Question about Canon Optura 30 Mini DV Digital Camcorder
My canon Optura 30 will not power on and will not eject the tape. I plugged it in the wall. I popped out the battery and re-inserted it. Nothing happens. What is wrong? What do I need to do? How can I at least eject the tape?
Remove tape from dead camcorder?
I think the battery failed, I would replace the battery. You can buy the battery by number (battery info is printed on the battery) on eBay.
Mar 23, 2017 | Canon Optura 50 Mini DV Digital Camcorder
Optura 60 cannot be turned on
Whether you think the battery is fully charged or not this sounds like a defective battery problem. Have the battery checked.
May 05, 2017 | Canon Optura 60 Mini DV Digital Camcorder
Tape won't eject on Canon Optura 20 MiniDV. About
This can be caused by several problems including a defective eject switch in the cameras internal circuitry or a bad motor and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Jul 30, 2011 | Canon Optura 20 Mini DV Digital Camcorder
DV tape won't eject from Canon Optura 20. Power on, screen flashes "eject". Battery is fine. Tape comes up but won't release.
Tape mechanism problems can be quite complicated but they can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be diagnosed by a qualified service technician.
Dec 18, 2010 | Canon Optura 60 Mini DV Digital Camcorder
Will not eject mini dv tape
I had the same problem. I cycled through the eject process until it finally gave me back my tape. I had to send it back to have the tape carriage replaced
May 03, 2010 | Canon Optura 20 Mini DV Digital Camcorder
Eject mechanism not functioning
Once when this happened to me, I took it to a repair shop and they said it just needed to be cleaned. (Optura PI tape won't eject)
    Dec 28, 2009 | Canon Optura Pi Mini DV Digital Camcorder
    Reads "eject tape" or "remove tape"
    Theres been a failure in the drive system for the tape. Probably mechanical, so you woul need to take it in to get fixed.
    A few times I've been able to resolve this by blowing compressed air in the frame and cleaning the head (if u can get to it)
    Aug 26, 2009 | Canon Optura 20 Mini DV Digital Camcorder
    Optura Pi is eating tapes
    hi from what i understand by "eat" is that the coil is popped out what it means is that the coil leader is misplaced and letting it to run free out of place this can be fixed by you if you will find what had gone wrong in that path (broken pin, cog etc...) and glue it back or fix the missing element in place good luck
    Apr 27, 2006 | Canon Optura Pi Mini DV Digital Camcorder
    Cassette Jam
    The most frequent cause of this type situation is not having a power source attached, or a depleted battery pack. Once the power source is available, some models require manually unlatching and opening the cassette compartment cover. When the cover is fully open, the videocassette will eject automatically. Please try the following procedures. 1. Attach the power source to the camcorder correctly or use a fully-charged battery pack. 2. Fully-open the cassette compartment cover until it stops while sliding and holding the OPEN/EJECT switch. The videocassette will eject automatically after a few seconds. If the videocassette still will not eject, seek assistance from a Canon Service Facility.
    Sep 04, 2005 | Canon Optura 60 Mini DV Digital Camcorder
    Canon Optura 30 Mini DV Digital Camcorder Logo
    55 people viewed this question
    Top Canon Video Cameras Experts
    Pieter Vleeshouwers
    Pieter Vleeshouwers
    Steve Mason
    Are you a Canon Video Camera Expert? Answer questions, earn points and help others
