Cant get a/c to run on heat - Heating & Cooling
  • pwrovrload Jul 08, 2008
    AC was on Energy Saver and it shut off completely and now the Unit won't turn back on and the green light won't turn on for the plug and when I click on the test buttons on the plug nothing happens.
  • kpodobnik Jul 24, 2008
    Our green light comes on but the ac unit won't come on. we checked the electrical panel and is fine. I seems to be making a clicking sound but doesn't kick on.
  • 182 Answers
Check the breaker in your electrical panel.
Posted on Jul 08, 2008
Gibson Furnace 80% runs a full cycle, then takes too long to turn back on again. Customer says runs about once an hr
Sounds like a over heat is holding the heat off taking to long allow a call for heat. A limit holding off .
Dec 22, 2017 | Gibson Heating & Cooling
New heat strip does not come on with themo in heat position.
you cant use that thermostat for a heat strip,your thermostat only gives 9 volts to tell the heat pump to come on,a heat strip needs 220 volts to run,DO NOT PLAY WITH ELECTRIC HEATERS!!you do not know what you are doing and can burn your house down or hurt someone!!
May 22, 2015 | Heating & Cooling
Hi my dryer is only just over 1 year old so of course warrenty is up and it wont heat. it runs and circulates but no heat, my husband cleaned out the vent tube what else can we do?? it cant be major its...
it could be the heating element even though it is just over a year old, i have seen heating elements go out on 3 month old dryers, it also could be a thermostat the best thing to do is make sure it is getting the full 220 volts going to it, if it only has 110 volts the motor will run and have no heat and vise versa, then if that is good get to the heating element and look it over real good most of the time the heating coil will be broke into it wont look burnt just broke
May 04, 2011 | Amana Dryers
I cant get much heat in my 2000 chevy venture
check if your thermostate is working... is it having troubles getting to operating tempurature?
check your heater lines that run to the heater core and see if there is heat getting to and from the heater core if the thermostat is running properly...
if you have heat running to and from the heater core then check and make sure your heater controls in the van are switching between defrost and heat and floor properly
could be a heater box problem ....
when i had the same problem with my venture it turned out to be a plugged heater core and i replaced it
Dec 07, 2010 | 2001 Chevrolet Venture
Dryer wont heat
could be the heating element cant check with meter have to open her up and see if one of the heat coils is bad a new one will cost around 80$
Jan 14, 2010 | Kenmore 73952 Gas Dryer
88 s-10 PU 2.5 TBI hard to start after sitting overnight. Misses, bucks and kicks like a mule till it finally starts. Runs good after warmup but I also get no heat. Replaced heater core, thermostat,...
As far as the poor running and hard starting, yes, it could be egr or valves or timing or almost anything. Your heat problem : I suspect the heater core may be air locked. With the engine running, loosen one heater hose with the heat control on hot, and see if you can get any air out of it.
Also, check your water pump. Squeeze your rad hose as tight as you can for a bit. When you release it, you should feel a surge of coolant go through it.
Check your heat control valve to see that it's working.
Nov 15, 2009 | 1988 Chevrolet S-10
Frame where door seals is very hot
Fan should be running when compressor and fan in refrig. is running... replace condenser fan, compressor will over heat with out fan running, and refrig. cant get rid of the heat in pulls out of freezer.
Sep 12, 2007 | Maytag MZD2752G Side by Side Refrigerator
Heating & Cooling Logo
98 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
