Question about Haier RRTW18VABW (18.2 cu. ft.)
Haier rrtw18vabw refrigerator is not working. Think I burnt the fuse. Trying to find out where it is located?
  • 425 Answers
Usually the fuse is located at the lower back portion of the refrigerator. just follow the plug to the unit.
but before anything else be sure to unplug the unit to the outlet.
Posted on Dec 31, 2010
    Sergeant:
  • 183 Answers
There is no built in fuse in refrigerator. Check the power plug with an ohmmeter,and the start relay of the compressor.
Defrost timer location
Check this out for manual: www.manualowl.com/p/Haier/HRF-588FR/Manual/99803
Feb 28, 2014 | Haier Refrigerators
My mini fridge stopped working while I was at work
RF-6850-16 Start Relay
Is the compressor again getting hot once you turn the temperature down? Will the refrigerator cool if you turn the temperature to as cold as it can get? Reason I ask is I am trying to decide if it is the thermostat or a defective staryt relay. Even at the cost of parts I would be careful and sure of what you are going to do here. Haier is not well know for quality products or customer support and there are other brands names out there that will support customers much better than Haier. Not trying to say bad things about your refrigerator I just hate to see when people invest into something and then get left holding something that Haier will not help with and does to all of their customer. Thanks Sea Breeze
I have lost valuable customers because of Haiers lack of customer support.
May 29, 2013 | Haier HMSE03WAWW (33 cu ft) Compact...
Anyone know where to get a relay for a hsa04wncbb. Haier 3.9-4.0 mini fridge? I believe its the relay, the main power comes to it and gets redistributed to the compressor and stuff. Any help would be...
Here are all the parts listed for that refrigerator, Click Here=>
HSA04WNCBB HAIER 1.8CU. MINI REFRIGERATOR
By clicking on the part numbers in blue on the left should take you to where you may find those parts. If you have any questions please let me know, Thanks, Sea Breeze
If helpful please rate this solution...Thanks Again
Jul 24, 2011 | Haier Refrigerators
Ice cream is not freezing in top freezer compartment - what should cold control be set on - i do not have very much in the refridgerator - is"1" coldest setting model is rrtw18vabw
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 12, 2010 | Haier Refrigerators
My small haier fridge just makes a clicking sound but does not get cold. Is there a reset switch or fuse?
the clicking niose is the compressor relay . and needs to be replaced . this may not get the comp going as it may be stuck or motor windings burnt . . then replacement of compressor in needed . mm /hope this hepled .
Jan 16, 2010 | Haier HSB03 Compact Refrigerator
Haier aficionado model AES44BPG compressor wont stay on
I had the same problem. Mine turned out to be the PTC starter. Checked the compressor coil resistance and it ws fine. Replaced the PTC starter with Item #: 1268268 from Repairclinc.com and it started right up. The PTC starter was an exact replacement.
Hope this helps some else trying to solve this problem. To bad Haier doesn't offer this part!!
May 01, 2009 | Haier (B000194UBA) Compact Refrigerator
Safty switch
Have a qualified person (electrician) check the wiring in the outlet to make sure there is no bad connections or burnt wires behind the outlet,I would start at the outlet where the appliance burned up.The only thing in the system to replace would be the wire itself ,bad breaker or fuse depending on your elecrical panel, the fuse would be obvious and the breaker would not be able to be reset,but it sounds like you have power to the outlet,bad connections cause heat,which could cause a fire,Please have this checked by an electrician to be safe and a peice of mind.
Jan 26, 2009 | Haier Refrigerators
Cold freezer-motor burned up
I had the same issue, but without the burnt parts.
I couldn't find a reasonable (less than $150) replacement motor from Haier places, but I just took the motor out and took it to an appliance repair center (in North Denver)
They said it was a standard part, charged me around $22 for a new one and I was all set.
For my replacement motor, it was a reversible design, and was initially set to go the wrong way, so I had to reverse it.
Sep 22, 2008 | Haier HTQ21JABWW Top Freezer Refrigerator
Haier RRTW18VABW (18.2 cu. ft.) Logo
170 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
