Question about Scheu (85-FAC) Heater
Have 2 heaters 1st heater will not light, has gas
Have 2 heaters 1st heater will not light, has gas and spark but will not light 2nd heater only stays lit if you hold down on the igniter button, otherwise works fine.
  • 784 Answers
Sometimes you need to hold down the button for 5 to 10 seconds while the heater heats up,, as soon as it gets to temperature then it should stay on with no problem.
as far as the one that is not lighting -- all I can thing of is that the igniter is not close enough to the fuel exit area ( ? ),, with the power off - ( un-plugged ) look inside as you press the igniter and see if you can see the spark arch. -- also, if this is a new heater there is a chance that there might be something wrong with the regulator and it is either getting to much or not enough gas.
c...
Posted on Dec 31, 2010
2012 Rockwood 8288ws just purchased. When I turn the switch on for the water heater it cycles trying to ignite gas. I want to run electric only. What am I doing wrong?
1st Question - Can you verify that you actually have a Gas/Electic Waterheater? Most units are gas only. You may have to look at the unit and look for power cables.
2nd. Is power connected prior to turning on the water heater?
May 10, 2015 | Forest River 2012 Rockwood Signature Ultra...
How do you know the temperature heater is running at when set on light orange 1st or 2nd square
The only way to tell is to use a thermometer as the outlet heat is based upon the surounding air temperature.
Aug 02, 2014 | Rinnai EnergySaver ES38 Gas Fired Direct...
Pilot light wont light will spark, but no propane
verify the inlet pressure to the heater. those pezioelectric spark lighters are garbage. make sure all manual shut off valves to the heater are open. Pilot tubing may also be blocked
Nov 25, 2013 | Glo-warm 503284 30000 BTU Propane Gas Vent...
I have 2 zone gas hot water heat. When I turn 1st floor zone down to 60 degrees and 2nd floor zone up to 80 degrees why do I get heat on 1st floor.
Gas Furnace
If you are looking for a high efficiency furnace with up to 96% efficiency then Amana AMH95 forced air gas furnace is a considerable furnace for you home heating requirements.
- See more at: http://www.cleanairheat.ca/amana-amh95-gas-furnace.php#sthash.FeFfEH9f.dpuf
Oct 28, 2013 | Heating & Cooling
7-25-11. Purchased Reliance 909 model 950 GKRT 200 natural gas hot water heater. 7-31-11, installed said hot water heater according to instructions and code, filled with cold water and checked for gas and...
The problem requires looking at manual and service handbook, except handbook doesn't show most recent water heater.
My first check point would be gas supply, and then vent draft, and then air supply.
Take off front cover and try lighting again to make sure air supply is not problem.
Review lighting instructions.
If there is no gas, and gas is turned ON, then gas control valve is suspect.
On-line manual for Reliance 909 gas
http://www.reliancewaterheaters.com/lit/om/manuals/186486-002.pdf
Reliance 2006 service handbook:
http://waterheatertimer.org/pdf/Reliance-2006-Service-Handbook.pdf
Other resources:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/images/Test-water-heater-vent-1400.jpg
http://waterheatertimer.org/images/Water-heater-in-attic-800.jpg
Jul 31, 2011 | Reliance Natural Gas Water Heater Control
My heater will not light and electronic ignighter just continually sparks but burners do not light up? I've checked gas, etc but just won't light. Any suggestions? Do burners need replacing? Heater is 8yrs...
Do you physically see the spark or are you just hearing it. You can also take the igniter wire off of the control module and disconnect the pilot gas tubing from the gas valve. Turn the heater on and wait to see if you hear and smell gas coming out of the gas valve. If there is no gas check for 24v at the PV connection on the module. If there is voltage the problem is the gas valve. If no voltage the problem is the ignition module. If there is gas I would replace the pilot and gas tubing.
Santa Clarita Pool Heater Repair
Apr 19, 2010 | Pentair 250k Minimax Ch Ng Mv Heater
Reddy 115 will not ignite
1st check to see if you have spark, 2nd check the pump pressure using the correct pressure gauge, the pressure should be 5.1 psi for model 115. if little or no pressure you may have a air line leak or a defective rotor. if you do have pressure you may have a plugged nozzle. i hope this helps.
Jan 08, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Laars Lite heater not working
1st time this happened to me the filter wasn't clean. 2nd time it was the pressure switch and for the third time they say I have to bleed the gas line, not enough gas to lite. And I also need the on/off switch gone bad.
Jun 08, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Scheu (85-FAC) Heater Logo
174 people viewed this question
Top Scheu Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Scheu Heating and Cooling Expert? Answer questions, earn points and help others
