Question about CTX Optoma EzPro 600 Multimedia Projector
Ezpro 600 Dear, I?m looking for an electronic manual for a beamer, EZPRO 600. Can I order a diagram for this beamer? If possible or not will you please answer to: Ruttens@telenet.be Greetings and thank you very much, Ruttens J.P.
Hi, I have a copy of the user manual fot this projector in PDF format, if you email me at chris@bse1.co.uk I will send you a copy.
Regards
Chris Woodward
Posted on Dec 18, 2008
I looking for a replacemnt bulb for ctx ezpro 500
I get all my lamps from
www.avprojectorlamps.com
Just checked, they have the lamp you require in stock
Hope that helps you
Aug 05, 2011 | CTX Optoma EzPro 500 Multimedia Projector
I NEED TO FIND A BULB FOR THE ezpro-610
This is it (in the USA) http://www.myprojectorlamps.com/projector/Optoma/EzPro%20610.html
You mention CTX & Optoma. The link above is an Optoma lamp for the EZPro 610....also note there is a 610H
Feb 16, 2011 | CTX Optoma EzPro 610 Multimedia Projector
EzPro 585 Multimedia Projector: Hello. I have a problem with my Projetor .. It is ...
check if your projector is capable of the same screen resolution as the laptop.
May 07, 2010 | CTX EzPro 585 Multimedia Projector
HOW DO I CONNECT A AN EZPRO 610 PROJECTOR TO A LAPTOP COMPUTER.
1. You will need a VGA or S-video cable and a 1/4 inch stereo plug that will go from the earphone jack to the EZpro then out to a amplified system for the sound.
2. I believe the EZpro has connections for HDMI which will supply sound as well as High definition video. You should have an adapter for the HDMI also if you
3. connections port as follows:
1. USB Connector (Connect to PC for Remote Mouse function)
2. RS-232 Connector
3. Audio Input Connector
4. S-Video Input Connector
5. DVI-I Input Connector
(PC Digital (HDCP)/PC Analog/Component Video Input)
6. VGA In/SCART Connector (PC Analog Signal/Component
Video Input, HDTV/SCART Input)
7. VGA Output Connector (Monitor Loop-through Output)
8. Power Socket
9. KensingtonTM Lock Port
Looking at the usb port go counter clockwise the numbers are in succession. 1- 9
1 Power Cord
2 VGA Cable
3 DVI-I to VGA Cable (Optional accessories)
4 Audio Input Cable (Optional accessories)
5 RS232 Cable (Optional accessories)
6 USB Cable (Optional accessories
Apr 24, 2010 | CTX Optoma EzPro 610 Multimedia Projector
Projector Cable
Found a pin-out at: http://www.diyaudio.com/forums/diy-projectors/78108-ezpro-550-rgb-cable-pinout.html
1 2
2 5
3 9
4 No conectar
5 14
6 1
7 6
8 13
9 15
10 11
11 no conectar
12 No conectar
13 3
14 12
15 No conectar
You probably need to have a special cable made up.
Jun 24, 2008 | CTX Optoma EzPro 600 Multimedia Projector
Words have a shadow
Hi prraver26
Try using a different cable from the source to the Projector.
If the problems persists you will be looking at a very expensive Mainboard replacement.
May 14, 2008 | CTX Optoma EzPro 600 Multimedia Projector
CTX Optoma EzPro 580
Hi, Optoma USA recommend that you set the PC resolution to SVGA (800 x 600) or XGA (1024 x 768). Your HP Pavilion ze 4900 default resolution is S = SXGA (1400 × 1050) or X = XGA (1024 × 768). I would assume that your cable(s) are properly mated/attached from the laptop to the projector. If on pressing TV Now! One-Touch button with a TV icon at the top of your keyboard to switch the display to the TV-Out mode, there is no picture projected, you can try to manually lower the screen resolution of your PC. Try lowering it to the 800 X 600 setting in your Display Properties. Also, you may want to check if the Dual Display Mode is enabled/activated. You can try different resolution setting as long as the projector can handle it. Hopes this works and give you an idea. Should you need more assistance, pls post/comment. Good luck and kind regards.
Aug 11, 2007 | CTX Optoma EzPro 580 Multimedia Projector
Ctx ezpro 600
Yes it is. You have knocked one of the optical components out of alignment. This should be a fairly easy repair for a qualified tech, well worth it, considering how expensive video projectectors are.
Jul 12, 2007 | CTX Optoma EzPro 600 Multimedia Projector
CTX Optoma EzPro 600 Multimedia Projector Logo
181 people viewed this question
Top CTX Office Equipment & Supplies Experts
jasbo
jasbo
chinopuma
Level 1 Expert
Arora Singh
Arora Singh
Are you a CTX Office Equipment and Supply Expert? Answer questions, earn points and help others
