Question about Dryers
Everything is connected properly and the dryer wont turn on
    Scholar:
  • 117 Answers
Assuming that the breaker is not simply kicked, you could have a blown thermal fuse. the thermal fuse is designed to blow in the advent of a overheating and a potential fire. this fuse will most likely be located on the heating element housing. You will have to open up the dryer to gain access to all the parts.
Posted on Dec 31, 2010
    Top Expert:
  • Dryers Master
  • 9,472 Answers
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
I have a Frigidaire GLET1031 Top Load Stacked Washer / Dryer. The water valves do not work unless the dryer is turned on. Also the washer drum will not spin with dryer on or off and the dryer does not get...
WHat ya need to check is for proper power going to the entire unit it sounds as if either a breaker is off or their is burnt/broken wire from the main power connection.
All symptons listed i suppose occured suddendly?? and to me its a lack of proper electrical power that is causing all of them.
GENE
Oct 03, 2011 | Frigidaire GLET1031 Top Load Stacked...
Put new belt on dryer but it wont turn and i can smell burning and the drum wont turn
sounds like the belt may be bound somewhere, I would take it back apart and see if I can turn everything by hand. If everything turns freely then I would reinsert drum, hook belt up and see it I could turn the drum with my hands, it will turn but not to freely. Hope this helped tim
Sep 19, 2010 | Dryers
Converted to propane ,installed turned on seems to heat etc properly but smell gas
Propane will often give you an odor even though you have done everything correctly...just spray all connection with soapy water to make sure you don't have any leaks...
heatman101
Sep 11, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Tromm LG gas dryer 5988 gas wont turn on says DRYING but it's not Everything else works
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 06, 2010 | LG DLG5988 Gas Dryer
Dryer wont turn
If a dryer drum doesn't turn but everything else seems to working properly, a broken drive belt is usually to blame. Changing the belt is not a tough job if you can handle a screwdriver and have a little patience. This site has great detailed instructions for how to do it, as well as offering the belt and other parts at good prices. (No, I do not have any connection with the site; I just find it about the easiest one to follow!)
Get the belt and have at it! You'll save around $100 if you do it yourself, and feel pretty good about yourself too. Good luck and thanks for using Fixya!
Jan 31, 2010 | Kenmore Dryers
Dryer wont turn on
It is probably the thermal fuse/ cutoff. It is a small white plastic piece on near the motor housing.
http://www.partselect.com/PartDetail.aspx?Inventory=345113&SourceCode=6
or
http://www.partselect.com/PartDetail.aspx?Inventory=344958&SourceCode=6
This is usually caused be an airflow problem. Make sure a the dryer vent is blowing properly after replacing the thermal cutoff.
Jan 16, 2010 | Whirlpool LER4634J Electric Dryer
Dryer starts but wont stay on
There is a switch on the motor that activates when the drum is turning at the proper speed. This switch should be checked if the drum is turning properly.
Eric
Jun 14, 2009 | Kenmore Dryers
My printer wont turn on!!!!!
please check if its connected properly...the wire connected from the printer to socket
if everything is fine and still does not work,.open the outer cover and see if the connections are properly solidered in place..
Jun 13, 2008 | Computers & Internet
Whirlpool LTE5243D Top Load Stacked Dryer heats sometimes and not others
couple things this could be lets start obvious
faulty door switch even though door latches doesnt mean its working properly
bad guages easy to check dont have to run dryer just guages
turn on setting let run threw cycle if it stops on cycle and dont move for a length of time this will be the problem
these 2 things are main causes of why a machine wont work or partcially works at times everything else is easy
Nov 27, 2007 | Whirlpool LTE5243D Top Load Stacked...
Dryers Logo
Top Dryers Experts
