Question about LG 50PC3D 50 in. Plasma Television
I have LG 50PC3D-UD display issue. I'm getting a black screen with thousands of blue pixels in center of screen. 5-6 inches wide orange horizontal from top to bottom moving across the screen. I check and test all A/V connection, hdmi, svideo, pc input, all same issue but sound work fine. I open the back cover and found 9 caps blown on the power board and replaced them and still no change. I spent $230 for new power board, still no change. I had 3 service tech out. Cause I wanted to be sure due to part cost. First one try replacing the power supply board, no change, and say the control board need to be replace. 2nd guy try the power board, no change, and say the Main board need to be replace. 3rd guy try the same power board, and have no clue to solve the issue, he said he called LG and they say to replace the Main board. I just want to make sure this will fix it due to the expensive Main board. Can anyone solve this? Is it the Control board or the Main board?
    Top Expert:
  • LG Master
  • 24,726 Answers
The reason the blue pixels are igniting is caused by the driver board, not the power supply or main board. The drivers are part of the LG screen and cannot be replaced.
Posted on Mar 08, 2017
  • 8 Answers
SOURCE: replace main board on LG 42LC7D-UB
not sure what you're referring to as a "main board", but heres the LCD Control Board for the TV
Posted on Mar 13, 2009
  • 1077 Answers
Try this place,
I the best place I know of to get parts at a good price.
There are a couple of boards that have different part numbers. You'll have to match the part# with yours. It maybe out of stock, but click on it. Then click on "find other products with this part number". Then all the main boards show up with that part number. A couple of them should be should be in stock.
Posted on Apr 17, 2009
  • 4090 Answers
To let you know , there jave been may claims against this 42" model There were some models released that had faulty power boards and video controller boards. LG recalled many of these to have them replaced
No picture and sound is Y +Z Sustainer problem.However, normally they have to change both Y Sus and Z Sus boards atthe same time. If you lucky than it's just a fuse on the Y sustainerblown (the chance is very rare) otherwise the IPM (Intelligence PowerModule) on the Y/X sustainer board is short. This is a common problemand costly to repair.
Is it under warranty or Extended 5 year warranty? If so get it repaired now.
Call customer service for help 877-543-8325 to try them first
If you are skilled in electronics the cost of parts is about $250 online (Otherwise add another $400 for labour and travel if you use a tech ) Always ask for a quote first))
Just ensure you select the right model as i am unsure this link is correct one. But the place itself should have your model
Please rate our help to =keep the FREE service online++++Thanks for using FIXYA
Posted on Sep 14, 2009
SOURCE: LG 42PX4MVH PLASMA TV - Sound but no picture.
I have the same issue with my LG 42PC3DVA and I narrowed it down to the Y SUS board. After a little research there are a few items that are prone to go. The ceramic fuses (as you found), sometimes the capacitors on the Y SUS, Z SUS, and power supply go along with them You can tell because thy will be bulged at the top instead of flat. I replaced a few of my capacitors - they are only $0.89 each so it was MUCH cheaper than a board.
The other thing that is common on the Y SUS in particular are the FETs (also called MOSFET). They can be replaced if you are good with a soldering gun but they are static sensitive so be grounded. They are also a bit tricky to test so you may want to do some research on how to determine if this is the issue... or you can just replace the whole board.
Posted on Oct 28, 2009
  • 458 Answers
SOURCE: i have a 42
The fuse you have replaced would have been on the sustain board, now that it clicks indicates a problem either with the control board or the sustain board. You would need to disconnect the connector from the power board to the Y-sustain board (left of power board) to check if the Vs & Va voltages are present, if so then the power supply will be working ok & the problem will be with the previously mention boards. There is the possibility that the plasma display screen could also be faulty.
Posted on Nov 06, 2009
Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line?
Black square on the screen Vizio Gallevia 47" 1080p - Fixya
Jan 16, 2008 - Black square sized app. 10"x10" pops up on the bottom right corner of the screen and won't go away. .... Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line? I am looking at replacing the ...
bad screens display vertical lines with a white background ...
iFixitJun 17, 2014 - I am now replacing a screen on a different G2 and I am on the secondscreen. ... A touchscreen smartphone made by LG Released: 09/2013 Model: VS980..... on the rigth side, from the top to the botton has 6/7 black lines.Missing: 42lg70 ‎pixel
Broken LG LCD TV Capacitor Black Screen My Wont Turn ...
