Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
I cannot install windows xp
It is showing acpi error
    Problem Solver:
  • 3 Answers
Just keep f7 key pressed while booting
Posted on Jul 08, 2008
Why ACPI not supported by upgrade to windows 7
acpi is supporrted by win 7 just make sure ist on in the bios and download acpi driver from the motherboard factory
Microsoft ACPI Driver Windows 7 Service batcmd com
Sep 05, 2014 | Computers & Internet
Why error 'ACPI not supported' when installating windows 7 home premium
the motherboard you are using is too old for windows 7
did you start with the application disk? that has to be first then the web will find the rest
Attempted to install service pack 3 but received error message: C:\windows\system32\drivers\acpi\sys.
Hi Michelle,
This problem happens if you run "Alcohol 120%" and "DAEMON Tools" applications. If you don't have these apps installed follow the below step to fix this issue.
  1. Go google "Unlocker Assistance" and download the software (or the link is provided below), it's free and very useful program. This program can unlock or kill or delete any files that's being used, no matter what situation the file is on, it can unlock the file or kill the process which is using it. (The icon looks like a star magic wand, that's the right program)
    Download the software below if you have trouble finding it. http://www.techspot.com/downloads/1029-unlocker.html
  2. After you install the program, then go in your My Computer, and right click on the C:\ and click on Search. Then find the keyword "atapi.sys" that the error message mentioned. You will see an icon that looks like a white sheet of paper, right click on that and choose "Unlocker" on the menu. I don't know if this would show up by default, but it should. After that a window should pop up showing you which program is currently using the file, I think it was "System". Now you need to click either on the "Unlock" or "Unlock All".
  3. After that, the "atapi.sys" file should be unlocked. Now, go back to the error message and you should see "Retry" or something like that, then just click on that. Viola, the process will continue on.
Feb 07, 2012 | Microsoft Windows XP
Dear Friends, My Toshiba Satellite M45-S2652 (PSM40U) is showing problem during windows XP/Vista/7/Even Windows ME installation. This system BIOS is not compliant with ACPI. Bios ver was 1.5 which upgraded...
Please go through the following Article if you are trying to install XP in the Compute. This should help you resolve the problem.
http://support.microsoft.com/default.aspx?scid=kb;en-us;Q314830
Dec 06, 2010 | Toshiba Satellite M45X-S331 Notebook
Xp installation problem
Goto bios - disable sata operations and select hard drive type as normal, disable ahci, disable acpi
May 29, 2010 | Gateway T-6330U Notebook
I need to disable tha acpi on an acer travelmate 529tx but i don't know how to do it. i am trying to install xp after a failure. i get bsod and says to press f7 when i install storage drivers but i need a...
I have seen on many forums that ACPI makes a lot of troubles to a lot of users under Windows. I will try to explain several things about ACPI and I hope that you will be able to solve your problems after you read this article. I cover only most encountered issues, but always there is a choice even if it's called ACPI disable.:)
The computer ACPI support is detected in the setup stage, but there are less frequent cases when ACPI is not detected and the Standard PC HAL is installed. If you want to force the installation of the ACPI HAL:
1. At the blue screen of the Windows XP setup when it prompts you to press F6 for additional mass storage devices press F5 and you will have a list of options.
2. Choose the proper HAL for your machine remembering that there are also different HALs for multiprocessor machines.
3. Complete the setup, go to Setup / Control Panel / System / Hardware / Device Manager / Computer. If you have listed the Advanced configuration and Power Management (ACPI) the process was completed successfully.
Warning: You can do the same thing if you don't want to install ACPI and your BIOS doesn't support ACPI disable setting. Just choose the Standard Computer HAL from the list of options.
Another method to disable ACPI is:
  • wait for the text-phase of XP setup to complete
  • before XP Setup Wizard to load, boot into DOS and change ACPIEnable = 0 from ACPIEnable = 1 in file c:\txtsetup.sif
The reason why ACPI is not installed on a computer with known ACPI compatibility may be a Microsoft known subtle incompatibility which can lead to hardware instability. In the installation step Windows XP checks the BIOS compatibility with ACPI and the BIOS presence on a known bad list. If the BIOS is there ACPI is not installed. Of course than errors can occur so you can force the ACPI installation (not recommended).
Try disabling it in the BIOS first, this can not be done on a computer with the operating system already installed as it will cause the machine to stop. MUST be done when you initially install the OPERATING SYSTEM.
Regards.
Nov 16, 2008 | Acer Computers & Internet
Windows XP Problem
if you got the OS cd, insert and boot from cd and try a repair.
or check for solutions in the solution range i used to fix similar problem from http://www.tinyurl.com/52mwor
source:
solution dictionary for fixing all pc problems on htpp://www.tinyurl.com/52mwor
http://www.digitalpowering.blogspot.com
Oct 29, 2008 | Microsoft Windows XP Professional for PC
Problem on o/s installation
Look in your bios & see if you can disable the ACPI, (which you should be able too do. Finish installing your OS. Than update the OS. After completing all updates re-enter your bios & enable the ACPI. You should not get that error message after re-start.
Boards that support ACPI will get this error during a fresh install untill they get windows updated. All OS's
Post back if this did not help! It worked for me.
Please vote..
Jan 28, 2008 | Intel D945GNT Motherboard
HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
24 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
