Question about DeLonghi HHP1500 Mid-Size Heater
DELONGHI hhp 2000 is a 2000w heater. But the heat it provides has become much less when i first used it. (that is one week earlier). Is that company defect or can we fix it.
How do I get the heating element out of a DeLonghi Electric Oil heater?
many times the sealant they use has to be heated with a torch to remove the element . and if not done properly all the oil in the heater makes a really big mess .
Aug 15, 2015 | DeLonghi Heating & Cooling
What would be a reason my DeLonghi penguino heater/ac/humidifier/fan will not put out heat over 55-65 degrees F.?
Try cleaning the air filter. Odds are the motor is getting to hot and it has a safety that stops the motor from over working.
Dec 28, 2014 | Heating & Cooling
My Coffee from my DeLonghi Magnifica does not seem to be hot enough.
Possible weakness in the thermostat which make the heaters cut off at a earlier state. So try to check the machine for any loose connection to the lines, the heaters or else the switch and thermostat must be looked into .
Jan 24, 2011 | DeLonghi EAM3500 Espresso Machine/Coffee...
Noisy oven
Make certain that the heating element is properly seated WHEN THE OVEN IS COLD! When you put "current" through wires and heating elements, they vibrate. Zip tie the wires together outside the oven cavity.
Apr 25, 2009 | DeLonghi Ovens
Delonghi TRD0715T heater
turn timer knob clockwise till arrow points to correct time (your time), there are plastic protrusions "ticks"around the knob, they move in and out, move them in for on, and out for off
select time sectors that you wish hearted to heat, each tick is 15 minutes, experiement and become profecient
Oct 27, 2008 | DeLonghi TRD0715T Oil Filled Radiator...
Efficency with Oil Column heating
because it operates on room air temperature, if this is the only means of heat to this room, leaving it on would be more economical thus keeping the rise in air temp time less=less time it works hard to match what you desire. but if not only source of heat no. time to heat room would be almost the same thus you would save what you used during the day due to fluctuations in room temps between time your furnace would kick on and off.
Jun 08, 2008 | DeLonghi 6507L Oil Filled Radiator Heater
Delonghi "the incredible heat machine" started smoking
Hi Coyote,
I don't know about your specific heater, but, as someone who has a vast electronics background, things that heat tend to give off some fumes. Many electronic componets are LIGHTLY coated with an oil product to provide humidity protection, while the product may sit in a warehouse for years. Typically, such protection, upon being heated, will disperse in the first (maybe) hour of use. but, it could be more, I guess.
BUT, fumes should never be taken lightly. FUMES SHOULD NEVER BE TAKEN LIGHTLY!!!. FUMES MAY KILL YOU!!
How I handle it is...if the fume is noxious, so as to irritate your nose, or eyes, etc. IT IS BAD!!!
Nevertheless, if I were in your boots, I would take the unit outdoors, and let it run on 'HIGH' for about a 1/2 hour, or so. After it cools down, take it indoors and try it again. If it is still fuming, write the manufacturer a "fuming" letter.
Good Luck,
Papou1
Jan 28, 2008 | Heating & Cooling
Re:Electric Convection oven does not heat up. Convection fan works, light works.
It is probably and electrical service issue. If this is a North American unit, it uses two electrical circuits to provide power. You must find and reset the breakers and check that the wiring is operating as intended. Less likely: It could also be a manufacturing defect. DeLonghi uses screw compression connections on some products. Sometimes, they don't work well.
Dec 20, 2007 | DeLonghi DEBIGE 2440 Electric Double Oven
DeLonghi HHP1500 Mid-Size Heater Logo
216 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
