Question about Samsung Televison & Video
Hi, my home theater system plays dvd's green and pink. we have tried to resest everything but with no luck.
    Problem Solver:
  • 12 Answers
Sounds like connection: a. if you are using composit video output, make sure video cable is going to video (and not component out) on your dvd and one of the AVs (and not DVD) on your TV. b. If you are using component output, you might need to change the video output in your dvd.
Posted on Jul 08, 2008
The dvd has started playing everything green. We never record and have only played about 25 dvds in it.
Sounds like the settings for the dvd output have been changed. Need to have it re-calibrated.
Apr 08, 2015 | Audio Players & Recorders
When i play dvd the picture is black and white
If you are using component cables red green blue amke sure they are all properly connected and secure. A misconnection will definately cause the picture to be black and white.
Mar 14, 2011 | Samsung Ht-c550 5.1 Dvd Home Theater...
Pink and green colours seem to be too vibrant when watching dvd's on lifestyle 48
I have a Lifestyle 48 which suddenly started producing a pink and green image when playing DVDs (regular TV was fine.) After speaking with Bose support, I did the following which resolved the problem:
1. Removed power from the video switcher. (or from the bose itself if you don't use the switcher.)
2. Reattach all the video cables on the back of the bose and ensure all connections to the TV and switcher (if applicable) are tight.
After performing these steps, my DVD image went back to normal. I suspect it was a loose cable in the end, but no harm in performing the power disconnect.
Apr 11, 2010 | Bose Lifestyle 35 System
SAMSUNG HT-P10 DIGITAL HOME THEATER SYSTEM wont play DVDs
You could try cleaning the drive with a dvd cleaner disk and also a can of compressed air to blow into the drawer. It may just be dirty. Good luck! I hope this helps you.
Aug 27, 2009 | Samsung HT-P10 Theater System
Green tint?
you have a bad video cable and its only allowing green and not red and blue, if changing the cable does not do the trick the you video controler in the dvd player or stereo has go bad, might try pluging dvd player into tv directly. that will help you determine if its the player or stereo. good luck
Jun 13, 2009 | Panasonic Audio Players & Recorders
DVD Does not work when using HDMI from Philips TV to Bravia
You could see if they will exchange just the unit and save both of you the hastle of checking and repackingit all. It does sound like the unit is faulty.
Or if your Bravia has more than one HDMI input then try on another, or a friends tv if you know some one with a HDMI tv in working order.
Apr 29, 2009 | Sony DAV-FC8 System
Unabl to play dvd
hi angedembe, guess your dvd lens is dirty or worn out.try using a dvd lens cleaning disk this might solve your problem n if it still of no use then u have to change your dvd lens.hope the 1st method solve your problem.have a nice time..
raj..
May 11, 2008 | RCA 420Watt 5-Disc DVD/CD Progressive Scan...
SC-HT730 Color problems
What kind of connection are you using? If you are using a component connection or a RGB connection this could be causing your problem check the leads and if so replace new leads.
Apr 06, 2008 | Panasonic SC-HT730 System
Connecting a sony home theater system
When a DVD is played on our Sony (surround sound) player there is a pink cast to any color segment. Old black and white footage is OK.
Sep 14, 2007 | Toshiba 42HL67 42 in. LCD Television
Televison & Video Logo
42 people viewed this question
Henry  Thomas
Henry Thomas
