Question about Yard Machines Garden
Tecumseh 195cc 7hp engine is very hard to turn over, had to use a bar and socket,after removing the pull starter to turn it over, the oil is clean,not burnt,also removed the plug it was good ,squirted some oil into the cylinder, kept turning it around but the starter will not turn the moter over,it feels like the moter is half seized, checked all under the moter in case the belt pulleys were seized etc, all was ok.
    Scholar:
  • 36 Answers
You are probably correct by saying the engine is half siezed. Rust will get inside the cylinder if it is not used very often. This is a common problem. You are doing the correct thing by turning the engine over with a wrench while putting oil or penetrating oil down the cylinder. The cylinder usually cleans up after a while of turning the engine. But please note that if this is the case then rust has gotten into the cylinder and it may have caused some damage. I have "broke loose" many engines by using the penetrating oil and turning them over by hand with good success. But this may cause it to use some oil, break a ring, or cause more engine damage. Be careful and good luck. Hope this helps.
Posted on Dec 31, 2010
I have an Ariens ST724 7hp snowblower (model:924075 serial 005629) that needs to have the starter cup, recoil, and the 4 bolts that secure the recoil replaced. The problem is all of these parts are NO
In order to order engine you must look-up the engine itself. If this blower still has the original engine then it is a
Tecumseh HSK50-65496
Recoil Part Number TEC590604 Image
t_590604_000.jpg This item has been discontinued by Tecumseh, part number STE150-003 will work but does not have the handle cup.
Original Tecumseh Part
Replaces Tecumseh 590604 and 590605
Fits Models: H, HS, HSK
For use on Snow King Models
RECOIL STARTER ASSEMBLY TECUMSEH 590420A
Nov 10, 2014 | Garden
Yardworks snow blower
Leaks are normally from bad seals or ones put on engine wrong. Many snow blowers leak oil, very common. Electric start needs to be taken apart. Rust is problem most likely. When you engage the starter it kicks out the gear to turn over engine. Carefully remove the starter from engine, try to start starter an if the pinion gear does not kick out from starter disassembly it an try to clean rust away from action. Dont break wires around electric motor careful about getting dirt an rust in winding. Try to lube spring an moving parts around gear. One other thing it could be a sheared off gear on starter also.
Mar 22, 2014 | Tecumseh Garden
Tecumseh Engine Prob. 7hp engine frozen. Tried PBS blaster penetrating oil but it all runs out the exhaust since the exhaust port is open. Any ideas on what to do next to unfreeze the engine?
You could try warming some oil slightly and then put a bit in and try to free it manually. The only other way would be to take the whole engine apart and free it manually. This is why we should make sure everything is oiled.
Sep 02, 2013 | Garden
Tecumseh 195cc
Those are engine numbers not buggy numbers, use tape measure inside the pulleys to get approximate size then experiment with different sizes
May 29, 2013 | Mtd Garden
Mccullough chain saw
Some saws use the compression stroke to pressurize the oil tank for auto oiling. If let set long enough the oil will flow backward into the engine causing this.
May 28, 2013 | Garden
Why is my Tecumseh 6.5 hp engine hard to start after taking blade off.?
When you tilt the mower too much oil will mix with gas. Try taking out the spark plug and cleaning it good in case some oil got on it. If this don't solve it, drain the gas and refill with fresh gas in case oil mixed with it when you tilted the mower.
Aug 04, 2012 | Tecumseh Lawn Boy Push Mowers Insight...
How hard is it to pull the motor, the wife was driving it when all the lights in the dash started blinking and then the motor locked up. After removing the vale cover everything looks dry on top, the...
I would question whether the motor is "locked" have you tried to turn it not using the starter? (Large socket and breaker bar on crankshaft front bolt)
You may even free it this way. First pull the plugs and drop a small amount of oil in each cylinder.
When you do try to start it, do you hear and feel the starter engage then stop in it's tracks?
If it's locked, you would likely had to see a trouble light, like oil light on for a fair while before hand, assuming oil pressure failure.
Sorry this does not answer the first question, but I think you're jumping the gun with pulling engine.
Also, have you ever got a junkyard engine before, it's a LOT of work and you never can be sure it's any good. Warrenty is fine, but you still have to pull it again if it's no good. And there's always a difference in somthing.
Jan 12, 2011 | 2003 Toyota RAV4
Engine part for Tecumseh 6hp 195cc
The float and pin can be bought as a repair kit., and replaced.
Mar 24, 2010 | Mtd Products Yard Machines 158CC Tiller
I need to fix athe pull string on my toro push behind mower. it has an 195cc tecumseh motor. the string broke and i can't find anything on toro about how to fix it without buying the whole assembly.
remove bolts from cover and remove the cover. Should be able to access the assembly for the pull rope. Go to a local mower repair shop buy some new line. The old line should just be knotted up on the spring loaded wheel in there. You put a new piece on put in a new knot, put some turns on the assembly to basically wing the spring so it snaps back when pulled, put line through whole and attach to pull handle.
Jul 11, 2009 | Garden
Garden Logo
259 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
