Question about Magellan Roadmate 5045 3065 3055 3045-LM 3045-MU 3045 2045 2036-MU 2036 2035 GPS Vent Mount Kit by C...
What is a add feature code - Magellan Roadmate 5045 3065 3055 3045-LM 3045-MU 3045 2045 2036-MU 2036 2035 GPS Vent Mount Kit by C...
How do I add a call to an existing call?
features come from network provider of phone.
Telstra Australia has
http://www.ross.net/notes/conference_calls.shtml
Google
your network provider's name
and add the words
third party conferencing codes
Oct 13, 2015 | Lands Phones
Show me a list of the feature codes for the T7316 so i know how to turn the ringer on. When i press the menu key, i need a feature number to go further.
menu key??? google ---'Norstar feature codes'
feature *80 controls ringer volume
feature 85 and feature #85 adds and removes do not disturb
Oct 13, 2014 | NorStar T7316E Corded Phone
K7gmhbcj
Check the Code setting on your radios and be certain they are all set to the same Code. Turn off any special features and keep the radios set to a simple setting with the frequency and code matching one another. Add features back in once you have established communications.
Apr 13, 2014 | Motorola Radio Communications
I just bought it and tested on a channel and eliminator code and it worked fine. But after a while I cannot hear static when holding "mon" and cannot hear the other radio if I talk into one. This happens...
If the radios are working fine otherwise, don't worry about the monitor feature not creating white noise (static). If you are still having a problem with the radios, try setting the interference eliminator code to off (zero). And turn off any other special features to see if you can regain communications. Then slowly add the features back in as you need them. All radios must be identical in freq., code, and features.
Best regards.
Aug 19, 2013 | Motorola Talkabout T5720 (7 Channels)...
PROGRAM SPEED DIAL FUNCTION TO MEMORY BUTTON ON NORSTAR T7316
press feature * (star (shift 8)) 3, push the memory key (speed dial), then feature 0. This programs speed dial to that memory key.
Aug 04, 2017 | NorStar T7316E Corded Phone
Kenmore h2 error code
April 8 2002 DIV 26 SOURCE 110 KENMORE ELITE HE3 & HET WASHERS "ADD-A-GARMENT" INDICATOR LIGHT ON DOOR WON'T UNLOCK WHEN PAUSE/CANCEL BUTTON IS DEPRESSED.
MODELS: See additional page for Kenmore model numbers
COMPLAINT: Due to a Microcomputer Machine Control software error , the ADD-A-GARMENT feature becomes inoperative.
CORRECTION: The Microcomputer Machine Control must be replaced with a service part that has been reprogrammed to prevent ADD-A-GARMENT feature loss.
PARTS: Order electronic control listed on this service flash by model from Division 26 , Source 110 following normal ordering procedure.
MERCHANDISE CODES: WASHER Service Flash - Model Nurnbers for: Kenmore Elite HE3 & HE3t Washers: "ADD-A-GARMENT" indicator light on door won't unlock when Pause/Cancel button is depressed. Kenmore models with serial Numbers beginning with CSL23 through CSM04 11042822200 11042824200 11042826200 11042832200 11042834200 11042836200 11042922200 11042924200 11042926200 11042932200 11042934200 11042936200 Electronic conrrol p/n 8181900 Electronic control p/n 8181899
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 11, 2010 | Kenmore 46462 Front Load Washer
When I try to run the TUB CLEAN feature on my LG WM2455HG, it err
Actually, that is not an error code. It is telling you to add bleach to the dispenser for the tub clean feature.
All you need to do is add bleach at this point (or Whirlout which works even better). Make sure you do not have any clothes in the machine when doing the tub clean cycle.
Hope this helps, please rate my answer.
Jan 05, 2009 | LG WM-2277HW Front Load Washer
Turning off the music feature on M7310
Anytime you want to reverse something on that phone, just add # to the command. Feature - # - 86 will turn that music off.
Nov 22, 2008 | NorStar M7310 Corded Phone
PICK UP GROUPS AND HUNT GROUPS
You will need to talk to the phone administrator. It needs to be set up in system admin.
Nov 08, 2007 | Avaya Definity 6408D Corded Phone
Magellan Roadmate 5045 3065 3055 3045-LM 3045-MU 3045 2045 2036-MU 2036 2035 GPS Vent Mount Kit by C... Logo
2,132 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
