Question about GE Tritonr XL GSD6260JCC Dishwasher
I have a GE Triton XL dishwasher that all of the sudden stopped cleaning well. I now find food residue on the dishes, and the detergent cup does not empty completely. I use the gel detergent, and I just see the gel dripping down the door after the cycle is complete. This machine is about 5 years old, and I'm looking to see if it can be easily fix. I rather not have to call someone to tell me that I have to get a new one, or pay more to fix it that what it is worth. Thanks
  • 1 more comment
  • amdevia Dec 31, 2010
    Spray arms look ok.
  • amdevia Jan 05, 2011
    The water temp seems ok, but it looks like there is not a lot of water inside the machine when the cycle starts. Not sure what the level should be
  • amdevia Jan 13, 2011
    Changed inlet water valve, and dishwasher works better.
  • 4,323 Answers
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps... Please post back if you need more information.
Daniel
Posted on Jan 01, 2011
  • Daniel Scott
    Daniel Scott Jan 05, 2011
    Then check the water inlet valve and make sure it is clean & fine.
  • GE Master
  • 43,501 Answers
The spray arms can look okay but stil not work properly....I even took mine out and tried to clean the **** out of them...thought I did a great job... yeah right...new worked tons better...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Dec 31, 2010
  • 3,267 Answers
Had the same problem and found two things which were causing it
-The O-ring was missing off of the tube connection on the back of the dryer that inserts into the sprayer tube. I found a size 11 O-Ring at Home Depot and it worked
-The openings on the underside of the spray arm are what propels the sprayer to spin. I found small pieces of plastic debris in the openings and cleaned them out.
Now the middle arm spins like it should.
Also
try placing a packet in the bottom of the DW and then start a wash cycle ( use the energy efficient cycle that does not use the heater to dry the dishes..).. if it is not dissolved at the end of the cycle then your water temp may not be hot enough..Hope that helps..
My office's GE QuietPower 3 dishwasher detergent
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Jul 29, 2011 | Maytag Dishwasher
We bought a new dishwasher because we were finding a hardened residue was being left on our dishes, it was ruining our dishes. Although we have a brand new dishwasher this problem is still occurring and...
My best advise is to reduce the amount of detergent to the least amount that you can use, and still get the dishes clean. We do rinse the dishes a bit, as the soft food disposer isn't made to act like a garbage disposer, but rather, to catch incidental food residues. We no longer fill the closed detergent dispenser. We sprinkle about 1/2 of the normal amount (that goes in the open cup) on the inside door and close it up. Our dishes get very clean, with no residue. Also, use a good drying agent as this will help sheet the water off of the dishes. It may take several cycles to see improvements, but you should see improvements nonetheless.
Best regards, --W/D--
Jan 23, 2011 | Dishwashers
Ge Triton dishwasher GSD5500GOOWW was not cleaning like it used to- I cleaned screens at back bottom-very dirty- also-detergent cup stuck opne - took door apart and got it unstuck - it works fine now. - it...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Jan 23, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
GE Triton XL dishwasher, at first I had the left over powder soap issue until I dismantled the lower spray arm and cleaned the nets and removed the rusty particles in the hole in bottom of washer and also...
heatman101
Sep 25, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
Soap (?) residue on dishes; also not getting them clean--food on
heatman101
Jul 26, 2010 | GE Nautilus 24" Built-in Dishwasher
Detergent left in dispenser cup
You either do not have enough water getting itno the machine or it is not hot enough. 5 years old so I would suspect a plugged screen on the fill valve.
Eric
Dec 11, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
My ge triton xl dishwasher isn't getting are dishes clean. There is a white film on the glasses and I find dark spots on my plates. There is always dish soap left behind in the dish soap container. It was...
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Oct 10, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Left over soap residue in glasses
you need to flush out the dishwasher, fill a cup with vinager and put it in the dishwasher standing up, then run the dishwasher thru a heavy duty cycle with no dishs. Then cut back on your soap, with new dishwashers and soaps you dont need much at all
Jul 08, 2009 | KitchenAid Food Grinder & Vegetable...
GE Triton XL
Try placing a packet in the bottom of the DW and then start a wash cycle ( use the energy efficient cycle that does not use the heater to dry the dishes..).. if it is not disolved at the end of the cycle then your water temp may not be hot enough..Hope that helps..
Aug 28, 2008 | GE Tritonr XL GSD6260JCC Dishwasher
Detergent trouble
hi there,
sounds like the detergent dispenser is not working properly.
are the rest of your dishes clean? in other words, is there any food residue on them?
check the dispenser and make sure that there is nothing visibly wrong with it.
if the problem still persists, replace the dispenser.
Mar 11, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
GE Tritonr XL GSD6260JCC Dishwasher Logo
1,511 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
jdthefixer
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