? 6:27
Aug 25, 2010 - Uploaded by FixItUrselfDummy
Broken LG LCD TV Capacitor Black Screen My Wont Turn On ...How I fixed my LG TV, Won't turn on or show picture Model: LG42LC7D ...Missing: horizontal ‎pink ‎pixel ‎line
Jan 05, 2016 | LG Televison & Video
42inch LG plasma TV
well if you could please give out the model nuumber thank you
Sep 10, 2008 | LG RU-42PZ61 42 in. HD-Ready Plasma...
Milk white screen.
Try updating the display drivers ... Hope it turns goos after the update ...
Jan 03, 2008 | Dell E151FP 15" Flat Panel LCD Monitor
Hello. My LG plasma 50pc3d has had red pixels jumping around whenever there is black on the screen, but has always cleared up. Today a vertical red line appeared, 1pixel thick, running from top to bottom....
Pixels on a plasma TV are from the zustain boards. You might have one or both of them about to go out. Horizontal lines are most likelly one of your buffers or the screen itself might be going bad. You can buy the sustain boards by part number that you can get from the board itself from
Jun 04, 2011 | LG Televison & Video
Please give me everything information about LG GW 525
The new LG-GW525 is a Slider QWERTY Touchscreen Phone with enhanced messaging and social-networking capabilities.It is a 2.8-inch full touchscreen phone featuring a 3-megapixel camera.There is no WiFi in it. The main features of the new LG-GW525 Slider QWERTY Touchscreen mobile phone are:
  • RF Band: GSM 850/900/1800/1900,UMTS 900/2100
  • Display: 2.8-inch full touchscreen TFT display with 240×400 pixels resolution
  • Dimensions: 106.5x53x15.9 mm
  • Slim and Compact design
  • Slider QWERTY keyboard
  • Enhanced messaging and social networking features
  • Push e-mail and instant messaging
  • 3 megapixel camera
The detailed specifications of the new LG-GW525 mobile phone are:
  • Network:GSM 850 / 900 / 1800 / 1900,HSDPA 900 / 2100
  • Dimensions:106.5 x 53 x 15.9 mm
  • Weight:125.5 g
  • Display:2.8 inches TFT resistive touchscreen, 256K colors,240 x 400 pixels
  • Full QWERTY keyboard
  • Accelerometer sensor for auto-rotate
  • Memory
  • Internal:40 MB
  • Card slot:microSD (TransFlash), up to 16GB
  • Data
  • 3G HSDPA 7.2 Mbps
  • Bluetooth v2.0 with A2DP
  • USB v2.0 microUSB
  • Camera:3.15 MP, 2048×1536 pixels
  • Stereo FM radio
  • Colors:Blue on Black, Red on Black, Silver, Pearl White
  • MP3/MP4/AAC/AAC+/EAAC+/WMA player
  • MP4 player
  • Document viewer (DOC, XLS, PPT, PDF)
  • Battery:Standard battery, Li-Ion 950 mAh
  • Stand-by:Up to 500 h
  • Talk time:Up to 5 h
Mar 29, 2011 | LG GW525 Cell Phone
Picture just has black bar down the middle of the screen.
That is probably a faulty segment display.
Replacing the screen will fix it.
Dec 07, 2017 | LG 50PC3D 50 in. Plasma Television
Horizontal (dashed) line across screen
On the KDFE55A20 this sounds like a bad Q-Box. I would get an estimate from a Sony authorized servicer as this part may be quite expensive. On the 55A10 model this may be the B-Block and is also quite expensive. Getting an on-sit estimate would be the first step I suggest. Again go with an authorized Sony servicer. Call Sony or go to for customer service. Good Luck
Nov 21, 2007 | Sony KDF-E55A20 55 in. LCD Television
LG Plasma TV 50PC3D
The TV should be under warranty. Send back. Sounds like the panel is faulty (half the value of the set).
Feb 06, 2007 | LG 50PX4DR 50 in. Plasma TV
LG 50PC3D 50 in. Plasma Television Logo
150 people viewed this question
Computer Repairing
Computer Repairing
