Do you have saw these picture on your computer?
Or have you do any change of these picture? such as PS or flip? the camera can't read these changed pictures..
A format error probably means that something in your download is corrupted (that is, it didn't get copied from whoever in the internet to you). Try a new download of the same item.
Hi ehoffman7196,
I see you get an error "format error" you mentioned this means that the mp3 player could not play the file you are trying to play.
check the format of the video is it mp3 is it avi is it wmv or possible it may be mp4 that is one reason since you mentioned that the error is format error then it cannot read the file mp4 is the latest format for a video file check first if it is then it really will not play at all.
Error e00100 means that the card is corrupted or formatted for another
digital camera.Format memory card and see the results,Try to format the memory card using a card reader with the PC, if error still exists then it means the memory card is electronically incompatible and won't workThe Kodak C310 uses MMC and SD cards and may be you are using SDHC memory card, In this case change the memory card, I hope problem will be solved, if error still exists then contact to Kodak Cameras service providers.
I hope this solution helps you Your token of appreciation in the form of Four thumbs and testimonial will be esteemed. THANK YOU and Keep Visiting FixYa!
1.) Format error means that the camera cannot read the card. 2.) It is quite likely that you will be able to recover the majority
of your pictures with an image recovery program. There are many programs
available but there is a list of freeware ones at the following page:-
3.) After recovering your pictures, or if you decide to discard them, you could 'Format' your memory card in the camera menus, or do it by right clicking the icon of the card in PC, to bring down the format options. Then format the card again in the camera, to ensure compatibility
1:friend connect the mobile to the PC and select mass storage option go to my computer and right click on the memory card Icon click on format select full format option . the above solution will solve your problem if the error is coming because of bad-sector 2:some times these error comes if there is a code to THE memory card.
3:the memory card is faulty or is infected with virus
Hi, Format error means memory card in camera is unstable and need to be formatted. You will lose all data/ files on memory card after format. Format option is available in camera Menu. This will solve your format error problem in camera.
It means memory stick is unstable / worn out.
Format memory stick by pressing Menu > format.
If problem is still there, put new memory stick in camera.
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card.
CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card.
