Question about Fisher and Paykel Washing Machines
Dirt on clothing after washing - black - Fisher and Paykel Washing Machines
  • 1,998 Answers
What model fisher and paykell is yours or the model number and could you please elaborate on what you put in the washer to wash and what it was like when you removed the clothing also if there are any lights staying on on your unit would be beneficial as well thanks again Rick
Posted on Dec 31, 2010
4 Suggested Answers
venexcsd
  • 1185 Answers
SOURCE: dirt left in creases after washing clothes. Clothes never look clean
Too many clothes in the load , if it says 5lb then that is the maximum you should fill it with otherwise the clothes do not seperate as they are being agitated
Also
Not enough detergent (Try the old powder types)
Hard Water area (Use a small amount of Washing Soda)
Water level too low , use add water button if fitted
Posted on May 21, 2009
  • 5 Answers
SOURCE: keep getting black dirt residue on a white wash?
clean the filters
Posted on Sep 09, 2009
beltronic205
  • 1460 Answers
SOURCE: when washing i get dirt all over my clothes
Could be oil from a leaky bearing. try flushing out machine 1st to try to cure...Good luck...
Posted on Oct 01, 2009
The machine did not rinse properly and the clothes had black stuff all over them and the machine has black stuff in it .What has happened ?
Sometimes the hoses break down and the material will follow with the water into the machine. Try replacing hot & cold water hoses.
Jun 03, 2015 | Fisher and Paykel Washing Machines
How to clean washingmchine internaly
Need to establish if the dirt was from the washing or the machine. Do another wash (hot with dirty or dark clothes which don't matter (or empty) and wash out your machine. Then wash again with a white low value sheet and see if problem persists. If it does, your machine bearings may need replaced, .
Dec 09, 2013 | Washing Machines
How do I wash my dog's clothing?
As with anything, always read the label for instructions on how to wash the clothing. I would also use a hypoallergenic laundry detergent because my dog was allergic to the detergent we once kept in the house.
Dec 31, 2012 | Dogs
Lg washer leaving black greasy marks on clothes
This is usually to do with fabric softener. Dilute it with more water. The fabric softener makes clots, and these make the marks on your clothing.
Hope it helps
* If you found this solution helpful, please vote positively.
Feb 17, 2011 | LG WM2077CW XL Front Load Stackable Washer...
When washing i get dirt all over my clothes
Oct 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Dirt in rinse cycle causes clean clothes to come out with dirt all over them and inside of the washing tub has dirt everywhere!
Several things could be happening...The machine is NOT "spitting" all the water out and there is STILL some dirty h2o (water) in the wash. You could be putting in dirty WELL water ? If you have HARD water and your "hard water filter, cleaner not working. Your cloths could be SOOOOOOOOO dirty ( no offence !!! because there are many D I R T Y jobs that could take two(2) washings ) that they are not getting clean.
Aug 31, 2009 | Washing Machines
Dirt left in creases after washing clothes. Clothes never look clean
Also
May 21, 2009 | Fisher and Paykel GWL11 Top Load Washer
Black marks
To eliminate possible bearing failure, spin the drum by hand and see if u can detect any rumbling noise or strange nioses coming from the drum, if u can then it is probably grease that is coming from the bearings. The other possible cause is an effect called ****, this is a result of washing at too low a temp, this causes a build up of dirt and grease,leading to the sort of prob that u are experiencing The thing u should do is to put the washer on at a high temp with powder in but no washing and do a full wash . This is called a maintenance wash, and should be done at least three or times a year depending on how often u wash more frequently if u do a lot of washing. Clean the door glass and rubber seal as thoroughly as u can ,and remove as much sludge and dirt as poss. This should help with your prob. Plz rate my solution. Thanks.
Dec 31, 2008 | Frigidaire 14 Cycle Tumble Action Washer
Fisher Paykel washer GWL15
I have noticed this same problem and wonder if it because my FP washer wasn't draining properly and dirty water couldn't get out. See my post on "eco smart won't drain, smells hot". I found one of my husband's socks when I removed the black motor/white plastic housing on bottom of washer. tip washer back and you'll see this electric motor. My post tells how to remove it. then you can look into that small space and see if there is something plugging it.
I am waiting on my replacemt motor, and hoping all the dirty streaks are gone. the water I drained out after i removed the sock was really grimy and gritty with dirt. I'm sure the sock has been holding a lot of junk in the bottom of the tub and it would end up on clothes during spin cycle. My issue has been going on for a few weeks and then the motor finally smoked which led to the sock discovery!
Oct 02, 2008 | Fisher Paykel EcoSmart GWL15
Washing Machines Logo
26 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
