Question about Cameras
Hi the tabs that are on the bottom of the minolta z1 that the door latches on to has broken off what can i do?
  • 876 Answers
Is this the battery door? If so, when I took mine in, the repairman put a strong piece of reusable tape on it and said that the repair was more than the camera was worth. I have been using it that way for a long time. You could probably send it to the factory to have it repaired however.
This page will give you the contact information that you need.
http://ca.konicaminolta.com/support/contact/index.html
Posted on Dec 31, 2010
Door is locked will not open
Potential Causes
Door Lock Mechanism broken. • Check Door Lock/Switch Assembly for foreign objects • Check Wire Harness connections to the Door Lock/Switch Assembly and Central
Control Unit (CCU) • Door Lock/Switch Assembly Failure
To Manually unlock the door lock system:
1. Unplug the power cord from the outlet. 2. Remove the lower toe panel. 3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly. 4. Located on the bottom of the door latch assembly is a tear-drop shaped tab. 5. Gently pull the tab down about 1⁄4" or until a click is heard. 6. The door may now be opened.
Feb 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Broken camera
This camera came out in 2003 and retailed for $400. It's only a 3.2MP camera with a 1.5 inch lcd screen...not much by today's standards but was quite a camera in its day. I'm guessing by your list of problems that it would be quite expensive to fix if you could even find someone to fix it. I would seriously consider putting the money toward a new camera.
Feb 26, 2010 | Konica Minolta DiMAGE Z1 Digital Camera
I close washer door but it wont go through cycle
Check to see if one of the two tabs on the door latch assembly are broken. If one is broken, replace the door latch. If the door latch is ok, you might have to replace the door switch and the door latch. To replace the door switch you have to remove the front panel. Remove the two screws holding the door switch assembly in place and drop the door switch assembly down into the bottom of the washer. Remove the wires and transfer to the new switch. Reach up and line up the new switch and install the two screws. Remove the two screws on the door latch assembly on the door, and remove old door latch. Install the new latch and replace the front panel. I hope this helps.
Jan 21, 2010 | Frigidaire Affinity ATF7000E Front Load...
NEFF H5470NOGB Microwave door latch fault
theres a small plastic hook inside the door which holds a tension spring this will have snapped off stopping the latch from entering the lock its actually quite easy to fix the inner plastic frame can be unclipped with a small flat blade screwdriver exposing the hook mechanism and the spring will be lying in the bottom of the door frame you can reconnect it to the metal inner frame it stretches the spring a little more but it will never snap again ive done this loads of times with no probs otherwise you will have to replace the outer door to reinstate the broken hook.
Oct 27, 2008 | Neff H5470 Microwave Oven
Rplacement battery door
the battrery door if still connected you can use a small strip of crome duct tape it blends in with your camera . close the door the best you can and tape it! good luck
Aug 23, 2008 | Konica Minolta DiMAGE Z1 Digital Camera
Broken battery door
You can order a new door from http://uscamera.com/1min038.htm and put it on yourself.
Jul 10, 2008 | Konica Minolta DiMAGE Z1 Digital Camera
MIcrowave
check the door latches inside the oven, open the housing and spray some lubricants on the latches.
Feb 21, 2008 | Frigidaire FMV145K Microwave Oven
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
