM1851DM2BB How can I solve this problem? Thanks
  • GE Master
  • 9,098 Answers
On this model, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
It is part number WB07X11020 and you can order it for $105.61 from the Pros here.
It's not currently in stock, but they can have it in a few days. They're our favorite supplier.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site , we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move your circuit board into the new frame.
Some connectors on the relays have a lock. See that image here:
Posted on Jan 02, 2011
Ge psacemaker microwave oven no working it started with a sensor error and the message change to F3 and beeping. I unplug and plug its still same error.Model JVM1750. What does F3 message stands for?
F3
Key panel (touch pad) shorted This code will occur if a shorted key panel is detected
continuously over 60 seconds. Replace key panel (also called touch
pad).
Dec 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave oven stop working. buttons will not work and an error code F3 come up on display. Could you tell me what this could be?
F3 is a shorted key you need a new keypad control panel. For the JE2160 series countertop model this should be the part#WB27X10681
Dec 06, 2010 | GE JE2160 Microwave Oven
Kenmore Gas Range model # 362.75491990 F3 error Oven will not hold temp - error message displays and beeps I Replaced the oven temp sensor same issue Is the control panel bad?
Many models of the GE microwave have sensors that can detect humidity from the foods you are cooking. This allows the microwave to make adjustments to the power levels used to cook your food. If "Sensor Error" appears, you should either press "Clear" to cancel the mode or leave the food in the appliance longer to give the microwave more time to detect the food.
Press "Time Cook" to manually enter the time if you receive an error message when trying to use the "Sensor Reheat" mode of your GE microwave. The error message may be caused by the food item being too large or too small to detect.
these are some other code error that will help you in case of next time.
  1. Step 1 Press "Off/Cancel" (or "Cancel/Off" depending on your model) to clear the error code. Note the code if it reappears.
  2. Step 2 Replace the touchpad if the code displayed is "F0," "F7" or "F10." A function key is stuck or shorted.
  3. Step 3 Replace the touchpad or the clock (ERC) if the code "F1" is displayed. Disconnect the ribbon connector to the touchpad. If no code is displayed after an hour, replace the touchpad. If the code displays again, replace the clock.
  4. Step 4 Replace the oven temperature sensor if "F2," "F3" or "F4" is displayed. "F2" indicates the oven temperature is too hot and the oven temperature sensor is suspect. "F3" or "F4" indicates the oven temperature sensor or shorted or open.
  5. Step 5 Replace the ERC if "F5," F6" or "F8" is displayed. The ERC is the main control unit. "F5," F6" and "F8 are codes that indicate problems in the ERC functions.
  6. Step 6 Inspect the door-lock assembly and circuit if "F9" is displayed. The door must lock when the oven is in use. If the lock mechanism is not functioning or if the detection circuit is malfunctioning, the stove will display "F9."
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); NOTE:
"F3" codes mean your oven temperature sensor has failed or shorted out. The only thing you can do is to replace the sensor.
Take care.
May 11, 2010 | Microwave Ovens
The microwave GE spacesaver is not working. It
TAKE MICRO APART PHILLIPS HEAD SREWDRIVER LOOK FOR A FUSE DOWN WERE THE PLUG COMES IN OR ON THE RIGHT HAND SIDE.iF THAT DOUSNT SOLVE IT TRY TO TIGHTEN ALL THE SCREWS BE CAREFULL YOU DONT HAVE TO TIGHTEN VERY TIGHT. THANKS FOR ASKING Troy Lawton
Jan 13, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Sensor Microwave model JES1456wf001 error code F3....how do we fix . Microwave comes on when plugged in and then reads to set clock and then it rings several times and we get an F3 code
Unfortunately, it appears that GE did not make that model to be repaired.
According to the owner's manual, there is a one year warranty.
After that, GE offers no support for it, but they sometimes make exception is people raise heck with Customer Service.
Good luck.
Sep 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
General Electric Microwave Oven Logo
147 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
