Televison & Video Logo
Posted on Dec 31, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have double image can't get line convergence to work don't have a password
Anonymous
Level 2:
New Friend:
  • Expert 57 Answers
  • Posted on Dec 31, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
57
Questions
Helped
8701
Points
163
You dont need a password, you need to replace the stks inside the tv and check bad fuses. that should fix your problem. if you need more help please feel free tro call me at anytime 602-810-7149.
Image is showing double on the screen. The entire screen's images are doubled and overlapping over themselves. Some color distortion obviously as well. Images basically aren't lining up. The red color...
On Rear Projection TVs there is a thing called "convergence" in which the color bands are lined up so that they can mix to make the colors that we see on the screen. When a TV of this type is moved or bumped around, or even near a source of electrical interference it can throw this out of alignment. Many TVs have options in their menus to set convergence.
I believe it is under Menu > Picture > Convergence I'm having trouble finding the exact process used for this, but it will be noted in your user guide as well.
If this does not resolve the issue you may need to purchase a convergence repair kit which requires a considerable amount of electrical knowledge and can take several hours to repair.
2helpful
2answers
Mitsubishi WS-55511 convergence problem?
No,need to diagnose.It a 100% convergence problems.Convergence problems very easy diagnose.The picture look like 3D,colors lines don't lines up.Fuzzy,out of focus.Convergence controls don't work to lines up any colors cross.The tech is cheating u if he said cost $125 to diagnose.If u know how to solders u could fix this convergence problems about $100.U can buy a convergence kit at Websites Tv repair World.com,Tvrepairkits.com.The shop everythings fix parts and labors only $300.
3answers
Hitachi Model# 43FDX01B is doing a double image.
You have a convergence problem, you will need to change the convergence IC's STK392-110, there is also 12 6.8 1w resistors that need to be changed, there is also 2 fusilbe resistors that may be open. You can probably Google the IC's as a kit and find them all in one kit.
You can fix this yourself and save about $300-$400 in repair bills.
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Getting double image in colors
this is a lost of convegence power. first check to see if you have the convergence option in setup menu. if you do not then i suggest you read the fl231 problem in the tips and trick section. otherwise there a good chance u would have to replace convergence power supply board
2helpful
2answers
Double Image Red and Green
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
2answers
Ghost image
You will have to replace both the convergence IC's on your TV..
Replaced Convergence but pictures still display with double images
i went to converge my mitsubishi ws 73903 and the blue line wont go down to match the other ones
1helpful
Color convergence red and blue will not line up/ double images
Repair involves some dis-assembly...replace convergence IC's
and inspect current limiting resistors for over-heat damage...
part # STK392-110 sub to upgrade STK394-160 Hitachi part # CZ 01341....you will need two....good solder technique required.
....................................................................................T.
2answers
Double image
convergance ic bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
