Question about Denon S-32 Shelf System
I have a Denon S-32 WiFi radio that also plays MP3 music from my D-Link DNS-321 NAS (network attached storage) via the UPnP AV Server in the NAS. Everything works as advertised except that the unit will not execute playlists correctly. The Denon appears to accept only .m3u playlists, but regardless of the track order, the playlist will always execute in alphabetical order. The unit also ignores the encoded MP3 track order and plays music within folders in alphabetical order as well. The Denon microprocessor has been reset using the procedure listed in the manual and the unit has the most recent firmware. Interestingly, resetting the processor fixed the problem with 'favorites' not being saved.
3 Suggested Answers
  • 31 Answers
Hi MadLad,
There are several things to consider re this fault.....
Normally on small systems there is a selector switch to allow you to select what you need to listen to...for example if you want to play a CD then you select the CD mode, insert the CD push play and away it goes....
In your case you need to select Radio, or maybe select AM or maybe select FM, one of these should be accessed from a digital read out menu where you select your requirements.
Please have a good look at the operating manual to see if you can work out how to select the required listening mode, and you will be sweet...
Cheers From YUBEUT
Posted on Dec 25, 2007
  • 8546 Answers
SOURCE: Since it appears that a Denon 1911 doesn't like
It seems that playlist are only supported on iPod. Page 22 of the manual. Playlists are not mentioned in any other context.
Posted on Apr 11, 2011
What is nas
network attached storage server using bsd.used for backup
Feb 05, 2011 | Microsoft Windows XP Professional for PC
I do not have to driver for the D-Link DNS 323 2-Bay Enclosure
You have not said what you are using it on, is it windows xp, 7, linux? etc.
Feb 01, 2011 | D-Link Dns 323 2-Bay Network Storage...
I had to replace my router and I now cannot see the dlink enclosure. I wanted to get the IP so I can reconfigure the IP address but like I said I cannot seem to get the device to show up on my belkin...
You can try a couple of things, easy thing is to reset the NAS server by unplugging it and allowing it release its leased IP address, assuming that it is setup for DHCP. Once this is reset it should grab another IP address. If you remenber setting it up for a static IP, then you could do a google search for an IP scanner or find one that you are comfortable with download and install look for device on your network that will give you your IP to the NAS server. Good luck
Nov 28, 2010 | D-Link DNS-321 Network Attached Storage...
Easy Search does not pick up the DNS 323
This may be problem with your personal firewall on Windows workstation where you are running the Easy Search utilit. Try disabling the firewall while you run it.
Mar 19, 2010 | D-Link Dns 323 2-Bay Network Storage...
D-Link DNS 323 Bittorrent doesn't start
Make sure that the ports for the application are open in both your modem and router
Dec 29, 2009 | D-Link Dns 323 2-Bay Network Storage...
I try to connect DLINK dns 323 to WD TV by USB cable but it not work how can i solve this
The USB port on the D-Link DNS 323 NAS is for a printer only. It won't work with your WD TV. Your best bet would be to plug the WD TV into a PC that is connected to your network along with the D-Link DNS 323 NAS and serve your media files that way.
Sep 04, 2009 | D-Link Dns 323 2-Bay Network Storage...
Bittorrent configuration problem
The new firmware already has bit-torrent capabilities built into it. Please do the following:
1. Download the latest firmware from D-Link website
2. Save your configuration in case there are any problems
3. Upgrade firmware from the DNS-323 menu
May 05, 2009 | D-Link Dns 323 2-Bay Network Storage...
Ftp and upnp problems with dns-323
Try to do the following:
1. Login to your DNS-323 in the same network
2. Make sure FTP is turned on and a user is configured to perform FTP to it
3. Ftp to your DNS-323 using the admin account
If this still does not work, read up on Fonz's fun_plug application and install it. This should let you access the linux firmware in the 323 for troubleshooting. Be aware that you need to know linux before you attempt to do this as you may brick your 323 if you are not careful.
Mar 17, 2009 | D-Link Dns 323 2-Bay Network Storage...
Denon S-32 Shelf System Logo
116 people viewed this question
Top Denon Audio Players & Recorders Experts
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
