All the small 19" -
    Genius:
  • 1,274 Answers
Hello hoopk,
Welcome to FixYa.
My name is John. I will be assisting you with your issue.
Yes, there are many, but, will you be getting one for
them or for you? Sure, there are many, many, sets, with
speakers. Some that will crack glass or even break the
sound barrier. Do them a favor, and have their annual year
exam. Some need new aid implants. Check it out. They will love you for it.
Thanks for choosing FixYa.
Happy Holidays.......John
Posted on Dec 31, 2010
Samsung LCD... Power supply, t-con or inverter?
Samsung LCD TV Repair - TV Won't Turn On - How to ...
? 8:22
https://www.youtube.com/watch?v=n54IurMvr6o
Apr 4, 2014 - Uploaded by ShopJimmy.com
So in this video today we are going to be looking at a Samsung LCD and how to diagnose if you have a bad main or a bad power supply.
Samsung LCD TV Fixing Power Supply Problem - YouTube
? 10:52
https://www.youtube.com/watch?v=F6qgCg8lsxc
Dec 23, 2011 - Uploaded by Studio G Vision
Samsung LCD TV Fixing Power Supply Problem. Studio G Vision .... How switch mode power supplies (SMPS) work - Duration: 19:22.
Samsung LCD TV Power Supply Repair, Capacitor Replace ...
? 25:23
https://www.youtube.com/watch?v=lL0id3-YZsQ
Feb 9, 2013 - Uploaded by HandySavesMoney
... LN46A630 LCD TV. This procedure will apply to several otherSamsung TVs. ... Samsung LCD TV Power Supply Repair, Capacitor Replace, LN46A630. HandySavesMoney .... Country: Worldwide; Restricted Mode: Off.
Jan 27, 2016 | Samsung Televison & Video
My Tv will not turn on?
If tv not powering on, then probly power capacitor is bad. Open tv to reveal inside. There is a cluster of small capacitors look like tiny cans) that feed/store power to turn on tv. If capacitors are bulging on tops then they are bad. Simple to replace by soldering. Can purchase online or radio shack.
Nov 18, 2014 | Emerson 20" Pure Flat Screen Tv
How do i tell what "type" of Poulan Model 1950 saw I have
The type no. should be on the ser no. plate 1-8 there are small changes between the type no.s but they are all model 1950, is this the machine that you inquired about the sprocket? as that was not the model quoted in you first question!!!!
Jan 13, 2013 | Poulan 14" Chainsaw
My sansui hdlcd1909 19 in. lcd tv won't turn on. the standby red light blinks once, what can i do to turn it on?
sounds like bad capacitors on the power board. Very common problem. I would look at the caps if any appear even slightly rounded on top they are bad. They should be perfectly flat on top any puffing up means replace that cap.
Aug 07, 2012 | Sansui HDLCD1908 19 in. LCD TV
I have a 19 " sansul cant get my ilive sound bar
I hope this helps. You have to connect your sound bar to your cable box/satellite tv receiver. If you are connecting with composite or component cables you connect the video cables (either the yellow or the green blue and red cables) between the television and the cable box /satellite tv receiver. Then you connect the red and white audio portion of the cable between the cable box/satellite tv receiver and the sound bar. You are going from the OUTPUT of the cable box/satellite tv receiver to the INPUT on the television and sound bar. You use the function/source/input button on the sound bar to choose the space you plugged the cables into on it or listen to the radio or listen to your IPOD and etc.
Jun 10, 2011 | Sansui HDLCD-1900 19 in. LCD Television
Coby 22' TFTV 2224.Bought approx 2 yrs (or less) ago. In taking it to another room (just around the door frame and it was still plugged in and on) i may have pressed a couple of buttons together. Shortly...
Honestly your best bet is to sell it for parts and on ebay/craigslist and just purchase a replacement 22" tv. For the amount it would cost to fix you could basically have a new tv with a warranty for the same amount of money.
Thank you,
Lee
May 03, 2011 | Coby TFTV2224 22 in. LCD TV
Cant get sound surround out of tv
Have you tried looking at the sound set up menu on the TV? Some sets will only output sound via certain sockets which have to be switched on. Others will only output sound via internal speakers till they are switched off etc.
Nov 24, 2009 | Televison & Video
Fix terrible sound on 19'' B-OPD LCD TV?
sound in a tv comes first from the tuner box    the components in it are so small and bad soldering is common  the tuner if removable may need to be replaced or re-soldered... if it is part of the main board an adventurous person could try to re-solder it using a magnifying glass   otherwise if it is an audio ic that is the problem  they can sound very bad if it is clipping the signal which likely would be in the circuit leading to the chip and likely not the ic itself
Nov 07, 2009 | Televison & Video
Orion 1934 19 " tv
Hello anglersquest,
It is usually located near the power supply section. unplug the TV, open the back of the TV and look for a small glass cylinder with two metallic ends. This will be the fuse, now to check it do a visual inspection and you should see a clear cylinder with no internal dark smuges (good) has smudges (bad). Then if you have an ohmmeter set it to the 1xR setting and measure the fuse ends it should read 0 ohms if the fuse is good and no reading if the fuse is bad.
I hope this helps
Thank you,
Shuttle83
Aug 22, 2008 | Orion1934 19" TV
Televison & Video Logo
Top Televison & Video Experts
