Question about Dynex S-Video A/V Selector Switch
What do I plug into the TV? the input or the out
  • Dynex Master
  • 6,694 Answers
connect the output of a/v selector to ur tv, and the source (dvd,cable box etc) outputs to a/v selector.
ok
Posted on Dec 31, 2010
How to connect Magnavox TV Model CH 3930 AL O2 to VHS player?
Actually, what you want to do is connect the VHS player to your TV. Your VHS player has three output leads: R. audio (red), L. audio (white), and video (yellow). These connect to corresponding inputs on the rear of your TV. Select VCR as the input source to your TV.
Mar 27, 2017 | Magnavox Televison & Video
Where to plug in to tv
You can put it in anyone of them as long as you change the input on your tv to match the input you have plugged into. (ex. if you plug into input 1 then your tv needs to be set to input 1) . This is done by hitting the source button or the input button.
Feb 15, 2015 | Televison & Video
When plugging antenna in 37: protron tv do I use analog input or digital input?
An antenna is analog. Try using the setup menu for the tv to choose analog input.
Jan 18, 2015 | Protron PLTV-3750 Television
The sound from my tv will not play through my surround sound.
Make sure that you have your receivers input selector to the correct input that you plugged your tv into. Try plugging the tv output into the working input that you have for the dvd. If the tv still does not work, and you are using a working input, then clearly, there is no workable signal going into the receiver. In tv menu check the audio output format.
Some tv sets output their audio signal in digital format. If you plug that into a receiver with an analog audio input it will result in silence.
Apr 02, 2014 | Audio Players & Recorders
WE ARE TRYING TO GET TELEVISON RECEPTIOB BUT WE GET "NO SIGNAL INPUT COMPONENT 5 AND THEN IT POWERS OFF". WE HAVE A PIONEER PDP 425 MX. I HAVE TRIED TO USE ONLY INPUT 4 BUT TV WILL NOT STAY ON...
The reason your tv is powering down is that it is not receiving an input signal on the channel (input). basically you don't have anything plugged in and turned so the tv doesn't see a signal on component 5 so it shuts the tv off. turn on your TV and hit the input button until you get to the input that you are have a device installed on. just make sure the device you are trying to see on the tv is turned on prior to turning on your tv.
If you do not have an and device plugged in (cable or other input device), plug something in to an input and turn the device on so a signal is being sent to the tv and then turn on your tv and change the channel to that input.
if you are locked on input 5, install and turn on a device to that input so the TV registers it as an active input.
Jul 02, 2011 | Televison & Video
Hi, I am having trouble connecting my Nintendo Wii to my Onkyo TX-SR507
Take the adapter cable from the Wii that plugs into the back of the Wii and converts the output(audio/video) into RCA style pin plugs, you will have: RED=right channel audio, plug it into any of the red audio INPUT on your Onkyo, then you will have WHITE=left channel audio, plug it into the other white INPUT jack next to the red plug on the Onkyo, then you will have YELLOW= video(picture) that will go directly to the yellow video INPUT on the back or side INPUTS of your TV.
Then when you want to play the Wii, set the input mode on the Onkyo to the inputs that you connected the red and white plugs into, then change the input on your TV to which ever the input is labeled on your TV in which you plugged the yellow plug into, you now will have sound comming from your Onkyo and the Wii up on the TV screen ready to play. Good luck!
Jan 27, 2010 | Onkyo Tx-sr507 A/V Receiver
How do you hook up the atari flashback to the tv?
To hook up the Atari Flashback to the TV, it requires you hooking up the RCA Plugs. The Video cable hooks up to the video input of your TV and the audio plugs hook up to the Left and right of the Audio inputs of the TV.
Just make sure you remember that if you have multiple inputs on your TV that you know what input you have the flashback hooked up to and change the TV to that input.
Aug 11, 2009 | Atari Video Game Consoles & Games
Av cable
Before plugging up any cables to your TV, look to make sure that you know the input number on the back of the tv if you have multiple inputs on your TV.
Make sure the video cable plugs into the video input on your tv, then the two audio cables, make sure they plug into the audio inputs on your tv and then make sure your tv is set to the right input and everything should be good, turn on the game system and enjoy.
Jul 31, 2009 | Sony Video Game Consoles & Games
HOW TO HOOK UP A VCR
yellow cord from vcr plug in the yellow input and then the yellow input on the tv
red cord from vcr plug in the red input and then the red input on the tv
white cord from vcr plug in the white input and then the white input on the tv
Jul 16, 2008 | Televison & Video
How to connect surround sound system, at the moment its connected through cable, each time we use the dvd player we have take them out of the cable box then into the dvd player, we have a LG 42PC55 tv.
In order of picture and sound quality -- from best to worst:
1. The best way to connect, assuming your TV and A/V Receiver and/or Cable Box have the jacks, is to use a HDMI cable ( this cable is for both sound and video).
2. Use Component Video out to input (3 RCA plugs, Red, Blue & Green) along with RCA Audio out to input (2 RCA plugs for stereo - 1 for mono).
3. Use S-Video out to input (1 din plug) along with RCA Audio out to input (2 RCA plugs for stereo - 1 for mono).
4. Use Video out to input (1 RCA plug, yellow) along with RCA Audio out to input (2 RCA plugs for stereo - 1 for mono).
Be sure to select the correct inputs on your TV and Audio/Video receiver when you are watching TV. For example if you have connected your TV to HDMI 1 and DVD to HDMI 2, you will not see or hear anything if you don't select the correct input on your TV and A/V receiver for the input you want to see and hear.
Detailed connection instructions will be found in your owners' manuals.
Hope this helped you. :)
Mar 30, 2008 | Televison & Video
Dynex S-Video A/V Selector Switch Logo
299 people viewed this question
Top Dynex Audio Players & Recorders Experts
Mike Neath
Mike Neath
Electro Med Services...
Are you a Dynex Audio Player and Recorder Expert? Answer questions, earn points and help others
